It basically as @Closet Skeleton says. If you add water, you're adding a solvent - if you add too much, you inhibit the ability of the paint to bind, so you get weak adhesion and other issues (e.g. altering the properties/behaviour of the paint). The medium is essentially acrylic binder, so you don't end up with this problem.
Vince Venturella had a very good video on the subject:
Register a new account
Sign in
