Agramar_The_Luna_Wolf Posted March 19, 2023 Share Posted March 19, 2023 (edited) Ok, this bit weird question but...I have doubts and I need more opinions. Well, I was making a list with Battlescribe this evening and my intention was put a squad of Tartaros Terminators of five, all with a pair lighting claws each. But Battlescribe don't allow me to put a pair in the squad's sargent. Only one lighting claw. I thought the entry allows that ("any member of the squad..."). Is correct Battlescribe or is a mistake? Edit: The rest of the options of the type("Any member of the squad...") are allowed for Sargents. The only one forbidden is pair of lighting claws. And same happens with Cataphactii. Edited March 19, 2023 by AGRAMAR Extra info Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/ Share on other sites More sharing options...
SkimaskMohawk Posted March 20, 2023 Share Posted March 20, 2023 Battle scribe is wrong, the Terminator entries are allowed double lightning claw on the seargent. Agramar_The_Luna_Wolf and Oxydo 2 Back to top Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921766 Share on other sites More sharing options...
MichaelCarmine Posted March 20, 2023 Share Posted March 20, 2023 You have to click on the red dot on the right side of the sergeant-entry, the sergeant with twin lightning claws is in fact a "different" upgrade in Battlescribe. =] SkimaskMohawk, Xenith and Oxydo 3 Back to top Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921783 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted March 20, 2023 Author Share Posted March 20, 2023 5 hours ago, MichaelCarmine said: You have to click on the red dot on the right side of the sergeant-entry, the sergeant with twin lightning claws is in fact a "different" upgrade in Battlescribe. =] Humm...I downloaded it last Wednesday and wasn't. Maybe I need check new versions. I'll do it. But I can tell you that upgrade isn't in for now. I'm going to check the version. Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921812 Share on other sites More sharing options...
Solution MichaelCarmine Posted March 20, 2023 Solution Share Posted March 20, 2023 22 minutes ago, AGRAMAR said: Humm...I downloaded it last Wednesday and wasn't. Maybe I need check new versions. I'll do it. But I can tell you that upgrade isn't in for now. I'm going to check the version. My Version is v2.03.25.338 and i use it on Android. =] First Step Second Step Xenith, Agramar_The_Luna_Wolf and Oxydo 3 Back to top Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921814 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted March 20, 2023 Author Share Posted March 20, 2023 14 minutes ago, MichaelCarmine said: My Version is v2.03.25.338 and i use it on Android. =] First Step Second Step Just updated I and I got it now. Thanks! But the option "TLC" of Twin lighting claws wasn't in the roster. Now it is. Maybe I need tp check updates more often.. Anyway, case solved. Thanks again! Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921817 Share on other sites More sharing options...
Xenith Posted March 20, 2023 Share Posted March 20, 2023 It's the same with Cataphractii, the Sergeant with TLC is a 'separate' option to the normal sergeant, you can't just upgrade the weapons, but the whole model. Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921825 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted March 20, 2023 Author Share Posted March 20, 2023 9 minutes ago, Xenith said: It's the same with Cataphractii, the Sergeant with TLC is a 'separate' option to the normal sergeant, you can't just upgrade the weapons, but the whole model. I know. But that options were miss. Only could change one weapon to LC. Now is upgraded so I can put my beloved TLCs Link to comment https://bolterandchainsword.com/topic/377970-pair-of-lighting-claws-tartaros-sargents-and-battlescribe/#findComment-5921828 Share on other sites More sharing options...
