Helias_Tancred Posted April 20, 2023 Share Posted April 20, 2023 Run the traditional 3 model box sets (Aggressors, Eradicators, Eliminators, etc) as one 5 man squad or 2 three-man squads? Thanks. Link to comment https://bolterandchainsword.com/topic/378386-is-it-more-efficient-to/ Share on other sites More sharing options...
Rik Lightstar Posted April 21, 2023 Share Posted April 21, 2023 With 10th changing/removing the restrictions on, and even the concept of, the Force Organisation Chart you won't be limited to a certain number of Elite choices for example but will still be limited to how many iterations of each unit you can take. So it depends how many units/models you want to take in total and which edition you're building for. If you want 9 of them in 9th Edition then putting them in 2 units leaves you an additional Elite Slot for another unit, in 10th you may as well have 3 units of 3. Rik Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/378386-is-it-more-efficient-to/#findComment-5937671 Share on other sites More sharing options...
Karhedron Posted April 21, 2023 Share Posted April 21, 2023 Larger units will now be more resistant to Morale. Also, most Character buffs only affect one unit so a larger unit will provide more bang for your buck. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/378386-is-it-more-efficient-to/#findComment-5937682 Share on other sites More sharing options...
Marshal Mittens Posted April 21, 2023 Share Posted April 21, 2023 If you run 3 marine units, 2 need to die before they start testing for moral; 66% of the unit. In a 5 Marine unit, 3, or 60%, need to die before you start testing. In a 6 Marine unit, you also test at 3 dead marines, or 50%. 2x3 Marine units seem more resistant to moral, and you can never lose more than 3 models to a single powerful shooting attack. And for both units to need to test, you would need to lose 2 models from each, or 4 models out of 6 in total. I think big squads look very cool, but the rules seem to favor odd numbered squads and small squads. Karhedron and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/378386-is-it-more-efficient-to/#findComment-5937699 Share on other sites More sharing options...
Lemondish Posted April 21, 2023 Share Posted April 21, 2023 7 hours ago, Marshal Mittens said: In a 6 Marine unit, you also test at 3 dead marines, or 50%. Wouldn't you test after four dead Marines because battle shock tests are done when you are below half-strength? mel_danes and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/378386-is-it-more-efficient-to/#findComment-5937856 Share on other sites More sharing options...
