44er Tabletop Posted May 1, 2023 Share Posted May 1, 2023 (edited) How does Rapidfire work? Havent played since beginning of 8th and dont remember how i did it back then. Now for 10th: A weapon has 2 shots (A=2) and the Rapidfire 2 trait. It then fires 2+2 on half range? If it has 1 shot (A=1) and RF 2, it fires 3 on half range? Is this correct? It has always been like this? Edited May 1, 2023 by 44er Tabletop Link to comment https://bolterandchainsword.com/topic/378503-rapidfire/ Share on other sites More sharing options...
Solution Kallas Posted May 1, 2023 Solution Share Posted May 1, 2023 5 hours ago, 44er Tabletop said: How does Rapidfire work? Havent played since beginning of 8th and dont remember how i did it back then. If your firing model is within half the maximum range of their target, they make twice as many attacks as their listed value. Example 1: a Bolter is 24" Rapid Fire 1, so if the model was within 12", they would fire 2 shots instead of the normal 1. Example 2: a Pulse Rifle is 30" Rapid Fire 1, so if the model was within 15", they would fire 2 shots instead of the normal 1. Example 3: a Storm Bolter is 24" Rapid Fire 2, so if the model was within 12", they would fire 4 shots instead of the normal 2. 5 hours ago, 44er Tabletop said: A weapon has 2 shots (A=2) and the Rapidfire 2 trait. It then fires 2+2 on half range? If it has 1 shot (A=1) and RF 2, it fires 3 on half range? Is this correct? Correct, as far as we know. 5 hours ago, 44er Tabletop said: It has always been like this? No, the [Rapid Fire X] rule is new to 10th Edition: before 10th, it has always been "double shots at half [for most editions]/12" [for 4th edition and prior, maybe 5th, but I forget]" Xenith and 44er Tabletop 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378503-rapidfire/#findComment-5942352 Share on other sites More sharing options...
