Deathwing Duck Posted May 4, 2023 Share Posted May 4, 2023 Does anyone know any bits companies/3d print designers that make marine pads with flat studs? Am thinking of the style seen on certain early Rogue Trader art and minis rather than the more rounded studs found on the current Mk.6 plastic kit. e.g. Poor old Brother Meredith: http://www.miniatures-workshop.com/lostminiswiki/index.php?title=Image:Citadel-RT101-99-04.jpg Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/ Share on other sites More sharing options...
Grotsmasha Posted May 5, 2023 Share Posted May 5, 2023 Honestly, you could achieve the look pretty easily by clipping the bulk of the rounded studs off a mkVI pad and giving them a once over with a fine grit sanding stick or nail file. Sea Creature 1 Back to top Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944018 Share on other sites More sharing options...
Deathwing Duck Posted May 5, 2023 Author Share Posted May 5, 2023 Yeah, was looking for a less fiddly labour intensive and more consistent option. Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944044 Share on other sites More sharing options...
MadGreek Posted May 6, 2023 Share Posted May 6, 2023 There are a lot of 3d creators on Shapeways that take commissions. I have had several items designed and made for me. Then you can either buy the printed items, or get the STL and print them yourself. Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944394 Share on other sites More sharing options...
Doghouse Posted May 6, 2023 Share Posted May 6, 2023 Are you looking for STLs or actual physical models? Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944530 Share on other sites More sharing options...
Doghouse Posted May 6, 2023 Share Posted May 6, 2023 (edited) Something like this? This is based on the plastic MK6 heresy one just with the bobbles chopped down. I can upload an stl you can get made if need be? Edited May 6, 2023 by Doghouse Deathwing Duck and Warden-Paints 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944535 Share on other sites More sharing options...
Deathwing Duck Posted May 8, 2023 Author Share Posted May 8, 2023 Oh thanks! Looks good. Maybe needs a little more height to the studs? Probably would need to see what looks like IRL on a model to judge. Link to comment https://bolterandchainsword.com/topic/378550-flat-studded-shoulder-pads/#findComment-5944950 Share on other sites More sharing options...
