Karhedron Posted May 5, 2023 Share Posted May 5, 2023 I normally varnish my models after painting to protect them. Normally I use either Testors dullcote or satin lacquer depending on the finish I am after. The problem is that both of these seem to kill the shine on metallic paints. I have just finished my new Dante and I would like to protect the paint finish but I don't want to dull the golden lustre. Does anyone have any advice for how to keep him shining? Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/ Share on other sites More sharing options...
Firedrake Cordova Posted May 5, 2023 Share Posted May 5, 2023 There's a few gloss varnishes out there - probably "the obvious one" is Vallejo Metal Colour varnish, which seems to get decent reviews. I've used Vallejo's gloss polyurethane varnish over their satin polyurethane varnish (to correct a mistake) without problems, too. Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/#findComment-5944109 Share on other sites More sharing options...
Grotsmasha Posted May 5, 2023 Share Posted May 5, 2023 I use GW's Munitorum Varnish spray, but when I really NEED something to keep it's shine, I go back over the spray with brush on 'Ard Coat form GW. Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/#findComment-5944185 Share on other sites More sharing options...
Borbarad Posted May 5, 2023 Share Posted May 5, 2023 For gold I use GW’s Storm Shield. It dulls the gold. But afterwards I apply little Mystic Gold (by Greenstuff World) to guve it the shine back. Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/#findComment-5944202 Share on other sites More sharing options...
Karhedron Posted May 6, 2023 Author Share Posted May 6, 2023 OK, so maybe some flavour of gloss varnish and then go over the non-metallic areas with a matt varnish to kill the shine is the way to go? Beaky Brigade 1 Back to top Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/#findComment-5944423 Share on other sites More sharing options...
Firedrake Cordova Posted May 6, 2023 Share Posted May 6, 2023 That sounds like a logical approach. It looks like there are some areas you could mask off with cling film (the axe, base) when spraying - don't know if that makes life any easier, as you could probably spray those? Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/378554-best-varnishes-for-metallics/#findComment-5944425 Share on other sites More sharing options...
