Captain Idaho Posted May 27, 2023 Share Posted May 27, 2023 I noticed some people have said they use a gloss coat followed by some sort of matte layer on top? I didn't know that was a thing! So how does that differ from a straight matte coat? I utilised a gloss to protect on my Custodes and they shined too much, so what would you guys suggest in that case? Bloody Legionnaire 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951664 Share on other sites More sharing options...
Lysimachus Posted May 27, 2023 Share Posted May 27, 2023 (edited) 33 minutes ago, Captain Idaho said: I noticed some people have said they use a gloss coat followed by some sort of matte layer on top? I didn't know that was a thing! So how does that differ from a straight matte coat? I utilised a gloss to protect on my Custodes and they shined too much, so what would you guys suggest in that case? This is what I usually do. A gloss coat is much harder wearing, better protection, but as you say the shine can look awful. So you put a coat of matte varnish over the top to take the shine away (though I have sometimes been more selective with where I add the matte, leaving it off on areas that I want the shine - power weapons or metallic areas?) Best of both worlds! Edit: I did once buy a can of spray varnish, but I've always been too cowardly to try using it, much prefer brushing it on for more control! The matte can sometimes still dry a bit white, but I've found if you give the bottle a really good shake and put it in a shallow bowl of warm water while you're using it, that issue happens a lot less! Edited May 27, 2023 by Lysimachus phandaal, Captain Idaho and Mithrilforge 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951667 Share on other sites More sharing options...
Captain Idaho Posted May 27, 2023 Share Posted May 27, 2023 I'll try this! Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951669 Share on other sites More sharing options...
Firedrake Cordova Posted May 27, 2023 Share Posted May 27, 2023 52 minutes ago, Lysimachus said: This is what I usually do. A gloss coat is much harder wearing, better protection This very much used to be the case, although Vallejo state with their polyurethane varnishes (including the Mecha line) this is no longer the case. Mithrilforge and Arkhanist 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951675 Share on other sites More sharing options...
Aramis K Posted May 28, 2023 Share Posted May 28, 2023 On 5/27/2023 at 9:48 AM, Captain Idaho said: I noticed some people have said they use a gloss coat followed by some sort of matte layer on top? I didn't know that was a thing! So how does that differ from a straight matte coat? I utilised a gloss to protect on my Custodes and they shined too much, so what would you guys suggest in that case? Lahmin medium is nice and easy to brush on for taking the shine off, and the level of matte matches usual unvarnished GW paint finish. Magic juice. You'll need to experiment over gold though, as all the varnishes will change the metallic effect. Firedrake Cordova and Captain Idaho 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951888 Share on other sites More sharing options...
Arkhanist Posted May 28, 2023 Share Posted May 28, 2023 (edited) On 5/27/2023 at 10:14 AM, Firedrake Cordova said: This very much used to be the case, although Vallejo state with their polyurethane varnishes (including the Mecha line) this is no longer the case. It's usually the chemical type of varnish that matters, rather than the finish. Matt varnish of the same type in the same line is just the gloss varnish plus matting agent. The toughest type is lacquer or enamel (oil based varnishes), then polyurethane, then acrylic is the weakest. Way back in the day, your choice was basically gloss lacquer furniture varnish, or modelling acrylic varnishes - and metal models were much more prone to chipping in particular. Hence it made a lot of sense to use a tough gloss lacquer coat for strength, and an acrylic matt for finish. These days, if you're already using say, testors dullcote spray - which is a lacquer - or both gloss and matt vallejo polyurethane, then you're not gaining mechanically from a gloss coat first, but obviously that old modelling knowledge - gloss then matt - persists. THAT said, some people prefer the final effect of a thin gloss coat then a thin matt coat, rather than 2 thin matt, as it probably will be a bit more satiny. And you're only risking frosting in the 2nd layer. Or you can use a semi-matt or satin varnish - I do this for marines, for example, but prefer matt for more organic models. As the old saw goes, the customer is always right in matters of taste! I guess the equivalent of gloss-then-matt these days would be a gloss polyurethane or lacquer varnish, then a layer of lahmian medium painted on - protection from the varnish layer, but should be very similar finish to raw paint and no risk of frosting. I may give this a go to see how it compares! Edited May 28, 2023 by Arkhanist Firedrake Cordova, Oxydo, Karhedron and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951894 Share on other sites More sharing options...
Special Officer Doofy Posted May 28, 2023 Share Posted May 28, 2023 I use varnish. Worth it if you travel with and handle your miniatures (no point if they just sit on a shelf). I did accidentally "frost" one miniature. Like with new paints or painting style, practice on something less important first! Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951899 Share on other sites More sharing options...
crimsondave Posted May 28, 2023 Share Posted May 28, 2023 I usually do. Always Testors dullcote simply because that’s what I started with. Mithrilforge and Karhedron 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951910 Share on other sites More sharing options...
phandaal Posted May 28, 2023 Share Posted May 28, 2023 Another benefit I have heard for gloss then matte is it gives the matte a smooth surface to settle on. This prevents frosting by getting rid of any kind of porous surface that excess matte can settle into. Conceptually, it makes sense, but I am not sure that is the actual mechanism that causes frosting. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951912 Share on other sites More sharing options...
Gederas Posted May 28, 2023 Share Posted May 28, 2023 Always varnish gaming pieces. I normally do Munitorum Varnish (satin) then Vallejo Matte, but that's because I don't really have easy access to Testor's Dullcote without going to Hobby Lobby Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951914 Share on other sites More sharing options...
bigtrouble Posted May 28, 2023 Share Posted May 28, 2023 (edited) I varnish for protection so I can play with them without rubbing paint off. Edit: I use 2 coats of satin spray varnish. Edited May 28, 2023 by bigtrouble Firedrake Cordova, Mithrilforge and phandaal 3 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5951969 Share on other sites More sharing options...
Bilskirnir3124 Posted June 25, 2023 Share Posted June 25, 2023 I always varnish, usually with a matte but sometimes satin, mostly Vallejo's. This is mostly down to getting into model building with Gundam models. Those have tons of decals and stickers, and the adhesive doesn't really care for the plastic so much so you need to gloss coat the model, then apply stickers and decals, then matte or satin coat the models to seal the decals after. It's a habit that carried into building every other model I've ever made. I've only had one case of frosting luckily. And it was from an old, second hand can of matte coat at that. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5965153 Share on other sites More sharing options...
Corswain Posted June 25, 2023 Share Posted June 25, 2023 I have used gloss on some of my metallic figures before but it makes non-metallic details like leafher or cloth look weird so I now just use matte varnish. Some models use a combo depending on the effect I'm going for. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5965183 Share on other sites More sharing options...
Bloody Legionnaire Posted June 25, 2023 Share Posted June 25, 2023 Every single model. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5965222 Share on other sites More sharing options...
KenaiPhoneix Posted June 26, 2023 Share Posted June 26, 2023 I should, but to be honest I sill have hope that I will go the extra mile and star getting better at painting minis. I like a more "grim" and realistic touch by no adding anything after the shade, but I know there is a lot of room from improvement Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5965248 Share on other sites More sharing options...
Matcap86 Posted July 14, 2023 Share Posted July 14, 2023 I don't varnish as a finish, due to disliking the effect it gives on my painting style. (messes with transitions and tends to change the look of some colours) I do use varnish when using oil paints and decals to make sure they have a smooth surface to settle on and then tone it down with matte varnish. In gaming I tend to grab my models by their bases so usually no rubbing off of paint. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5971676 Share on other sites More sharing options...
Bloody Legionnaire Posted July 16, 2023 Share Posted July 16, 2023 On 5/27/2023 at 3:48 AM, Captain Idaho said: I noticed some people have said they use a gloss coat followed by some sort of matte layer on top? I didn't know that was a thing! So how does that differ from a straight matte coat? I utilised a gloss to protect on my Custodes and they shined too much, so what would you guys suggest in that case? A gloss coat aids in the application of decals because it provides a smooth surface that makes it easier to adjust the decal and get it in the desired position. On 5/27/2023 at 4:21 AM, Lysimachus said: This is what I usually do. A gloss coat is much harder wearing, better protection, but as you say the shine can look awful. So you put a coat of matte varnish over the top to take the shine away (though I have sometimes been more selective with where I add the matte, leaving it off on areas that I want the shine - power weapons or metallic areas?) Best of both worlds! Edit: I did once buy a can of spray varnish, but I've always been too cowardly to try using it, much prefer brushing it on for more control! The matte can sometimes still dry a bit white, but I've found if you give the bottle a really good shake and put it in a shallow bowl of warm water while you're using it, that issue happens a lot less! Ehrm, not necessarily. Layers of paint are layers of paint are layers of paint. I believe the practice is more done because of the decal application process than anything else. That being said, I'm guessing multiple layers of gloss followed by 1-2 layers of semi-gloss or matte/flat has a better appearance than say 6 coats of matte/flat would produce. If you put 4 layers of gloss down followed by 1-2 layers of matte/flat then you have 6 additional layers of paint protecting the actual paint finish underneath. I'm fairly positive that a gloss layer of a acrylic offers the same level of protection a matter layer of acrylic offers. True durability is going to depend on the type of paint used. Lacquer being one of the hardest ones. Before anyone asks, yes.. it is okay to use lacquer on top of your acrylic paint as long as it is fully dry. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5972152 Share on other sites More sharing options...
Brother Carpenter Posted August 7, 2023 Share Posted August 7, 2023 I usually varnish my models. I start with gloss for better decal adhesion and lesser silver transfer effect. Then seal any decals with a new gloss layer and finally a matte layer. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5979699 Share on other sites More sharing options...
lhg033 Posted August 8, 2023 Share Posted August 8, 2023 +1 for bad experiences with spray varnishes. 100% my fault for not understanding/paying attention to what I was doing well enough but it has still put me off these. I varnish all models painted with contrast paints, by hand these days using a Vallejo varnishes. Just storing the models in a foam tray is enough to rub off / damage the finish for contrast paints. I havent really done anything with layer paints in a while but I hadnt previously varnished these and they've generally stood the test of time. andes and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5979784 Share on other sites More sharing options...
Guest Posted August 8, 2023 Share Posted August 8, 2023 Gloss then Matte for me... (Airbrush) Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5979853 Share on other sites More sharing options...
nilsh Posted August 8, 2023 Share Posted August 8, 2023 Usually I varnish, what kind depends on the miniature and always by brush as I don't have a place to spray. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5979856 Share on other sites More sharing options...
StratoKhan Posted August 10, 2023 Share Posted August 10, 2023 I've found that repeated handling can rub paint off of plastic miniatures, especially on the pointed parts of a model, or on a model's edges. So yes, I do varnish. I've been experimenting with oils and generally you varnish mid-paintjob to use the oils. I find that a coat of gloss followed by a coat of matt varnish is a good final protective combo, regardless of the painting process. for smaller details or assemblies, I sometimes brush the varnish, just try not to clog up the details with too much varnish. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5980287 Share on other sites More sharing options...
Shovellovin Posted August 11, 2023 Share Posted August 11, 2023 In the past, I used rattlecans and had some issues with matt varnish. If you ever get a frosted matt look on a model you can try to shake the rattle can vigorously and then spray the model again. I found that solved the issue for me. Now I tend to use Vallejo's satin and matt varnishes through my airbrush. Some areas of the model, such as a marine's eye lenses I will brush on gloss varnish. When I use oils I spray Pledge floor polish on the model so that the paint will flow better. I varnish all of my models. Like some others have discussed, I use varnish to get a uniform finish on my models as some paints tend to be more glossy or matt than others. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5980560 Share on other sites More sharing options...
Sir Clausel Posted August 11, 2023 Share Posted August 11, 2023 I always varnish. I have always used spray cans for varnish and have had very very few problems. Always sprayed outside. Right now i use munitorium varnish from GW and i like the satin look it gives but have recently started brushing on matt varnish after on the cloth and base and it really makes a nice difference. Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5980568 Share on other sites More sharing options...
Imren Posted August 16, 2023 Share Posted August 16, 2023 YES! Do you go to events/tournaments? Do you play friendly games with your mates over beer and pretzels? Then you ought to varnish to protect your minis from greasy and drunk fingers. Best way is to airbrush vallejo polyurethane varnish in two coats with 24h in between so that the first coat get to cure before the second one. You can mix and match between matt and gloss to get either matt or gloss or satin and everything in between. I varnish my 30k Alpha legion and Iron hands with 3:1 ratio between gloss and matt VAllejo polyurethane varnish so that the metallic armour panels doesnt get dulled down and the metallic effect diminish. With airbrush you get far better control and easier to prevent frosting compared to spray cans and also you get a more even and thin coat compared to brushing it on. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/378692-do-you-varnish-your-miniatures/page/2/#findComment-5981529 Share on other sites More sharing options...
