Inquisitor_Lensoven Posted June 3, 2023 Share Posted June 3, 2023 In the last few months I have played a lot of games against people who had models that had a 2+ for WS BS Sv and either from CP reroll or an ability, they’d get a reroll. it bothers me how OP that is and I feel the same way about my own captains as well. rerolling a 2+ should result in a -1 modifier to the reroll or 40k needs to switch to a more granular d10/12 system. d12 you could scale almost perfectly if you wanted the exact same relative effectiveness, but you could also make SoB slightly better than guardsmen without them being much better for example, but custodes could have a 3+ Sv and a reroll, but this way the reroll isn’t basically a guarantee success. Emperor Ming, tzeentch9, Oxydo and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/ Share on other sites More sharing options...
ThePenitentOne Posted June 3, 2023 Share Posted June 3, 2023 That might change now that people only get 1 CP/ turn. It certainly isn't something that will be used indiscriminately; is it worth it to save your warlord? Probably. To kill you opponent's Warlord? Probably. But other than that, it's a real opportunity cost. You can use two 1CP strats/ round or one 2CP strat. Foregoing any of that to reroll a single die... In a lot of cases, Command Reroll feels like a trap strat to me. You want an outcome so badly that you cave in and burn the CP, and then you're stuck without the ability to do cool, fun, cinematic stuff. Oxydo and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5954497 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 3, 2023 Author Share Posted June 3, 2023 12 minutes ago, ThePenitentOne said: That might change now that people only get 1 CP/ turn. It certainly isn't something that will be used indiscriminately; is it worth it to save your warlord? Probably. To kill you opponent's Warlord? Probably. But other than that, it's a real opportunity cost. You can use two 1CP strats/ round or one 2CP strat. Foregoing any of that to reroll a single die... In a lot of cases, Command Reroll feels like a trap strat to me. You want an outcome so badly that you cave in and burn the CP, and then you're stuck without the ability to do cool, fun, cinematic stuff. CP doesn’t effect character aura rerolls can’t remember how many of those we’ve seen in the previews so far. Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5954506 Share on other sites More sharing options...
ThePenitentOne Posted June 3, 2023 Share Posted June 3, 2023 Ah, right. My bad. Forgot about those lol. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5954514 Share on other sites More sharing options...
Trickstick Posted June 4, 2023 Share Posted June 4, 2023 Guard artillery can pretty easily hit on 2+ with rerolls, even indirectly. 4+ to hit, +1 to roll for Heavy, +1 to bs for order, scout sentinel within 18" and los of target gives reroll 1s and ignore indirect malus. Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955221 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 5, 2023 Author Share Posted June 5, 2023 2 hours ago, Trickstick said: Guard artillery can pretty easily hit on 2+ with rerolls, even indirectly. 4+ to hit, +1 to roll for Heavy, +1 to bs for order, scout sentinel within 18" and los of target gives reroll 1s and ignore indirect malus. Ok? Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955246 Share on other sites More sharing options...
crimsondave Posted June 5, 2023 Share Posted June 5, 2023 1 hour ago, Inquisitor_Lensoven said: Ok? I think he was pointing out an aura reroll in 10th after you said you couldn’t remember from the previews. Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955261 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 5, 2023 Author Share Posted June 5, 2023 20 minutes ago, crimsondave said: I think he was pointing out an aura reroll in 10th after you said you couldn’t remember from the previews. Oh ok. Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955263 Share on other sites More sharing options...
Trickstick Posted June 5, 2023 Share Posted June 5, 2023 Oh I was mainly highlighting how 2+ with rerolls are available even without spending cp, and also providing an example of something that some people may consider OP. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955302 Share on other sites More sharing options...
Marshal Mittens Posted June 5, 2023 Share Posted June 5, 2023 Rerolls and generally +1 modifiers should probably go away. 2+ should only be for legendary characters, in my opinion. For many years and editions, a Space Marine or Space Elf shot at 3+, there were generally no rerolls, and generally no +1 to hit. 2+ is way to easy to get, and rerolls are way to easy to get. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955311 Share on other sites More sharing options...
Xenith Posted June 5, 2023 Share Posted June 5, 2023 (edited) Never mind overpowered, giving things WS 2+ and reroll 1's auras (I think Ghazkull and some slaanesh stuff) is just pointless. Just say that they automatically hit. The fun in 40k for me comes from the unforeseen events that dice rolls cause. If you give enough modifiers and rerolls to stuff to make events a foregone conclusion, it removes so much joy from the game. Anyway, I guess it's pretty moot as of 2 days ago when GW dropped the 10th ed rules for general use, and totally moot in 19 days. Edited June 7, 2023 by Xenith Marshal Mittens, Helias_Tancred and Kythnos 3 Back to top Link to comment https://bolterandchainsword.com/topic/378838-2-w-flat-rerolls-are-broken/#findComment-5955323 Share on other sites More sharing options...
