Karhedron Posted June 7, 2023 Share Posted June 7, 2023 Have we been given any indication of how Lethal Hits interacts with Devastating Wounds yet? Lethal Hits automatically wound on a to-Hit roll of 6. Devastating Wounds inflict MWs on a to-wound roll of a 6. So if you roll a 6 to-Hit, you normally skip the to-Wound roll. Does this mean that you miss out on the chance to inflict Mortal Wounds? Link to comment https://bolterandchainsword.com/topic/378879-10th-edition-lethal-hits-devastating-wounds/ Share on other sites More sharing options...
TrawlingCleaner Posted June 7, 2023 Share Posted June 7, 2023 Devastating Wounds needs Critical Wounds to occur: From the wording of Lethal Hits, I believe the Wounds caused by this ability are not Critical Wounds: Compared to Anti, explicitly triggering a Critical Wound on X+ which then triggers Devastating wounds: Basically Lethal Hits is post-nerf Votann Grudge tokens, you can't use them to trigger "6+ to wound" abilities Karhedron, Oxydo and Kallas 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/378879-10th-edition-lethal-hits-devastating-wounds/#findComment-5956253 Share on other sites More sharing options...
Karhedron Posted June 7, 2023 Author Share Posted June 7, 2023 Thanks. That explanation makes sense, I just wanted to make sure I had not missed something somewhere. Link to comment https://bolterandchainsword.com/topic/378879-10th-edition-lethal-hits-devastating-wounds/#findComment-5956255 Share on other sites More sharing options...
Xenith Posted June 8, 2023 Share Posted June 8, 2023 Yea, so a lethal hit is not an automatic 6 to wound, like with hail of doom. Link to comment https://bolterandchainsword.com/topic/378879-10th-edition-lethal-hits-devastating-wounds/#findComment-5956524 Share on other sites More sharing options...
