Karhedron Posted June 29, 2023 Share Posted June 29, 2023 The trouble is that MWs themselves are a solution to the fact that GW has real difficulty in making some armies as tough as they want them to be without making them unbeatable by factions that traditionally don't have access to large quantities of high AP weapons. MWs are intended as the great leveller. If all else fails, throw a bunch of Mortals at it. This problem is not new and dates all the way back to 3rd edition. Back when Marines had a fixed 3+ save, some melee armies (particularly Nids) struggled to take them down. The result was the Rending rule which allowed 6s to bypass armour, very much like MWs (although they still allowed invulnerable saves back then). GW keeps getting into an arms race with itself where rule X is too good so rule Y is introduced to trump it. Y is then too good so Z has to be introduced and then the cycle repeats. This is virtually inevitable but it is disappointing to see just how OP the initial crop of Xs are at the very beginning of the edition. 10th should have provided an opportunity for levelling but the wild discrepancies are rather surprising. Interrogator Stobz, Sea Creature, LSM and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966550 Share on other sites More sharing options...
LSM Posted June 29, 2023 Share Posted June 29, 2023 (edited) 2 hours ago, TrawlingCleaner said: ...I posted this when these were originally posted to the Leviathan thread and at risk of sounding like the Board's Doomsayer: I hope these rules never see the light of day. 10 Combis using the Melta profile do an average of about 36MW to Vehicles and about 15 to anything else with OoM at 12" (all of which is super easy with Droppods). This assumes that the Sternguard rules will be: Any number of models can each have their Sternguard bolt rifle replaced with a Sternguard combi-melta, a Sternguard combi-plasma, a Sternguard combi-flamer, or a Sternguard combi-grav. For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard heavy bolter or a Sternguard heavy flamer. Instead of: For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard combi-melta. For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard combi-plasma. For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard combi-flamer. For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard combi-grav. For every 5 models in this unit, 1 Sternguard Veteran’s Sternguard bolt rifle can be replaced with a Sternguard heavy bolter or a Sternguard heavy flamer. Edited June 29, 2023 by LSM Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966556 Share on other sites More sharing options...
Rain Posted June 29, 2023 Share Posted June 29, 2023 7 minutes ago, Karhedron said: The trouble is that MWs themselves are a solution to the fact that GW has real difficulty in making some armies as tough as they want them to be without making them unbeatable by factions that traditionally don't have access to large quantities of high AP weapons. MWs are intended as the great leveller. If all else fails, throw a bunch of Mortals at it. This problem is not new and dates all the way back to 3rd edition. Back when Marines had a fixed 3+ save, some melee armies (particularly Nids) struggled to take them down. The result was the Rending rule which allowed 6s to bypass armour, very much like MWs (although they still allowed invulnerable saves back then). GW keeps getting into an arms race with itself where rule X is too good so rule Y is introduced to trump it. Y is then too good so Z has to be introduced and then the cycle repeats. This is virtually inevitable but it is disappointing to see just how OP the initial crop of Xs are at the very beginning of the edition. 10th should have provided an opportunity for levelling but the wild discrepancies are rather surprising. Rending still allowed invulnerable saves. That's the key thing. Having a mechanic that ignores the saves of rank and file troops for "really killy" weapons is fine, it's having a mechanic that ignores the invulnerable saves of elite troops and characters which creates the issue. No weapon should require the same exact rolls to put a wound on a guardsman as on Guilliman. Also, Nids had lots of monstrous creatures, which all ignored regular armor saves by virtue of being monstrous creatures. Gaunts were a cheap horde unit, it made perfect sense that they'd have trouble killing marines, and that they functioned as tarpits, letting the bigger more specialized bugs do the killing. phandaal, Kallas, Scribe and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966557 Share on other sites More sharing options...
Karhedron Posted June 29, 2023 Share Posted June 29, 2023 9 minutes ago, Rain said: Also, Nids had lots of monstrous creatures, which all ignored regular armor saves by virtue of being monstrous creatures. Gaunts were a cheap horde unit, it made perfect sense that they'd have trouble killing marines, and that they functioned as tarpits, letting the bigger more specialized bugs do the killing. Back then they only had the Hive Tyrant and the Carnifex. There was the awkward middle ground of units like Stealers and Lictors who should have been far more deadly to Marines than they were prior to the introduction of rending. Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966560 Share on other sites More sharing options...
Squark Posted June 29, 2023 Share Posted June 29, 2023 Rending also didn't/doesn't bypass cover saves, which would be a problem bringing it back since certain units that would have used cover saves to mitigate it in shooting, but cover is now an armor avae modifier. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966561 Share on other sites More sharing options...
MoshJason Posted June 29, 2023 Share Posted June 29, 2023 Age of Sigmar has had Mortal Wounds since it came out, and 40k has had mortal wounds since 8th - I don't think they are going to get rid of them any time soon. There's an argument that MW are needed - as a way to speed up the game, and as a way to make some weapons as deadly as possible without having them be *too* deadly. IE - if something has Anti-Psyker 2+ and Devastating Wounds, it's supposed to be really bad news for Psykers, without having it have to have A) tons of bespoke rules, or B) Characteristics that make it more deadly vs the non-intended target. A condemnor boltgun has Str 4 Ap 0 D1 (Anti-Psyker, Devastating Wounds) so that it can effectively hurt it's intended target. If you just made it "Autowound on a 2+" then suddenly any psyker in the game has a reasonable chance to shrug it off, and you'd either need even more rules or to increase the AP, but if you increase the AP suddenly it's better at killing its non-intended targets. Blurf and jaxom 2 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966563 Share on other sites More sharing options...
Scribe Posted June 29, 2023 Share Posted June 29, 2023 I'm really not sure MW, and Devastating Wounds even worse, isnt a solution for a problem that doesnt really need to exist, especially in a system where the rules were being tweaked, and had a granular AP and Damage system in place. Just feels like a mistake, another artifact of Apocalypse that should never have made it into the core game. phandaal, Interrogator Stobz, LSM and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966566 Share on other sites More sharing options...
Focslain Posted June 29, 2023 Share Posted June 29, 2023 12 minutes ago, MoshJason said: Age of Sigmar has had Mortal Wounds since it came out, and 40k has had mortal wounds since 8th - I don't think they are going to get rid of them any time soon. There's an argument that MW are needed - as a way to speed up the game, and as a way to make some weapons as deadly as possible without having them be *too* deadly. IE - if something has Anti-Psyker 2+ and Devastating Wounds, it's supposed to be really bad news for Psykers, without having it have to have A) tons of bespoke rules, or B) Characteristics that make it more deadly vs the non-intended target. A condemnor boltgun has Str 4 Ap 0 D1 (Anti-Psyker, Devastating Wounds) so that it can effectively hurt it's intended target. If you just made it "Autowound on a 2+" then suddenly any psyker in the game has a reasonable chance to shrug it off, and you'd either need even more rules or to increase the AP, but if you increase the AP suddenly it's better at killing its non-intended targets. This is what I think the thinking behind the Sheildbreaker missiles and Thundercoil Harpoon are, their made to take on specific targets (other knights and large targets). While it can be super harmful to other targets that is only by chance. The more I see this the more I'm for just making FD a modified roll, would help in curtailing the deadliness. Plus they can always use that 6 on the damage roll for the d-cannons (or other weapons) making their natural devastating that much more without it being a guaranteed kill shot. Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966569 Share on other sites More sharing options...
Scribe Posted June 29, 2023 Share Posted June 29, 2023 21 minutes ago, MoshJason said: There's an argument that MW are needed - as a way to speed up the game, and as a way to make some weapons as deadly as possible without having them be *too* deadly. There's a couple of better ways to do this. I would refer GW to 5th edition, and lowering the 'matched play' points level, but well then how could they push more plastic? I think 10th is a serviceable platform, I really do. I think the index lists are a fine starting point. I believe someone in the wider community would need to release it in a polished state however, because GW is going to GW, and 9th happened for a reason. 10th will go the same way. Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966571 Share on other sites More sharing options...
spessmarine Posted June 29, 2023 Share Posted June 29, 2023 10 hours ago, Karhedron said: Yes but every list will look the same with Eldrad, maximum Wraithknights, D-Cannon and Fire Prisms and then whatever minimal infantry are necessary to hold Objectives and farm additional CPs and FDs. People saying the rules are half-baked may well be right. I met a friend on Saturday who knows someone in Nottingham and apparently the index lists have not been formally playtested. At all! GW allocated no paid time to playtesting. The only playtesting that happened was informal and conducted in lunch breaks and after-hours. Normally I would take such stories with a pinch of salt but looking at the power disparity in the Indices, I certainly find them plausible. Given that proofreading didn't seem to get much time, stands to reason playtesting suffered a similar fate. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966589 Share on other sites More sharing options...
Blurf Posted June 29, 2023 Share Posted June 29, 2023 3 hours ago, Rain said: Rending still allowed invulnerable saves. That's the key thing. Having a mechanic that ignores the saves of rank and file troops for "really killy" weapons is fine, it's having a mechanic that ignores the invulnerable saves of elite troops and characters which creates the issue. No weapon should require the same exact rolls to put a wound on a guardsman as on Guilliman. Also, Nids had lots of monstrous creatures, which all ignored regular armor saves by virtue of being monstrous creatures. Gaunts were a cheap horde unit, it made perfect sense that they'd have trouble killing marines, and that they functioned as tarpits, letting the bigger more specialized bugs do the killing. then they give a unit 2++ rerollable and we're back in 7th edition again. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966598 Share on other sites More sharing options...
Blurf Posted June 29, 2023 Share Posted June 29, 2023 3 hours ago, Focslain said: This is what I think the thinking behind the Sheildbreaker missiles and Thundercoil Harpoon are, their made to take on specific targets (other knights and large targets). While it can be super harmful to other targets that is only by chance. The more I see this the more I'm for just making FD a modified roll, would help in curtailing the deadliness. Plus they can always use that 6 on the damage roll for the d-cannons (or other weapons) making their natural devastating that much more without it being a guaranteed kill shot. 1. This still doesn't solve the problem of Fate Dice being WAY too strong. 2. Do you do the same to Miracle Dice? Because if so, Morvenn Vahl and Celestine need their data sheets rewritten. Interrogator Stobz and Emperor Ming 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966600 Share on other sites More sharing options...
Focslain Posted June 29, 2023 Share Posted June 29, 2023 28 minutes ago, Blurf said: 1. This still doesn't solve the problem of Fate Dice being WAY too strong. 2. Do you do the same to Miracle Dice? Because if so, Morvenn Vahl and Celestine need their data sheets rewritten. Considering the lack of access to Dev Wounding sisters have (it's only on the epic characters) I don't think it would change how Miracle Dice work. Both Morvann and Celestine as pretty cheap currently, so no real change there. Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966608 Share on other sites More sharing options...
Lexington Posted June 29, 2023 Share Posted June 29, 2023 2 hours ago, Blurf said: then they give a unit 2++ rerollable and we're back in 7th edition again. Funny enough, I’m pretty sure this is the exact edition-destroying that problem Mortal Wounds were introduced to solve, this introducing the new edition-destroying problem of…Mortal Wounds Kallas, Rain, Scribe and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966627 Share on other sites More sharing options...
Rain Posted June 29, 2023 Share Posted June 29, 2023 Is…not adding a 2+ rerollable invulnerable save to the game just off the table? Sergeant Bastone 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966631 Share on other sites More sharing options...
TheMawr Posted June 29, 2023 Share Posted June 29, 2023 (edited) 1 hour ago, Focslain said: Considering the lack of access to Dev Wounding sisters have (it's only on the epic characters) I don't think it would change how Miracle Dice work. Both Morvann and Celestine as pretty cheap currently, so no real change there. Morvenna vahl has it on melee Canoness has it on Condemntor boltgun Celestine has it on melee Battlesister squad sister superior can have it on Condemnor boltgun or Combi weapon Aestred thurga can give it on all melee weapons for one of these units (and her self I think) : Battle sisters, Celestians, Dominions, Retributor Dominion squad sister superior can have it on Condemnor boltgun or Combi weapon Retributor squad sister superior can have it on Condemnor boltgun or Combi weapon edit: Not meant smug, just pointing out something overlooked (or I misunderstand how it works.. also possible) , but I saw earlier in the threat the mention of only 3 models.. Its a bit annoying that the datasheets are so "complete" but then some things are on a seperate armory card. Edited June 29, 2023 by TheMawr Aarik 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966632 Share on other sites More sharing options...
Scribe Posted June 29, 2023 Share Posted June 29, 2023 30 minutes ago, Lexington said: Funny enough, I’m pretty sure this is the exact edition-destroying that problem Mortal Wounds were introduced to solve, this introducing the new edition-destroying problem of…Mortal Wounds Which is extra frustrating, that these issues still exist in some ways. There are fundamental problems with how GW approaches the game, if we look at the game as a competitive exercise, and the thing is none of it is an issue of 'cannot be solved'. GW clearly didnt apply enough time, effort, and thought, to 10th. They didnt manage it from either a timeline/release window perspective, and they 100% didnt manage it from an internal balance/development perspective. There are just too many issues, or inconsistencies. Now maybe its just copium on my part, as I really wanted to get back into 40K, I wanted the game to be great again and worth the time and $ invested, but when I look at most of 10th, its good, maybe even great, but there are just a few things here or there that need to be obliterated, or in some cases just tweaked even, and we could be in a great edition. I just dont think GW has the will or ability to get there. Kallas, Interrogator Stobz, Akerkoke and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966633 Share on other sites More sharing options...
Interrogator Stobz Posted June 29, 2023 Share Posted June 29, 2023 I feel, may be wrong ofc, but a large part of the problem for Sisters and other AT weapons is the nerf to Melta etc.. Surely it should have remained at a Str relative to the T of the Heavy Vehicles it is famous for wrecking. Tank killer guns don't need shenanigans like Anti and DevWnds and Mortals, they merely need high Str, AP and Damage. The KISS principle wouldn't have gone astray. Anti anything is a fools mechanic except for things like Psychic and other space magic attacks. mooftak and apologist 2 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966634 Share on other sites More sharing options...
Scribe Posted June 29, 2023 Share Posted June 29, 2023 27 minutes ago, Interrogator Stobz said: I feel, may be wrong ofc, but a large part of the problem for Sisters and other AT weapons is the nerf to Melta etc.. Surely it should have remained at a Str relative to the T of the Heavy Vehicles it is famous for wrecking. Tank killer guns don't need shenanigans like Anti and DevWnds and Mortals, they merely need high Str, AP and Damage. The KISS principle wouldn't have gone astray. Anti anything is a fools mechanic except for things like Psychic and other space magic attacks. I'm not sure on this, because it leads to an issue where the guns are great against Armour, and anything with higher than Human Toughness and Wounds. They clearly wanted to hit these types of 'catch all' answers like Melta/Plasma. Then they go and throw in "A 6 to wound always wounds." and ruin the concept... Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966643 Share on other sites More sharing options...
TheMawr Posted June 30, 2023 Share Posted June 30, 2023 5 hours ago, Rhavien said: Goonhammer just released one of their tournament analysis articles. Looking through it I can see Aeldari, Knights and Custodes being very prominent. Only two Astartes lists (Iron Hands, DA ) that placed within the top ranks. What do you guys think about those results? I'm really curious how the meta will shape in the close future. Quite the varied amount of data there..I made a listing of data in there thats a bit wider ( top 10s of each tournament, highest placing for each other army, NP is Not played.. as well as the amount of player playing the 4 purposed strong ones as well as their lowest rankings, however, Id have to say purposed.. as I included spacemarines there and they arent doing that great I think, despite having a strong power on paper.).. its quite a list so it has a spoiler tag Spoiler Boise 1. Imperial Knights 2. Necrons 3. Imperial Knights 4. Tau 5. Aeldari ( 3x Wraithknights ) 6. Custodes 7. Orks 8. Thousand Sons 9. Custodes 10. Admech Highest place per "other" army ( of 51 ) Spacemarines 13 ( Ultramarines ) Chaos Knights 15 Daemons 40 Genestealer cults 50 Drukhari - NP Leagues of Votann 34 Astra Militarum 18 Sisters of Battle - NP Tyranids 25 Chaos Space marines 38 Grey Knights 27 Deathguard 33 World Eaters - NP Imperial Agents - NP # Aeldari players 2 ( 1 in top 10, 1 in top half, lowest ranking : 32) # Spacemarine players 12 ( 0 in top 10, 6 in top half, lowest ranking : 51 (dark angels )) # Knight players 8 (2 in top 10, 7 in top half, lowest ranking : 29 (chaos knights)) # Custodes players 3 ( 2 in top 10, 2 in top half, lowest ranking : 28 ) Brittany Open 1. Aeldari ( 2x Wraithknight ) 2. Imperial Knights 3. Genestealer cults 4. Aeldari ( 1x Wraithknight ) 5. Custodes 6. Astra Militarum 7. Aeldari 8. Spacemarines ( Deathwatch ) 9. Genestealer cults 10. Chaos Knights Highest place per "other" army ( of 48 ) Admech 48 Drukhari 24 Leagues of Votann 43 Thousand sons 23 Tau 32 Necrons 34 Daemons 15 Orks 20 Sisters of Battle 22 Tyranids 13 Chaos Space marines 29 Grey Knights 33 Deathguard -NP World Eaters - NP Imperial Agents -NP # Aeldari players 9 (3 in top 10, 6 in top half, lowest ranking : 39 ) # Spacemarine players 6 ( 1 in top 10, 3 in top half, lowest ranking : 47 (Blood angels )) # Knight players 4 ( 2 in top 10, 3 in top half, lowest ranking : 45 (imperial )) # Custodes players 4 ( 1 in top 10, 1 in top half, lowest ranking : 31 ) Hellstroms All-Star heat 3 1. Imperial Knights 2. Drukhari 3. Chaos Knights 4. Thousand sons 5. Spacemarines 6. Aeldari (1x Wraithknight ) 7. Daemons 8. Custodes 9. Spacemarines ( Dark angels ) 10. Leagues of Votann Highest place per "other" army ( out of 40 ) Orks - NP Astra Militarum 23 Admech 25 Tau - NP Necrons 12 Genestealer cults - NP Sisters of Battle - NP Tyranids 13 Chaos Space marines 17 Grey Knights 21 Deathguard - NP World Eaters - NP Imperial agents - NP # Aeldari players 4 ( 1 in top 10, 3 in top half, lowest ranking : 27 ) # Spacemarine players 6 ( 1 in top 10, 2 in top half, lowest ranking : 38 (Blood angels )) # Knight players 3 ( 2 in top 10, 3 in top half, lowest ranking : 20 (Imperial )) # Custodes players 3 ( 1 in top 10, 2 in top half, lowest ranking : 39 ) SIMP 1. Aeldari 2. Aeldari 3. Spacemarines ( Dark angels ) 4. Imperial Knights 5. Thousand Sons 6. Aeldari 7. Aeldari 8. Spacemarines 9. Daemons 10. Daemons Highest place per "other" army ( out of 28 ) Orks 18 Admech 16 Necrons 22 Astra Militarum 26 Chaos Knights - NP Genestealer cults - NP Drukhari - NP Leagues of Votann - NP Tau - NP Sisters of Battle -NP Tyranids - NP Chaos Space marines 14 Grey Knights -NP Deathguard 27 World Eaters - NP Imperial agents - 28 # Aeldari players 4 ( 4 in top 10, 4 in top half, lowest ranking : 7 ) # Spacemarine players 4 ( 2 in top 10, 2 in top half, lowest ranking : 21 (Blood angels)) # Knight players 4 ( 1 in top 10, 4 in top half, lowest ranking : 13 (Imperial )) # Custodes players 1 ( 0 in top 10, 0 in top half, lowest ranking : 20 ) I must say.. the upper 3 tournaments show a much more varied result than SIMP does wich does show comparable results to stuff like AoW, but also comes from a similar limited pool of diversity in the armies played. It makes me feel the rock-paper-scissor theory might be more true than I initially thought.. and GSC just might be a scissor. ( wich in itself is a terrible way to design balance in your game btw.) Knights of all flavor (incl wraith) still dominate but there is more variety in the top 10s there. Among 4 tournaments only 1 player played sisters of battle, and no one played Worldeaters, making these hard to judge... Deathguard got more play and with it more losses ( I think it was 3 players all of wich placing in the bottom half.) Aarik 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966658 Share on other sites More sharing options...
Rain Posted June 30, 2023 Share Posted June 30, 2023 3 hours ago, Scribe said: Which is extra frustrating, that these issues still exist in some ways. There are fundamental problems with how GW approaches the game, if we look at the game as a competitive exercise, and the thing is none of it is an issue of 'cannot be solved'. GW clearly didnt apply enough time, effort, and thought, to 10th. They didnt manage it from either a timeline/release window perspective, and they 100% didnt manage it from an internal balance/development perspective. There are just too many issues, or inconsistencies. Now maybe its just copium on my part, as I really wanted to get back into 40K, I wanted the game to be great again and worth the time and $ invested, but when I look at most of 10th, its good, maybe even great, but there are just a few things here or there that need to be obliterated, or in some cases just tweaked even, and we could be in a great edition. I just dont think GW has the will or ability to get there. The core rules are great, and the internal balance of many indices seems good. GW’s decision to give each unit a special rule has been a major glowup to previously pointless units brought solely for flavor like the CSM and WE Helbrute, the Vortex Beast, etc. The problem is that the balance between indices is so broken that the game is borderline unplayable for some matchups. Helycon, Kallas, jaxom and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966660 Share on other sites More sharing options...
Scribe Posted June 30, 2023 Share Posted June 30, 2023 18 minutes ago, Rain said: The core rules are great, and the internal balance of many indices seems good. GW’s decision to give each unit a special rule has been a major glowup to previously pointless units brought solely for flavor like the CSM and WE Helbrute, the Vortex Beast, etc. The problem is that the balance between indices is so broken that the game is borderline unplayable for some matchups. For the most part I agree. I do think that always wounds on a 6 and MW/Dev Wounds are flawed, but otherwise yeah. I'm certainly more interested in the game than I have been in many years. Akerkoke 1 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966661 Share on other sites More sharing options...
Interrogator Stobz Posted June 30, 2023 Share Posted June 30, 2023 6 hours ago, Scribe said: I'm not sure on this, because it leads to an issue where the guns are great against Armour, and anything with higher than Human Toughness and Wounds. They clearly wanted to hit these types of 'catch all' answers like Melta/Plasma. Then they go and throw in "A 6 to wound always wounds." and ruin the concept... I have no issue with something that can wreck a tank also wrecking a massive bug. But a skilful difference in saves, invulnerable saves and wounds can go a long way to providing the difference between them. No need for all these special rules. Aarik, phandaal, Captain Idaho and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966677 Share on other sites More sharing options...
Akerkoke Posted June 30, 2023 Share Posted June 30, 2023 3 hours ago, Scribe said: For the most part I agree. I do think that always wounds on a 6 and MW/Dev Wounds are flawed, but otherwise yeah. I'm certainly more interested in the game than I have been in many years. I returned to the game after a long stop, hyped for 10th edition, luckily I'll be only playing crusade with my friends and combat patrols so I should be relatively fine. However as a player that played tournaments back in the day, the thought process of balance/imbalace/extreme imbalance is always there and these concerns are being given form in this edition unfortunately Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966678 Share on other sites More sharing options...
MoshJason Posted June 30, 2023 Share Posted June 30, 2023 4 hours ago, Interrogator Stobz said: I have no issue with something that can wreck a tank also wrecking a massive bug. But a skilful difference in saves, invulnerable saves and wounds can go a long way to providing the difference between them. No need for all these special rules. This is how we ended up with Plasma being the only weapon type anyone (who had access to it) would bring. It had Long (enough) range High (enough) STR high (enough) AP and dealt a reliable 2 damage, while firing 2 shots, with access to enough rerolls to prevent rolling ones. It was equally good at killing big stuff, small stuff, medium stuff and any other stuff you could think of. Sure, Melta might have been arguably better in a few fringe cases, but Plasma worked wonders against Marines and other infantry, so there was no opportunity cost. But if GW very specifically goes "THIS WOUNDS VEHICLES ON A 2+" instead of "THIS IS STR 1000", it silos the weapons a little more. It's a solution that we used to have in 7th with Armorbane and Fleshbane. Honestly, I'm not sure why everyone is complaining now, since MW are not a new concept having existed since 2017 in 40k - and having played (and played against) Grey Knights and Thousand Sons its not like MW are particularly more prevalent - it's just changed which datasheets have access to them. Arbedark and Cactus 2 Back to top Link to comment https://bolterandchainsword.com/topic/379275-10th-edition-tournament-results-it-doesnt-look-good/page/6/#findComment-5966732 Share on other sites More sharing options...
