Markov Gheist Posted June 29, 2023 Share Posted June 29, 2023 So Eliminators get [Devastating Wounds] when they have remained stationary, but their Sgt with instigator bolt rifle lets them move after shooting. Remain Stationary refers specifically to the movement phase, so do Eliminators count as having remained stationary even after they used their special movement rule? Link to comment https://bolterandchainsword.com/topic/379324-eliminators-special-rule/ Share on other sites More sharing options...
Solution Dr_Ruminahui Posted June 29, 2023 Solution Share Posted June 29, 2023 (edited) Yes, Remains Stationary is particular type of (non) movement, so if do it in the movement phase, you get the benefit until the start of your next movement phase. Oddly, with it worded the way it is, it would seem to still applies even if something else happens later that either moves the model (like its special rule) or makes it count as moving (for example, having a transport blown out from under them). Even if this weren't the case, I would have a hard time accepting that you count as having moved when you haven't moved yet. Edited June 29, 2023 by Dr_Ruminahui TrawlingCleaner and Markov Gheist 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379324-eliminators-special-rule/#findComment-5966641 Share on other sites More sharing options...
