Luciant Posted June 29, 2023 Share Posted June 29, 2023 (edited) I have been trying to find the answer to this and have been unsuccessful. Any help you can provide is appreciated. Question Can you bring back a terminator with an apothecary if the unit was selected for teleport assault, since you are not on the board in the command phase? Where can I find the answer to this question? I have heard it was covered in the Rules Commentary but I'm struggling to find it or maybe just struggling to understand. This is what I found in the Rules Commentary. Pg. 11 REPOSITIONED UNITS Some rules enable units to be repositioned by removing them from the battlefield then setting them back up on the battlefield. In such cases, the following points apply: 1. If used in the Movement phase, such rules can be used on units that arrived as Reinforcements this phase, and can be used on units that have already been selected to move this phase. 2. Rules that are triggered by or apply to Reserves units or units that are ‘set up on the battlefield as Reinforcements’ are also triggered by and apply to a repositioned unit when it is set back up. 3. A repositioned unit counts as having made a Normal move in the phase in which it is set back up. 4. If a repositioned unit is Below Half-strength and it was not on the battlefield during your Command phase, it must take a Battle-shock test as if it were your Command phase after it has been set back up. 5. If a unit is below its Starting Strength when it is removed from the battlefield to be repositioned, destroyed models are not returned to that unit when it is set back up. Likewise, wounded models in that unit do not regain any lost wounds when they are set back up. 6. When a unit is removed from the battlefield to be repositioned, any rules affecting it for a specified duration or under specified circumstances continue to affect it while that duration/those circumstances apply. For example, a unit that was within range of an Aura ability when it was removed would no longer be affected by that Aura ability if it is set back up beyond that Aura ability’s range, whereas a unit that was Battle-shocked when it was removed would still be Battle-shocked until the start of your next Command phase. Edited June 29, 2023 by Luciant Link to comment Share on other sites More sharing options...
Kallas Posted June 30, 2023 Share Posted June 30, 2023 Page 11 of the Designer's Commentary: "Units can still use rules and abilities while in Reserves." Spoiler Helias_Tancred 1 Back to top Link to comment Share on other sites More sharing options...
Luciant Posted June 30, 2023 Author Share Posted June 30, 2023 Thank you. Really appreciate your time on this. Kallas 1 Back to top Link to comment Share on other sites More sharing options...
