tagsta Posted July 3, 2023 Share Posted July 3, 2023 (edited) Hi guys, here is a 2.5k AL HH List for your feedback: Thanks in advance Questions: - Unsure about the ROW - any recommendations? - Would you rate this list very competitive? I am looking for a balanced list overall. - Is it correct that the Scorpius Squadron costs 15 points and each Scorpius 105? Here is the plan: - Most units infiltrate and disrupts opponent's plans - Saboteurs try to blow things up and cause mayhem - I understand that Dynat allows me to infiltrate 3 Units, so he would join the stolen Fulmentarus and Infiltrate 2x Tactical Squads including MM Rhinos. - Effrit will infiltrate, pick a target then shotgun and shank. - Recon Squads will infiltrate, provide support fire, cause pinning - Proteus Land Speeders Go Outflank and Tank Hunting - Deredeo & Normal Dread will walk around and hunt infrantry - Scorpius & Sicaran Arcus provide fire support Options: - I have a spare rhino with MM, I could replace Effrit and instead use them as a 10x man Recon Squad with Shotguns in a MM Rhino to have another Line/Scoring Unit. - I could swap the turret of the Sicaran for the normal and plasma version What could be better: - Melta on Dreadnought instead of second Fist - Lascannon on Deredeo - More Line Units? I have 30 bodies - 2x Tacs and 2x Recon that can hold objectives Alpha Legion - 2.5k Legiones Astartes 2.495 HQ --- 1x Armillus Dynat 185 Rite of War 1x Saboteur 85 magna combi-weapon (melta) 1x Saboteur 85 magna combi-weapon (melta) TROOPS ---- 10x Tactical Squad 100 Tactical Sergeant, 9 Tactical Space Marines • 1x Rhino 65 pintle-mounted multi-melta 10x Tactical Squad 110 Tactical Sergeant (power sword), 9 Tactical Space Marines • 1x Rhino 65 pintle-mounted multi-melta 5x Reconnaissance Squad 135 Reconnaissance Sergeant (Nemesis bolter), 4 Reconnaissance Marines, 4× Nemesis bolter 5x Reconnaissance Squad 135 Reconnaissance Sergeant (Nemesis bolter), 4 Reconnaissance Marines, 4× Nemesis bolter ELITES ---- 1x Contemptor Dreadnought Talon • Contemptor Dreadnought 195 2× Gravis power fist (plasma blaster) 10x Effrit Disruption Cadre 280 Effrit Principal (power dagger), 9 Effrit Disruptors, power daggers 5x Fulmentarus Terminator Squad 315 Fulmentarus Decurion (power fist), 4 Fulmentarus Terminators, 4× power fist FAST ATTACK --- 1x Proteus Land Speeder Squadron • 1x Land Speeder 95 pintle-mounted multi-melta, hull-mounted graviton gun • 1x Land Speeder 95 pintle-mounted multi-melta, hull-mounted graviton gun HEAVY SUPPORT --- 1x Scorpius Squadron 15 • 1x Scorpius Tank 105 1x Deredeo Dreadnought Talon • 1x Deredeo Pattern Dreadnought 205 volkite falconet 1x Sicaran Arcus Squadron 15 • 1x Sicaran Arcus Strike Tank 210 two sponson-mounted lascannons Edited July 3, 2023 by tagsta Link to comment Share on other sites More sharing options...
Unknown Legionnaire Posted July 3, 2023 Share Posted July 3, 2023 - The first Scorpius in a Squadron (of up to 2 tanks) costs 120 pts. The second tank clocks in at an additional 105 pts. - Armillus Dynat can bestow Infiltrate on up to 3 infantry units. Infiltrate does not transfer to or from independent characters. So, if you want him to infiltrate alongside a unit, he needs to be one of the three selections. See the rules on infiltrate and independent characters. - Three line units in a 2.500 pts. list might not be enough, depending on the parameters of the mission you'll find yourself playing, but four units should work (if the tiny 5-man recon squads survive indeed). - Consider running PotL for your RoW, with Dynat bestowing infiltrate upon himself and two units of Veterans (which will be your compulsory troop choices). Link to comment Share on other sites More sharing options...
tagsta Posted July 4, 2023 Author Share Posted July 4, 2023 (edited) 13 hours ago, Unknown Legionnaire said: - The first Scorpius in a Squadron (of up to 2 tanks) costs 120 pts. The second tank clocks in at an additional 105 pts. - Armillus Dynat can bestow Infiltrate on up to 3 infantry units. Infiltrate does not transfer to or from independent characters. So, if you want him to infiltrate alongside a unit, he needs to be one of the three selections. See the rules on infiltrate and independent characters. - Three line units in a 2.500 pts. list might not be enough, depending on the parameters of the mission you'll find yourself playing, but four units should work (if the tiny 5-man recon squads survive indeed). - Consider running PotL for your RoW, with Dynat bestowing infiltrate upon himself and two units of Veterans (which will be your compulsory troop choices). Great feedback mate - Hydra Dominatus! Well, I think Veterans are typically better to be CCW equipped and I don't have units for this. But maybe I will stack up on some Terminators or Lerneans and run POTL. I reckon I switch up the Effrit Squad to a Recon Squad with Shotguns and Rhino with MM that can also infiltrate and hold objectives etc. that way I have 5x scoring units and 40 bodies at least until I have maybe amended the list a bit. I could also turn the sniper recon squads into a 10-Man Unit to save some points Edited July 4, 2023 by tagsta Link to comment Share on other sites More sharing options...
Brother Sutek Posted July 6, 2023 Share Posted July 6, 2023 I like to give my saboteur lightning claws so they can protect themselves while they are in enemy territory. Link to comment Share on other sites More sharing options...
LameBeard Posted July 14, 2023 Share Posted July 14, 2023 This list reads like you’ve ticked all the boxes for the really effective stuff in 2.0: lascannons, snipers pinning, Fulmentarus, contemptor, arcus … So if it has a weak spot, it is presumably being overrun by a horde of chainaxe wielding loonies. So my question is, do you actually *want* to infiltrate? That just means getting closer to the enemy. And don’t feel you need a Rite of War, it’s very respectable to do without one. I personally am looking forward to trying the Mobius Configuration, which seems to me like a Rite of War masquerading as a Warlord Trait. But perhaps it could work here - a sacrificial speed bump? Not sure what you’d drop to make room for the allies though. Link to comment Share on other sites More sharing options...
