apologist Posted July 4, 2023 Share Posted July 4, 2023 (edited) Hi all, I'm working on a new project themed around the Battle for Armageddon (the second war; the first against Waa-Ghazghkull), and would like to the models' bases to evoke the sandy desert of the period. The paints have changed quite a bit, so do you have any suggestions for getting something like this using the modern GW (or other) colours? Edited July 4, 2023 by apologist Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/ Share on other sites More sharing options...
Solution Azaiel Posted July 4, 2023 Solution Share Posted July 4, 2023 My suggestion would be Mournfang brown base and then a heavy Zamesi Desert drybrush and Ushabti Bone drybrush. sarabando, Grotsmasha and apologist 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5968341 Share on other sites More sharing options...
sarabando Posted July 4, 2023 Share Posted July 4, 2023 2 hours ago, Azaiel said: My suggestion would be Mournfang brown base and then a heavy Zamesi Desert drybrush and Ushabti Bone drybrush. bascially it was this. The names were different back then but this is basically the process. I think it was snakebite leather as a base back then. apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5968410 Share on other sites More sharing options...
Kaiju Soze Posted July 4, 2023 Share Posted July 4, 2023 Looks like the old Snakebite Leather. apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5968511 Share on other sites More sharing options...
Grotsmasha Posted July 4, 2023 Share Posted July 4, 2023 10 hours ago, Azaiel said: My suggestion would be Mournfang brown base and then a heavy Zamesi Desert drybrush and Ushabti Bone drybrush. Nailed it apologist and Mithrilforge 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5968556 Share on other sites More sharing options...
apologist Posted July 7, 2023 Author Share Posted July 7, 2023 Brill, thank-you all! Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5969556 Share on other sites More sharing options...
Firedrake Cordova Posted July 7, 2023 Share Posted July 7, 2023 I have that boxed set, and the paint key isn't overly helpful - it just says Bestial Brown (although it could just mean that's the rim colour) @Azaiel's suggestion sounds like it would give a good result, though apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5969579 Share on other sites More sharing options...
sarabando Posted July 7, 2023 Share Posted July 7, 2023 you know the more i looked at that image the weirder it felt until i finally figured it out. Spoiler The bareheaded sarge is white not coal skinned like he should be. Chaplain Mollusc 1 Back to top Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5969610 Share on other sites More sharing options...
Castlerook Posted July 15, 2023 Share Posted July 15, 2023 On 7/7/2023 at 3:25 PM, sarabando said: you know the more i looked at that image the weirder it felt until i finally figured it out. Reveal hidden contents The bareheaded sarge is white not coal skinned like he should be. Yeah, that was before GW retconned the Salamanders' appearance. Which if I remember was a couple of years after the Armageddon Global Campaign. Link to comment https://bolterandchainsword.com/topic/379404-armageddon-basing-request/#findComment-5971748 Share on other sites More sharing options...
