RoadRunna Posted August 25, 2023 Share Posted August 25, 2023 As started in the title, if an enemy unit is within 6” of two units that both cause Fear (1) and that enemy unit is forced to take a moral check, is that check done at -2? Link to comment https://bolterandchainsword.com/topic/380058-two-units-cause-fear%E2%80%A6-does-it-stack/ Share on other sites More sharing options...
Solution sonsoftaurus Posted August 25, 2023 Solution Share Posted August 25, 2023 1 hour ago, RoadRunna said: As started in the title, if an enemy unit is within 6” of two units that both cause Fear (1) and that enemy unit is forced to take a moral check, is that check done at -2? See the second paragraph of Fear rule, main rules p. 238. Does not stack, if multiple sources only use the highest modifier. Gorgoff 1 Back to top Link to comment https://bolterandchainsword.com/topic/380058-two-units-cause-fear%E2%80%A6-does-it-stack/#findComment-5983418 Share on other sites More sharing options...
