Spore pods for Nid beasties are a long established thing but are they any use?
Dropping a unit of Stealers or a Screamer Killer in close to the enemy sounds cool but is it worth it?
At the time of writing, they are a £45 direct-only kit that costs one hundred points.
I could probably Strategically Reserve that SK on from the sides with most of the effectiveness.
Am I missing something?
Bit wasted with stealers... they have scout  8 inch move and unless you improve charge deepstrike charges arnt reliable enough. This effects all cc options for a pod. Really ypu want something that either has an effective charge. Can shoot well at short range or... is worthy to rapid ingress...
Some units shine in a pod... pyrovores.
  Most you can do... but why would you.. tyranid warriors.
But then... then theres curveballs that arnt great but positioning could block something off esp with abilitys like toxicrine...
Personally i used to use loads with the doom and theres a lot to be said for the right location for stuff ruining your opponents day...
Register a new account
Sign in
