slitth Posted September 13, 2023 Share Posted September 13, 2023 As the title says would you like if GW designed model with magnets in mind? Personally I would love to see premade holes for magnets in Space Marine and other models.. Perhaps for heads, power packs and arms. And if you don't like to use magnets, the premade holes would be perfect to make a pin to make a stronger bond, perhaps from the leftover sprues. But maybe it would be harder to kitbash, after all if the holes are not if the angle that you want, it just something you need to fill to before moving on. What do you think? Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/ Share on other sites More sharing options...
RWJP Posted September 13, 2023 Share Posted September 13, 2023 Absolutely. At the very least Vehicles and Dreadnoughts should be designed with magnets in mind. We know GW can do it as the Titanicus range is almost entirely designed for magnetisation. Aarik, Oxydo, MARK0SIAN and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988444 Share on other sites More sharing options...
sitnam Posted September 13, 2023 Share Posted September 13, 2023 I don't particularly care for magnets, but I don't actually play big 40k, so all my monsters and vehicles that would be magnet bait are just pretty shelf decorations. It wouldn't particularly bother me if they were made for magnets Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988446 Share on other sites More sharing options...
Helycon Posted September 13, 2023 Share Posted September 13, 2023 41 minutes ago, slitth said: As the title says would you like if GW designed model with magnets in mind? Personally I would love to see premade holes for magnets in Space Marine and other models.. Perhaps for heads, power packs and arms. And if you don't like to use magnets, the premade holes would be perfect to make a pin to make a stronger bond, perhaps from the leftover sprues. But maybe it would be harder to kitbash, after all if the holes are not if the angle that you want, it just something you need to fill to before moving on. What do you think? They already did this with a couple of the Forge World dreadnought models for the Custodes. The Telemon is the best example of this. They even specified the size before, but that no longer seems to be on the page. Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988450 Share on other sites More sharing options...
Halandaar Posted September 13, 2023 Share Posted September 13, 2023 Theres no debate to be had really, it would obviously be better for hobbyists if they did design for magnets, even if we chose not to use those options. From GWs point of view they could even sell Citadel branded magnet packs at a healthy markup, but the handful of exceptions already mentioned aside, they won't do it because they'd rather you bought 2 Autarch kits rather than easily give you the means to switch the model around between games. MegaVolt87, Kallas, Oxydo and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988455 Share on other sites More sharing options...
Noserenda Posted September 13, 2023 Share Posted September 13, 2023 Depends on the kit, bigger joins it should be fine but if im losing surface area on infantry shoulder joints or the like itll be a big pain in the backside and id rather not. WrathOfTheLion, Special Officer Doofy and Cactus 3 Back to top Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988457 Share on other sites More sharing options...
WrathOfTheLion Posted September 13, 2023 Share Posted September 13, 2023 They designed some of the 30k kits already with magnetization in mind as well. Both the Contemptor and Leviathan Dreadnoughts have magnet holes in them. The predator as well makes sure there's duplicates of parts for the turret, so you can make every single gun out of one kit. So I don't think it's a stretch that this may happen, but I don't think we're there yet for the main 40k design team to do it. Aarik 1 Back to top Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988466 Share on other sites More sharing options...
Evil Eye Posted September 13, 2023 Share Posted September 13, 2023 I personally prefer permanent assemblies on my models, but it would be neat to see more magnet support from GW for those that do magnetize. Noserenda 1 Back to top Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988479 Share on other sites More sharing options...
Rhavien Posted September 13, 2023 Share Posted September 13, 2023 Absolutely yes. Would be cool as hell if this would be the standard. And for everyone that don't want to and fears about enough surface to glue they could provide proper pins on the sprue for convenience. Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988514 Share on other sites More sharing options...
Allart01 Posted September 13, 2023 Share Posted September 13, 2023 (edited) I don't think anyone here will answer "nope". What GW wants, on the other hand, is a different story. Edited September 13, 2023 by Allart01 Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988515 Share on other sites More sharing options...
Orion Posted September 14, 2023 Share Posted September 14, 2023 They do. Tau flyers have all the weapon options with magnet holes. Even the landing gear. Pro tip though: DO NOT use too strong magnets. N52s make swapping stuff out without leverage a massive pain in the ass. Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988576 Share on other sites More sharing options...
ThePenitentOne Posted September 14, 2023 Share Posted September 14, 2023 Apparently the Sisters of Silence Kharon Pattern Acquisitor was designed with magnets in mind. I think it's a decent idea- especially on dreads and vehicles. Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988577 Share on other sites More sharing options...
Domhnall Posted September 14, 2023 Share Posted September 14, 2023 It would be great if they did make their kits with magnets in mind, especially for larger model that are a pain in the breastplate to transport or store safely with all the arms/wings/dangly bits some of them have! Just don't see it happening unfortunately on more mass produced stuff or smaller kits. Link to comment https://bolterandchainsword.com/topic/380574-would-you-like-if-gw-designed-model-with-magnets-in-mind/#findComment-5988602 Share on other sites More sharing options...
