Artisan Cybersmith Posted September 21, 2023 Share Posted September 21, 2023 Greetings! I am planning on a Adeptus Mechanicus custom paint scheme and I got down the base paints. However I don't know what paints I should use for layering. I would like some suggestions. The Base paints are... Vallejo 72.027 Scurvy Green for the outside robes. Citadel Eshin Grey for the inside robes & edge-highlighting black. Vallejo 70.837 Pale Sand for wings, under-bodies & insides of the Skorpius transport. Vallejo 70.950 Black for guns & non-robes clothes. Vallejo 71.336 A-14 Steel Grey for armour plates. Vallejo 72.047 Wolf Grey for cybernetics & kastelan robots. Pro Acrylic Bright Neutral Grey for the middle of the kastelan torso and for stripes. Thank you in advance! Link to comment https://bolterandchainsword.com/topic/380635-would-like-some-paints-suggestion-for-layering/ Share on other sites More sharing options...
Cleon Posted September 21, 2023 Share Posted September 21, 2023 Vallejo black grey goes quite well with their Black if you want a neutral layer, I just use Mechanicus grey on Esshin and I don't use the others so can't help there. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/380635-would-like-some-paints-suggestion-for-layering/#findComment-5990239 Share on other sites More sharing options...
andes Posted September 21, 2023 Share Posted September 21, 2023 My default black progression is Black -> German Grey -> Basalt Grey, all available in the Vallejo Model Color line. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/380635-would-like-some-paints-suggestion-for-layering/#findComment-5990246 Share on other sites More sharing options...
Bryan Blaire Posted September 22, 2023 Share Posted September 22, 2023 Rather than getting paints to highlight, why not build up the highlights in a consistent color? For instance, if you wanted a more warm tone to the light, you could highlight with an ivory for all the colors you outlined, or if you want a colder light, you could use an ice blue to mix into each of your base colors for the highlight. You could build layers in a 3:1, 2:1, 3:2, 1:1, 1:2 fashion, with the spot highlight of your chosen highlight color, or even a white for the sharpest corners. The problem with choosing other colors as highlights (which is something I usually do as well) is that unless the colors you choose all have the same warm/cold tone, your highlights can end up looking a little weird - so you have to decide which direction you want to go with your highlights before you could get really good color suggestions. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/380635-would-like-some-paints-suggestion-for-layering/#findComment-5990380 Share on other sites More sharing options...
