Kierdale Posted October 9, 2023 Share Posted October 9, 2023 I have a farseer on jetbike that I used in a diorama some years ago, mounting it on a long clear rod. I now wish to sell this mini but no longer have the original base. Could anyone tell me the base size (32mm I think) and most importantly how high the rod should be? From the top of the base, to the underside of the jetbike. Many thanks in advance. TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/380778-farseer-jetbike-base/ Share on other sites More sharing options...
Grotsmasha Posted October 9, 2023 Share Posted October 9, 2023 I'm pretty sure that GW supplies two heights with the clear flight stands, 1 inch, and 1.5inches. I'm pretty sure that you're spot on with the round bit being 32mm. HOWEVER, I'd honestly list it as is, as I don't suspect anyone will care unless it doesn't have a base at all. Kierdale and TrawlingCleaner 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380778-farseer-jetbike-base/#findComment-5993692 Share on other sites More sharing options...
Kierdale Posted October 9, 2023 Author Share Posted October 9, 2023 It’s currently attached to about a 6 inch clear rod, so I will cut that down and I would like to make a bit of a scenic base too. I have some Eldar basing I made with a textured roller. thank you very much for the information! I’ll go with 1.5 inches. TrawlingCleaner 1 Back to top Link to comment https://bolterandchainsword.com/topic/380778-farseer-jetbike-base/#findComment-5993752 Share on other sites More sharing options...
TrawlingCleaner Posted October 9, 2023 Share Posted October 9, 2023 I'm a Sorry Kier! You sent me a message asking this and I said I'd measure it and get back to you... Promptly forgetting about it Sorry again! Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/380778-farseer-jetbike-base/#findComment-5993754 Share on other sites More sharing options...
Kierdale Posted October 9, 2023 Author Share Posted October 9, 2023 It’s no problem at all! I didn’t want to bug you about it again. No problem! Link to comment https://bolterandchainsword.com/topic/380778-farseer-jetbike-base/#findComment-5993769 Share on other sites More sharing options...
