librisrouge Posted October 9, 2023 Share Posted October 9, 2023 I've been wondering about the viability of taking a guard list that only utilizes tanks. Something like: Tank Commander Demolisher x2 Exterminator x3 Rogal Dorn x3 Enginseer All high toughness and 2+ saves for days, basically. I understand that this would be a low model count army but I think it can be made to work. I wonder if anybody else has tried a similar list and has any advice or perspective to offer before I go painting treads. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/ Share on other sites More sharing options...
sairence Posted October 9, 2023 Share Posted October 9, 2023 I've run 2 TCs and 3 Russes last weekend. They're reasonably durable but probably won't survive as much as you'd like. The main issue is movement and line of sight, especially if you play on stuff like WTC boards. Emperor Ming, duz_ and librisrouge 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5993841 Share on other sites More sharing options...
Emperor Ming Posted October 9, 2023 Share Posted October 9, 2023 and the oc difference between tanks and inf with command squads is rather alot Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5993857 Share on other sites More sharing options...
sairence Posted October 10, 2023 Share Posted October 10, 2023 Have some more time to get into my thoughts on this style. OC matters to some extent, but your plan is to blow the enemy off the objectives, not get into a numbers game with them. Tonl paraphrase a certain drill sergeant: The enemy can't score, if you take away their models. If you do want to run this I would definitely change your distribution though. Go all on the Demomishers, because you will get caught im CC, maybe even add some Eradicators with the same ability. You don't really need 3 Exterminators, you have decent AP on most guns anyway. Personally, I would also include some Sentinels, as the scout move amd bodt blocking is essential. Also, you need at least one more TC, would recommend running all Plasma on those, probably also a second Enginseer if you're going this hard. And lastly, 2 Basilisks pair really well with this. They can stay back, hold your home objective, and slow done enemy infantry. Regardless off all this, you will struggle to score actualy objectives. You don't really have the capacity for fixed secondaries, or the flexibility for tactical ones. Something like the Ghosts and a callidus go a long way to opening those up big time. DemonGSides, Emperor Ming and librisrouge 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5993879 Share on other sites More sharing options...
Tokugawa Posted October 25, 2023 Share Posted October 25, 2023 Recent tournament lists shows Russ chassis is back on menu. https://40kstats.goonhammer.com/#ft4-astra_militarum Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997473 Share on other sites More sharing options...
Emperor Ming Posted October 25, 2023 Share Posted October 25, 2023 3 hours ago, Tokugawa said: Recent tournament lists shows Russ chassis is back on menu. Nice to see, the only one I could rate atm is the demolisher, just so it can actually fire decently when its tagged in combat 200 is still a lot for bs4 I wish they had kept the previous edition for being tagged, all weapons suffering minus to hit is just Only the main gun should be affected really Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997501 Share on other sites More sharing options...
casb1965 Posted October 26, 2023 Share Posted October 26, 2023 On 10/25/2023 at 11:06 AM, Emperor Ming said: I wish they had kept the previous edition for being tagged, all weapons suffering minus to hit is just The minus 1 is negated by plus one for shooting heavy weapons when not moving though. Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997781 Share on other sites More sharing options...
Emperor Ming Posted October 26, 2023 Share Posted October 26, 2023 6 minutes ago, casb1965 said: The minus 1 is negated by plus one for shooting heavy weapons when not moving though. Most vehicle weapons that were heavy, are not heavy anymore....... Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997782 Share on other sites More sharing options...
FashaTheDog Posted October 26, 2023 Share Posted October 26, 2023 If you hate painting infantry, but love the tanks I have to recommend you go with the models you like. You will spend a lot of time prepping and painting them before they even hit the table. What is competitive now will change in the future so you can play a few smaller games with tanks and see how they go for you. You might want to add in some infantry as support or perhaps artillery or air support. You might not. I do not want to know how many hours I have spent working on my models to enjoy using them on the table so go start with what you like and adjust from there is always the best thing you can do. Emperor Ming, Tokugawa and sairence 3 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997795 Share on other sites More sharing options...
casb1965 Posted October 27, 2023 Share Posted October 27, 2023 14 hours ago, Emperor Ming said: Most vehicle weapons that were heavy, are not heavy anymore....... Hadn't noticed that the vehicle weapons were different to the infantry version. Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997880 Share on other sites More sharing options...
sairence Posted October 27, 2023 Share Posted October 27, 2023 1 hour ago, casb1965 said: Hadn't noticed that the vehicle weapons were different to the infantry version. For me, the logic they used here is pretty straightforward. If the weapon is narratively meant to be stationary when used, it gets heavy. So that's artillery, long range sniper style weapons, infantry support weapons that usually need set up, etc. If it's mounted on a unit that meant to move, fill a linebreaker role or be agile, it doesn't get heavy, cause it's not expected to be stationary. That's most of your Leman Russes, transports, etc. The only gun I've come across that weirdly breaks this mold is the Sentinel missile launcher, for some reason. casb1965 1 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-5997885 Share on other sites More sharing options...
Inquisitor_Lensoven Posted November 16, 2023 Share Posted November 16, 2023 Have you considered sentinels? Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-6002984 Share on other sites More sharing options...
Hiroitchi Posted November 29, 2023 Share Posted November 29, 2023 I've been running Armored Company lists since 8th ed, still do albeit its now cavalry these days, so I think I have some skin in the game. All the points that @sairence have pointed are pretty spot on. I just dont run Basilisks and Sentinels in my lists even though they are great additions. I'm just holding out for the Guard Codex to come out to run my Russ' again. 3x Tank Commanders /w Demolisher cannon; 1x with Grand Strategist 3x Leman Russ Battle Tanks 2x Leman Russ Vanquishers 2x Rogal Dorns I choose the Tank Commanders with Battle Cannons because they are closer in points. Generally, the 2x Rogal dorns are enough for 3x more Russ chassis, but Rogal Dorns are way cool looking. Vanquishers are there because of nostalgic reasons. They were good with their 9th ed codex, but...theyre just okay since their turret has Heavy. So yeah.. play what you like man. Optimizing the list would be replacing the Vanquishers with Basilisks.. Removing 2x Tank Commanders in favor of Lord Solar, and fill the rest with Scout Sentinels. duz_, sairence, MrKoolPants and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/380784-massed-tank-warfare/#findComment-6006313 Share on other sites More sharing options...
