Wulf Vengis Posted October 20, 2023 Share Posted October 20, 2023 I was watching this video from Eric's Hobby Workshop and noticed he mentioned "dish-fluid" or perhaps "dish-fluid" several times, and I cannot figure out what that is. Is he just referring dish soap? Like Dawn or or Fairy? Link to comment https://bolterandchainsword.com/topic/380905-what-is-dish-fluid/ Share on other sites More sharing options...
Solution andes Posted October 20, 2023 Solution Share Posted October 20, 2023 6 minutes ago, Wulf Vengis said: Is he just referring dish soap? Like Dawn or or Fairy? Yes. Wulf Vengis and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/380905-what-is-dish-fluid/#findComment-5996541 Share on other sites More sharing options...
Firedrake Cordova Posted October 20, 2023 Share Posted October 20, 2023 (edited) What @andes said. Dish soap is often used as a cheap flow improver ... Edited October 20, 2023 by Firedrake Cordova Wulf Vengis 1 Back to top Link to comment https://bolterandchainsword.com/topic/380905-what-is-dish-fluid/#findComment-5996547 Share on other sites More sharing options...
Wulf Vengis Posted October 20, 2023 Author Share Posted October 20, 2023 (edited) Thank you much. I've never heard of or thought to use it in wash mix. What exactly is the purpose of the soap in this mix? Got it. Ok thank you much friends. Edit: Questions answered Edited October 20, 2023 by Wulf Vengis Link to comment https://bolterandchainsword.com/topic/380905-what-is-dish-fluid/#findComment-5996552 Share on other sites More sharing options...
Xenith Posted October 20, 2023 Share Posted October 20, 2023 It's an anti-surfactant to change/remove the typical surface tension that water has, to make it flow better. Adding it to a wash will make it flow into recesses better. andes, Wulf Vengis and Firedrake Cordova 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/380905-what-is-dish-fluid/#findComment-5996553 Share on other sites More sharing options...
