Goranged Posted October 31, 2023 Share Posted October 31, 2023 Is it a vehicle, can we use dev grav cannons? or just Lancers? Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/ Share on other sites More sharing options...
Paladin777 Posted October 31, 2023 Share Posted October 31, 2023 Wraithknights are not vehicles, they are monsters. So lascannons (and their variants), demolisher cannons, and probably eradicators are gonna be your best bet. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5998942 Share on other sites More sharing options...
Karhedron Posted October 31, 2023 Share Posted October 31, 2023 Wraightknigts are not that hard to kill. They have fewer Wounds than Imperial Knights and can only get an Invulnerable save if they give up their best guns. If you see a Wraithknight with a shield, you can breath a sight of relief. Even if it is hard to kill, it is not going to be hitting you with Heavy Wraithcannons enhanced with Strands of Fate. Eradicators are one of the easiest options out of the box. 190 points with get you 6 with 2 Multimeltas in there which is only 37% the cost of a Wraithknight but actually have the same number of Wounds. The Eradicators get full rerolls to Hit and Wound against a Wraithknight so will do 9 Wounds at Long range or 15 Wounds at close range, almost enough to kill it. Add an Apothecary Biologis and you will kill a WK on average with a single volley at Close range or seriously maul one at long range while still paying less than half the points with WK costs. A Devastator squad with Lascannons cost just 120 points meaning you could potentially get 4 and still cost less than the WK (OK, only 3 of the same datasheet, you get the gist). A Single Lascannon will do on average 1 wound per turn to a Wraithknight. When you consider that Lascannons are cheap and can be spammed on Devastators, Razorbacks, Predator Annihilators etc, you can see that you don't have too much to worry about. You can get enhanced versions on Land Raiders Gladiators etc and your damage rate goes up if you target the Wraithknight with OOM (and you probably should as it will likely be the biggest target on the table). Granted the Eldar player will probably use a Fate Dice to bounce one of the shots off but they can only do that once per phase now so burning down a Wraithknight is not too hard as long as you have decent anti-tank weapons in your list. Given that vehicles are quite strong and popular in 10th edition, you will probably want to be doing this anyway. The lack of a native Invulnerable save means Wraithkights just aren't that hard to kill in this edition. If you have enough big guns to take out a couple of enemy tanks, you can pop a Wraithknight just fine. If you don't, you probably want to increase your anti-tank regardless of who you are fighting. 6 Back to top Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5998989 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 31, 2023 Share Posted October 31, 2023 With extreme prejudice. 3 5 1 Back to top Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5998990 Share on other sites More sharing options...
Tokugawa Posted November 1, 2023 Share Posted November 1, 2023 GW rules team can help you. With new patch on devastating wounds mechanic, they are no longer brain-dead broken. Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5999064 Share on other sites More sharing options...
Forté Posted November 1, 2023 Share Posted November 1, 2023 Need to stack those buffs. Oath of Moment, Detatchments, Strategems, Leaders, and unit abilities. The other option is to ignore it and focus on getting as many VPs as you can. Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5999250 Share on other sites More sharing options...
Karhedron Posted November 1, 2023 Share Posted November 1, 2023 Personally I would not choose to ignore it as even with the nerfs to Fate dice, it still has a ton of damage output and moves fast. If you ignore it, it will take chunks out of your army. For its points though it is a glass hammer. It costs more than twice as much as a Land Raider yet is only slightly more survivable. It has the same toughness, same save and only 2 more wounds. It does have the -1 Damage rule but that is not a lot against proper anti-tank weapons. If you can kill a Land Raider, you can kill a Wraithknight with only marginally more effort. 1 Back to top Link to comment https://bolterandchainsword.com/topic/381002-how-to-kill-a-wraithknight/#findComment-5999266 Share on other sites More sharing options...
