Inquisitor_Lensoven Posted November 14, 2023 Share Posted November 14, 2023 Just curious if anyone here has tried hydro dipping their larger models to save time on painting. Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/ Share on other sites More sharing options...
Karhedron Posted November 14, 2023 Share Posted November 14, 2023 I haven't ever seen it done on models. Most of the things I have seen hydro dipped have been larger than most 40K models although it might work for vehicles. Could look good for Harlequins perhaps but not sure what other armies would look good with that kind of effect. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002291 Share on other sites More sharing options...
Firedrake Cordova Posted November 14, 2023 Share Posted November 14, 2023 (edited) It's not something I'd ever heard of (), so I did a little bit of Googling and found this: Personally, the results they got don't look great on non-flat surfaces - I'd have thought spraying the model would have been a better time-saver. Don't know if that's any help? Edited November 14, 2023 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002292 Share on other sites More sharing options...
m_r_parker Posted November 14, 2023 Share Posted November 14, 2023 My eyes.... my poor eyes... Halandaar, Helias_Tancred, madlibrarian and 2 others 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002304 Share on other sites More sharing options...
Halandaar Posted November 14, 2023 Share Posted November 14, 2023 I'm pretty sure I've seen some Eldar vehicles done with it that looked okay, but IMO it does not work well with anything smaller than that. Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002337 Share on other sites More sharing options...
TrawlingCleaner Posted November 14, 2023 Share Posted November 14, 2023 @The Yncarne has done some amazing work with Hydro dipping and Harlequin units. I highly recommend taking a look! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002339 Share on other sites More sharing options...
Terminatorinhell Posted November 14, 2023 Share Posted November 14, 2023 It's something that can look good sometimes but most of the time looks awful Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002419 Share on other sites More sharing options...
The Yncarne Posted November 15, 2023 Share Posted November 15, 2023 (edited) As mentioned above hydro-dipping looks best on large, relatively flat surfaces. There's also the pattern scale to consider. Most patterns will simply be too large, especially for infantry. If you're considering a Camo pattern, use a very small scale. I had good luck using galaxy film on eldar and dark eldar vehicles. I've seen some knights and even dozer blades that worked great with scenic films, but I suggest trying it out on other objects first. You'll also want to consider sub-assemblies. Hope this helps. Edit: Hopefully these images come thru and you can see how a boa constrictor pattern looks without touchups. You can see my galaxy vehicles in threads and galleries here at the B&C. Edited November 15, 2023 by The Yncarne Added photos Terminatorinhell, TrawlingCleaner, Grotsmasha and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/381616-hydro-dipping/#findComment-6002599 Share on other sites More sharing options...
