Xenith Posted November 21, 2023 Share Posted November 21, 2023 (edited) I realised last night that I think I've been playing the Big Guns Never Tire (BGNT) and blast interaction wrong. I previously thought that a model with a BLAST weapon cannot fire it while within engagement range at all, however now my reading is that: BGNT allows VEHICLES and MONSTERS to fire weapons even when within engagement range, and they can opt to shoot at targets within engagement range if a friendly model is also engaged, albeit at -1 to hit. BLAST weapons cannot target models within engagement range Ergo a MONSTER with blast, if within engagement range, can fire out of the combat with that BLAST weapon, at a target not within engagement range, with the -1 to hit modifier. I had just assumed that things couldn't fire out of combat, however I think the ability to fire out of combat was already there in 9th, if unengaged, and 9th explicitly, in no uncertain terms, said that a model within engagement ranged can only shoot at models within engagement range. The key wording difference between 9th and 10th, is: 9th: "can only [shoot] against enemt units that it is within engagement range of" 10th "Monsters and vehicles are eligible to shoot...even when they are within engagement range [full stop]. [They] can target one or more enemy units within engagement range" Am I right? Edited November 21, 2023 by Xenith Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/ Share on other sites More sharing options...
Xenith Posted November 21, 2023 Author Share Posted November 21, 2023 I guess it boils down to: Can VEHICLES and MONSTERS shoot out of combat in 10th, when they are within engagement range Can they do so with a BLAST weapon? Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004406 Share on other sites More sharing options...
Jolemai Posted November 21, 2023 Share Posted November 21, 2023 Yes to both. There's an example in the designer commentary on the app I believe. TrawlingCleaner and Xenith 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004408 Share on other sites More sharing options...
Xenith Posted November 21, 2023 Author Share Posted November 21, 2023 Awesome, thank you! Every Tyranid Monster having a BLAST weapon is now no longer as crippling as I thought it was! Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004411 Share on other sites More sharing options...
Karhedron Posted November 21, 2023 Share Posted November 21, 2023 I made the same mistake initially with my Knights. Easily done. Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004413 Share on other sites More sharing options...
Metzombie Posted November 21, 2023 Share Posted November 21, 2023 1 hour ago, Xenith said: and they can opt to shoot at targets within engagement range if a friendly model is also engaged Where did you get the marked part from? Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004427 Share on other sites More sharing options...
Xenith Posted November 21, 2023 Author Share Posted November 21, 2023 46 minutes ago, Metzombie said: Where did you get the marked part from? It's in the BGNT rule - they have to be in the same combat - if enemy unit A is in contact with tyranid monster B and gaunts C, Monster B can still shoot A with non blast weapons, even though C is still in engagement range. Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004443 Share on other sites More sharing options...
Metzombie Posted November 21, 2023 Share Posted November 21, 2023 Yes, but the way you wrote it, it means you need to have another unit in combat to shoot into combat. Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004448 Share on other sites More sharing options...
Xenith Posted November 21, 2023 Author Share Posted November 21, 2023 Yea, I forgot the ", even..." It wasn't really the main part of my question. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/381728-bgnt-blast-and-engagement-range/#findComment-6004471 Share on other sites More sharing options...
