Battle-shock - how long does it last in certain conditions?
Go to solution Solved by Karhedron,
The general rule of Battle-shock is that at the start of your Command phase you have to take one if a unit is below half-strength and if you fail it then it lasts until your next Command phase.
In the following scenario, the opponent is charging in his turn a unit I control led by Dante. Dante's ability forces the opponent's unit to take a BS check with a -1 penalty, and they lose it.
In the following turn, which is mine, does the opponent's unit remain battle-shocked throughout that turn? His unit is not below half-strength.
And is then released from BS in his own following turn?
=][= Moved to Offical Rules as it's a better fit here =][=
For the Question itself, you have the right of it here. If a unit is above Half-strength when the controlling player's Command phase rolls around then they automatically pass Battle-shock.
The ideal is that you force Battle-shock in their turn so they're Battle-Shocked for longer but it's not always do-able! :laugh:
Register a new account
Sign in
