Inquisitor_Lensoven Posted December 28, 2023 Share Posted December 28, 2023 If a unit with 0 OC kills a unit with sticky objrctive rule in melee, does the sticky still stick? Link to comment https://bolterandchainsword.com/topic/381994-sticky-objectives-and-oc-0/ Share on other sites More sharing options...
BluejayJunior Posted December 29, 2023 Share Posted December 29, 2023 From the sticky objective abilities I quickly looked up, it doesn't say you stop controlling it when that unit is destroyed. Only when it is controlled by your opponent. A unit with 0 OC cannot control an objective, so it looks like it would still be controlled by the player with the sticky unit. Xenith, Karhedron and Dr_Ruminahui 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/381994-sticky-objectives-and-oc-0/#findComment-6012391 Share on other sites More sharing options...
Dr_Ruminahui Posted December 29, 2023 Share Posted December 29, 2023 (edited) Certainly that's the way the rule works for Chaos Cultists, the only unit with sticky objectives whose rules I am personally familiar with. For a more detailed discussion on why OC 0 can't control objectives, see here: Note, at least for Chaos Cultists, the objective doesn't become sticky right away - that doesn't happen until their controller's command phase. So, a Chaos Cultist unit could move onto an objective and control it, then be killed before their command phase then the objective wouldn't be sticky yet and their controller would lose control of it (unless he/she had another unit also controlling it). So, in answer to the original question - No, unless the "sticky" unit is destroyed before its rules make the objective sticky. Edited December 29, 2023 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/381994-sticky-objectives-and-oc-0/#findComment-6012434 Share on other sites More sharing options...
Xenith Posted January 2, 2024 Share Posted January 2, 2024 Sticky ends when it is controlled by your opponent, OC0 cannot control, so cannot flip a sticky objective. Link to comment https://bolterandchainsword.com/topic/381994-sticky-objectives-and-oc-0/#findComment-6013100 Share on other sites More sharing options...
