Brother Raul Posted December 29, 2023 Share Posted December 29, 2023 Hi All, Looking to get back into the hobby and trying to save some coin by mixing my own highlights which I've had some success in the past. I try to stick to a colour wheel but metallics are a new horizon. Would runefang steel mix in with Gehenna gold to lighten up? Plan is to use Gehenna as a base with some nuln oil, highlight with Gehenna, then mix a runefang/Gehenna as a third and then use a light point 4th highlight of runefang. Basically the same with standard mechanicus/ Abaddon black (creating eshin) but metallic. Also Averland sunset mixed in with Mephiston red to make evil sunz and fire dragon orange. Corax with a grey for celestial grey. Any tips and advice would be appreciated and I'll use the medium as well. Definitely not painting a blood angels army. Thanks. Link to comment https://bolterandchainsword.com/topic/381997-highlight-mixing/ Share on other sites More sharing options...
Bung Posted December 29, 2023 Share Posted December 29, 2023 For highlighting metallics i would recommend the brightest silver color you have. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/381997-highlight-mixing/#findComment-6012415 Share on other sites More sharing options...
Firedrake Cordova Posted December 30, 2023 Share Posted December 30, 2023 GW's tutorials often have gold being highlighted with silver (Stormhost, I think) for the final highlight, so your plan sounds like it should work. The easiest way to check is to mix up a little on your palette and see if it "looks right" Otherwise, your plan seems reasonable. Paint-mixing was how things were done "back in the day" before GW had a giant range of colours. Brother Raul 1 Back to top Link to comment https://bolterandchainsword.com/topic/381997-highlight-mixing/#findComment-6012524 Share on other sites More sharing options...
Karhedron Posted December 30, 2023 Share Posted December 30, 2023 (edited) For gold, my usual recipe is to start with a base of Retributor Armour and wash it with Aggrax Earthshade (I use my dwindling supply of gloss but the regular stuff will do). Then I highlight with Liberator Gold and a top highlight of Stormhost silver. Pretty straightforward but it looks good. Here is my Dante which was painted in this way. Edited December 30, 2023 by Karhedron Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/381997-highlight-mixing/#findComment-6012580 Share on other sites More sharing options...
