L30n1d4s Posted January 14, 2024 Share Posted January 14, 2024 (edited) So, I am trying out a Blood Angel list, including the Librarian Dreadnought with its "Wings of Sanguinius" ability. By my reading, there is no restriction against using it on a a friendly Astartes Infantry Unit within 12" that is locked in combat (meaning I can use this ability to have a unit escape melee) and, as I read it, this move is not a Fall Back move either, so that means the selected Infantry unit is free to Shoot and Charge this turn after it has been moved. Is that an accurate interpretation of the "Wings of Sanguinius" rule? I am asking because, if it is the way i understand it, that makes this ability even more powerful than I realized! Edited January 15, 2024 by L30n1d4s BAjim and Karhedron 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382095-question-on-wings-of-sanguinius/ Share on other sites More sharing options...
Jolemai Posted January 14, 2024 Share Posted January 14, 2024 Yep, it appears to be fine. Karhedron, L30n1d4s and Adorondak 3 Back to top Link to comment https://bolterandchainsword.com/topic/382095-question-on-wings-of-sanguinius/#findComment-6015749 Share on other sites More sharing options...
Jolemai Posted January 16, 2024 Share Posted January 16, 2024 On 1/14/2024 at 6:18 PM, Jolemai said: Yep, it appears to be fine. To add a little bit more context, any ability which puts you into Strategic Reserves requires you to not be in engagement range, but any ability which moves you on the same turn (such as a Weirdboy's Da Jump ability) do not require this. There's neither anything in the Designer Commentary either to say that the unit is falling back; essentially it has elected to Remain Stationary and only when the ability has been used does the unit count as having made a Normal Move. Adorondak 1 Back to top Link to comment https://bolterandchainsword.com/topic/382095-question-on-wings-of-sanguinius/#findComment-6016130 Share on other sites More sharing options...
