Dominoris Posted January 20, 2024 Share Posted January 20, 2024 When the two disagree, which has the current correct values? The PDF or the phone app? I am assuming the app but I want to be sure. Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/ Share on other sites More sharing options...
Emperor Ming Posted January 21, 2024 Share Posted January 21, 2024 Pdf The app is renown for being questionable/not kept updated Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6017468 Share on other sites More sharing options...
Dominoris Posted January 21, 2024 Author Share Posted January 21, 2024 (edited) oof. That's a bummer. I need to be sure and download the correct field manual now. Is version 1.5 dated 6/12/23 current? Edited January 21, 2024 by Dominoris Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6017485 Share on other sites More sharing options...
Emperor Ming Posted January 21, 2024 Share Posted January 21, 2024 Yep The January update should be very soon thou so expect that to change Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6017491 Share on other sites More sharing options...
DemonGSides Posted January 23, 2024 Share Posted January 23, 2024 On 1/20/2024 at 6:45 PM, Dominoris said: When the two disagree, which has the current correct values? The PDF or the phone app? I am assuming the app but I want to be sure. I'd say PDF, but I'm also curious what discrepancy you're seeing currently. Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6018277 Share on other sites More sharing options...
Dominoris Posted January 24, 2024 Author Share Posted January 24, 2024 I was me looking at an old PDF ... DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6018629 Share on other sites More sharing options...
DemonGSides Posted January 25, 2024 Share Posted January 25, 2024 Ah no worries brother! GWs organization on MFM leaves a lot to be desired! Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6018885 Share on other sites More sharing options...
Xenith Posted January 29, 2024 Share Posted January 29, 2024 On 1/20/2024 at 11:45 PM, Dominoris said: When the two disagree, which has the current correct values? The PDF or the phone app? The phone app should be updated with the latest values within days of the pdf dropping. If there's a difference, make sure you have the latest pdf! On 1/24/2024 at 7:56 PM, Dominoris said: I was me looking at an old PDF ... Ah, that'll do it! Link to comment https://bolterandchainsword.com/topic/382151-warhammer-communitys-munitorum-field-manual-vs-wh40k-app/#findComment-6019628 Share on other sites More sharing options...
