Agramar_The_Luna_Wolf Posted February 5, 2024 Share Posted February 5, 2024 I was searching in old catalogues for an oop set of FW and I have a doubt. The vox operator helmet/head the same model in both .FW made a mistake when they made the catalogue's pics or never existed a proper modem for one of the sets? Maybe if someone owns both can tell me. This Mk II And this MkIII (Pics from Miniset.net) The MkIII is still available, Mk II ,Mk IV and VI are opp Link to comment https://bolterandchainsword.com/topic/382261-question-about-mk-iii-ii-command-sets/ Share on other sites More sharing options...
Solution Spagunk Posted February 5, 2024 Solution Share Posted February 5, 2024 (edited) Nope. The mk3 vox heads are 1:1 the same as the mk2 vox heads. This is intentional just like how the mk2 back packs were the same as mk3's at the time. EDIT: Old MK5 and MK6 had the same backpack, for reference. Edited February 5, 2024 by Spagunk roryokane, Agramar_The_Luna_Wolf and LameBeard 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/382261-question-about-mk-iii-ii-command-sets/#findComment-6021131 Share on other sites More sharing options...
Cactus Posted February 6, 2024 Share Posted February 6, 2024 The crested helms are probably Mk3. You can tell because they have two eye slits. The two helms with the single-slit are Mk2. So each kit appears to come with two heads of each mark. Link to comment https://bolterandchainsword.com/topic/382261-question-about-mk-iii-ii-command-sets/#findComment-6021268 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted February 6, 2024 Author Share Posted February 6, 2024 19 minutes ago, Cactus said: The crested helms are probably Mk3. You can tell because they have two eye slits. The two helms with the single-slit are Mk2. So each kit appears to come with two heads of each mark. The crested helmets are fine, one of each Mk. The intriguing point for me was the vox operator helmet, same model in both Mks roryokane 1 Back to top Link to comment https://bolterandchainsword.com/topic/382261-question-about-mk-iii-ii-command-sets/#findComment-6021278 Share on other sites More sharing options...
