Inquisitor Trinity Posted February 6, 2024 Share Posted February 6, 2024 (edited) After starting them in April my Inquisition Storm Trooper company is finally ready to spray paint. All 70 of them! I did have a provisional name for them as the endless but I've gone off that name. Unsure what to call them. As you can see there is somewhat of a diverse range of models, however, I've added little details to each so that there is something to link them all together. I've tried to make it look like they've gotten their arms and armour from the same armoury. If you want to see more check out my instagram! https://www.instagram.com/inquisitor_trinity/ These are my counts as crusaders from my Inquisition stormtroopers. As several others have done I've used the subjugators and their massive shields as the base but I've also added what a lot of other people have used which is skitarii heads. Not seen the two together so far. I've also used deathwatch power swords, kasrkin shoulders and sculpted a lot of details. The subjugators are quite a popular choice for plastic crusader conversions, as are the skitarii heads. I don't think anyone has altered them to this level though. I wanted a more militaristic and techy feel to them instead of the religious overtones in the original Inquisition crusaders. I think they're looking pretty awesome! I hadn't initially planned to include arbites in my Inquisition stormtrooper company but after seeing them I just had to have them. That happened a lot I have made a lot of effort to bring their look closer to the other models, particularly the kasrkin who are the base template if you will. This includes: - sculpted kasrkin style tunic and armour plates - kasrkin gas mask - kasrkin helmet light - sculpted navy breachers helmet crest I've also removed any arbites iconography as they aren't arbites in my lore, just differently armed storm troopers which I've decided to call, seekers. Hopefully the green stuff doesn't look too bad! The arbites are probably the squad I made the most alterations to. As you can probably tell. Unfortunately I won't be able to use them in game because the minimum squad size is 10 and you can't mix shields and shotguns. Even in the exaction squad which is really annoying. At least they look cool, that's the important thing. Unfortunately these assault Kasrkin will probably never see the game board as there is nothing that I could approximate them to. Not only is there no astra militarum assault unit there isn't a jump unit either. The closest approximation would be the sororitas jump infantry I guess? Still a fun unit to make though. It combines cadian chainswords and las pistols with kasrkin and orlock jet packs. I've made the usual green stuff alterations as well. For a relatively simple kitbash I'm very pleased with these jet troopers. All it took was to add some orlock wrecker jet packs to kasrkin and grab some chainswords and las pistols from the cadian sprues. I did consider doing hot shot laspistols but I thought they'd be too unwieldy. # The navy breachers are another squad that wasn't planned initially for my stormtrooper company but I couldn't resist! In order to bring them in closer to the rest of the company I added kasrkin style armour plates. I always thought they looked a bit underarmoured and I think I've rectified that quite well. I've also added arbites elbow pads, arbites shotguns, chest targeter and a kasrkin helmet light. You can also see ive removed all the navy iconography and added an Inquisition symbol. Enjoy! I always thought they were under armoured given that they're supposed to be wearing vacuum sealed suits, so I gave them some extra armour using press moulds from the kasrkin. I've always been very keen on the kasrkin style, even back when it was a choice between the metal ones and the regular stormtroopers I'd choose kasrkin. Once I saw they were coming out in plastic I had to get some. I'm justifying the deviation from deathwatch as they're Inquisition stormtroopers not technically another faction aha. They're the base template for the company at large. I've added the navy breachers helmet crest and arbites elbow pads and chest targeter in addition to the Inquisition symbol. I've also tried to mix up the poses as there's a lot of them I wasn't that keen on. You might be able to tell that they've all got some form of close combat weapon as well! This is the other stormtrooper kasrkin squad. Much the same as the other one just with different poses. I've armed them more or less the same as both squads have two volleyguns, a melta, plasma and sniper. Each squad also has a vox and a medic for flair. I'm very keen on the bayonets that's for sure This is by far the squad I'm most proud of they're a combination of cawdor ridge walkers, kasrkin for the pilots and rough rider lances. I had to really carve up the legs and green stuff them so they'd fit which was a pain but had come off pretty well! (Looks pretty natural after I've spray painted them at least) You can see I've also green stuffed some other details including: - arbites elbow pads and chest targeter - navy breachers helmet crest - Inquisition symbol on chest These are details I've tried to include across all my storm troopers to tie them together. I think weirdly the bases I made for them are one of my favourite bits. As there's not any sculpted oval based for this scale I made some industrial ones using necromunda bits and the void war bases parts. I've been sure to include all the weapon options for rough riders. They've got the lance, holstered pistol and you can see a lasgun on the front of the walker so they've got access to all the weapons. Reposing the walkers so they didn't all look the same whilst standardising them so that they all look like the same vehicle was a tricky balance. Most of the poses look good but a few are a bit iffy. What do you think of my Inquisition stormtroopers cavalry? I've been working on the organisation of my Inquisition army. Inquisitor Trinity has a much larger retinue than most, the size of a small army or astra militarum platoon. This is very apt as they are far more militaristic than most Inquisitors, even of the ordo xenos, and believe in applying ever whelming force. Some of the roles here are obvious and some are troops that I am converting and are essentially Inquisition stormtroopers. I will be building ALL of them at some point and some are already built (look back over my posts) any guesses what's what? Edited December 18, 2025 by Inquisitor Trinity Title change Lord_Ikka, AutumnEffect, N1SB and 5 others 4 4 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/ Share on other sites More sharing options...
ThePenitentOne Posted February 8, 2024 Share Posted February 8, 2024 This is awesome. This is a full-on Order of Battle. I hope GW gives you an Inquisition detachment that can use this force, though your count-as strategy will certainly be okay with any opponent worth playing. I love your cavalry! I also love the fact that you've got a full-fledged Chamber Militant army to back these guys up. I checked your Insta as much as I could before it started pestering me to create an account. Do you Crusade, or are you a stand-alone gamer? This army and their Chamber Militant allies were made to Crusade. Unfortunately, detachment and bespoke Crusade support are weak right now, but your Chamber should make out okay. Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6021643 Share on other sites More sharing options...
W.A.Rorie Posted February 9, 2024 Share Posted February 9, 2024 Really like where you are going with this and can't wait to see more. Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6021924 Share on other sites More sharing options...
Inquisitor Trinity Posted February 13, 2024 Author Share Posted February 13, 2024 On 2/8/2024 at 3:20 AM, ThePenitentOne said: This is awesome. This is a full-on Order of Battle. I hope GW gives you an Inquisition detachment that can use this force, though your count-as strategy will certainly be okay with any opponent worth playing. I love your cavalry! I also love the fact that you've got a full-fledged Chamber Militant army to back these guys up. I checked your Insta as much as I could before it started pestering me to create an account. Do you Crusade, or are you a stand-alone gamer? This army and their Chamber Militant allies were made to Crusade. Unfortunately, detachment and bespoke Crusade support are weak right now, but your Chamber should make out okay. Fingers crossed they'll give the inquisition some love! Though I do sadly doubt it. Yeah the counts as would be find in casual games so i could soup from multiple armies. it's not like the inquisition is competitive enough to play in tournaments anyway. Yep, Inquisitor Trinity is based out of Watch Fortress Furor Shield as it's inquisitorial representative. They've got plenty of space for barracks aha. I don't really game all that much, mostly I just build and paint. I kinda want to do a full 10 squads so i'm trying to think of other 10man units i could do a counts as conversion that would work. Something human sized with reasonably heavy armour and on the imperial side. I suppose I could get a second arbites squad so I can actually field a 10 man shields/mauls and a 10 man shotgun squad. Though ideally I'd like to do more with the kasrkin as a base so it looks like the crusaders, breachers and arbites are unique specialist squads. ThePenitentOne 1 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6022657 Share on other sites More sharing options...
Inquisitor Trinity Posted July 30, 2024 Author Share Posted July 30, 2024 Finally got round to posting about my inquisition stormtroopers. Matching my colour scheme for the other inquisition elements I've gone with red armour, orange elbow and knee pads, purple shoulders, gold head crest and details, blue cables, green eye lenses and yellow lights. The symbol of Inquisitor Trinity is (somewhat crudely) represented on the right shoulder and the squad designation on the left. After trying for ages to find a decent numeral system that looks cool I settled on the star wars aurebesh. Still haven't come up with a cool name for the "regiment" I thought something like "The Endless" or "The Immortals" but neither sounds right. I want something that evokes relentless implacable destruction but is one word so it'd be The something. This is squad D, troop type vindicator. This here is my navy breacher squad that's part of my inquisition storm trooper company. As you can see I gave them extra armour as I wanted them to look similar to my kaskrin. In retrospect I kinda wish I'd swapped the shoulders out for kaskrin shoulder pads as the breacher ones are a bit small for the squad and company markings Up next for my inquisitorial stormtrooper company is an assault squad! Sadly I won't be able to use them in games as there isn't a unit that's even slightly similar. So they're purely for the fun of it. I think they look really cool! I used orlock wrecker jet packs and various cadian chainswords and pistols. Like my other stormtroopers they have the helmet crest, elbow pads and chest targeter. Iconography is the squad designiation and company insignia (of inquisitor trinity) Harrowmaster, W.A.Rorie and deathspectersgt7 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6053029 Share on other sites More sharing options...
W.A.Rorie Posted July 30, 2024 Share Posted July 30, 2024 Nice Inquisitor Trinity 1 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6053042 Share on other sites More sharing options...
Inquisitor Trinity Posted October 15, 2024 Author Share Posted October 15, 2024 ++ SURRENDER TO THE INQUISITION ++ I finally got around to putting together the Inquisitor I've had as an idea in my head for over a year! Inquisitor Trinity is my account name for that reason. Surprise though, Trinity (as the name suggests) is three individuals! Or is Trinity one amongst them? Or not there at all and controlling them from afar... Who knows! I'm really pleased with how they came together. My idea was for them to be alike with many common features but also different. I wanted to put my utmost effort into them and make them the absolute best models that I have ever done. Utilising techniques that I've never tried, painstaking incremental blending, better glow effects, detailed free handing and more. I'd say the end results are quite fantastic! Each looks like they're wearing a suit of power armour and are as similar as I could make them whilst still being noticeably different. Matching the colour scheme of my inquisition force (of which they are the head) helps tie them into the army and each other. The capes are some of the best parts of the models, the large area allowed me to blend much easier and I could add the Inquisitor Trinity symbol! Sadly not completely as it's too small for the full detail but it's very close. First up is this Inquisitor Trinity that I will refer to as "sigil". The base model is Jelsen darrock from the cursed city set. I've cut off all the stakes and other gubbins leaving the base model. Added a bunch of power armour, the mask, staff and constructed some backpack guns they operate remotely, keeping their hands free. It's hard to pick favourites but I think this one needed the most work to convert. Creating the sabatons (foot armour) of the "sigil" Trinity was one of the more challenging aspects of creating a more power armour vibe, it should look right painted. The staff I created from a sisters of battle halberd and added a stripped down deathwatch vehicle icon. The backpack guns were created from the little servo arms on the kataphron breachers with bits from the kaskrin hellguns. Next we're taking a look at the "hammer" version of Inquisitor Trinity. Based on the Hanniver Toll model it's got a very dynamic pose. Through green stuff I was able to turn the boots into power armour and I used the hammer head from Jelsen Darrock. It was very annoying getting the sword off of the cape but the whole effect is pretty great I think! Certainly the most dynamic of the three. I hadn't fully fleshed out this idea before I started building this one so I got the base model (Hanniver Toll) and experimented with some parts. Made them look all 40k style and crafted the hammer out of various parts. I think the end result is pretty good don't you? The third Inquisitor Trinity wields a spear alongside the backpack guns. Though I don't have a favourite of the three this version is the first one this came to me and the inability to choose between this version and the "sigil" version helpful spawn the Trinity idea. In addition to chiseling off all the fantasy details from the Hexbane base model I added a spear using several celestian sacresant parts and used green stuff to make the armour more power armour. You'll have to let me know which Inquisitor Trinity is your favourite based on the conversions and paintjobs! Also, if Trinity is one amongst them, which do you think they are? Or do you think Trinity controls them from afar? Or are they somehow all of them? brother_b, librisrouge and deathspectersgt7 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6071040 Share on other sites More sharing options...
Inquisitor Trinity Posted December 19, 2024 Author Share Posted December 19, 2024 I started this army in April. Of last year. And now finally, I have finished all the models I built. There will be more but at the time I only had these in mind. As I wanted them to be very uniform I (perhaps foolishly) decided to build all 70 at once. They are The Edict, Inquisitorial storm trooper company of Inquisitor Trinity (that's them at the front). It is very rare to see an Edictor unarmoured, any knowledge of the person within is completely obscured. Rumours abound of just how trinity acquires recruits for the Edict. Some theories suggest they are cultivated through breeding programs or are somehow grown from scratch. They certainly have very similar builds and mannerisms.... Training for the Edict includes significant hypno conditioning and memory implantation, similar to that of the Red Hunters space marine chapter. All weapons and armour are provided by trinity and have a high degree of compatibility with each other allowing for flexibility and swift reorganisation. Squads can be reformed and directed at will via trinity issuing one of many numbered orders and contingencies. The Edict is an extension of Trinity's will, ready to destroy the alien, wherever they are found. The Edict includes: 10 Exterminators (crusaders) 10 seekers (Arbites) 10 Breachers 20 Vindicators (kaskrin) 10 Hunters (kaskrin with jetpacks) 10 Stalkers (kaskrin on ridge walkers) I have plans for further squads and some agents, on stormtroopers in service of the Inquisitor, but for now I'm very excited to do some more deathwatch. I'll probably alternate going forward. Let me know what you think! I haven't before shown you the crusaders so here they are! I think the conversions are really cool! I learned some tricks from painting the Inquisitors so these guys have decent power sword lightning effects and armour chipping. Annoyingly crusaders are only in the adeptas sororitas codex so I can't take them with my imperial agents AND they're limited to units of 3 or 6. All the same they're very cool and I'm sure friends would let me use them in a casual game. And these are the rough riders (or krieg death riders with the new codex) of my inquisition stormtrooper company. I call them stalkers. As I'm sure you can tell the bodies are kaskrin with rough rider lances. The walkers are cleaned up and standardised cawdor ridge walkers from necromunda. The toughest part of making these was trying to standardise the look of the walkers. Give that the cawdor ridge riders are so rickety I had to use the same parts and then strip away as much of the extra bits as I could. Despite that it still has the wraps on them which I hope look decorative and not like they're holding it all together. I need to remember to post here more often rather than dumping a huge amount on you all! You can check out my instagram for more frequent updates. brother_b, sitnam, deathspectersgt7 and 3 others 3 3 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6081829 Share on other sites More sharing options...
Ulfast Posted December 20, 2024 Share Posted December 20, 2024 Really cool looking army. Must be fun to have! Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6081973 Share on other sites More sharing options...
Inquisitor Trinity Posted January 16, 2025 Author Share Posted January 16, 2025 I've put together some agents as part of my Inquisitor's retinue. All of them are pulling double duty with the option of agents of astra militarum rules. But of course the day I built these I discovered that the regimental advisors aren't in the new astra militarum codex aha This one with the staff is designed to be a primaris psyker but can also be an agents mystic. This one with all the antennas is a master of ordinance in regimental advisors or in kill team a navy breachers surveyor or in agents a generic agent. The master of ordinance model is lore wise in charge of operating all the drones attached to the retinue. Servo skulls, servitors, C.A.T units, robo dogs and such. Given how many there is I figured someone would need to be in charge of that. The gas mask dude is a pilot with can be either an officer or the fleet in the regimental advisors or a pistoleer in agents. The bookish model is either an astropath in a regimental advisors unit or a mystic in agents. It's hard to tell from the photos but I drilled it's eyes out, a nice subtle conversion aha. deathspectersgt7, Ulfast and librisrouge 3 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6087696 Share on other sites More sharing options...
Inquisitor Trinity Posted March 6, 2025 Author Share Posted March 6, 2025 I finished up building a command squad for my inquisition stormtroopers. If you check out my other posts you'll be able to see the company so far. Unlike the squads which are very uniform I've tried to combine elements of the armour used in the various squads for the command. Navy breachers, Arbites, kasrkin and palanite armour elements are all featured. My aim was to roughly allow for the squad to be used as cadian, scions or krieg. To that end as they unhelpfuly are a mix of lasguns, pistols and hotshot lasguns I've given them something along the lines of hotshot lascarbines made from extended hotshot laspistols that I'm hoping opponents would be cool with. I'd also have to sub in a special weapon model for krieg and scions. The commander has a rather funky hat in addition to a mace and plasma pistol. The standard bearer has an icon instead of a flag as I felt it was more appropriate, and much more cool. The medic has the medic pistol thing from the scions in addition to the lascarbine. The vox master I based on the cadian vox and made them a little taller so they're at kasrkin scale. I also added more armour to bring them in line with the kasrkin. The power fist dude is essentially a morale officer (and will represent the krieg commissar). Unfortunately they're noticeably slighter and shorter in scale. There's also a priest and Arco flagellants I needed to get done at the same time. deathspectersgt7 and brother_b 2 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6098565 Share on other sites More sharing options...
Inquisitor Trinity Posted March 27, 2025 Author Share Posted March 27, 2025 I've finished painting my inquisition stormtrooper Command squad! The intent was to reasonably be able to proxy them as either cadian, scions or krieg (though I'd need a special weapon dude for some of those). There's also a priest and two Arco flagellants I needed to finish off a squad. All in all I'm pretty happy with them. The colour scheme really brings them together with the rest of my inquisition stormtrooper company. librisrouge, brother_b, deathspectersgt7 and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6102085 Share on other sites More sharing options...
Inquisitor Trinity Posted May 12, 2025 Author Share Posted May 12, 2025 My latest batch of minis includes my versions of interrogators and the rogue trader retinue. The interrogators will represent commissars in my astra militarum army though I suppose the sniper looking one will have to represent a vindicare assassin. I could also use the dual bladed assassin as an eversor or the death cult assassin in the new sanctifiers kill team. As Inquisitor Trinity is represented by 3 individuals (check out my other models) 3 interrogators made sense thematically. I wanted to make my own conversions for the rogue trader entourage (although the rejuvenant adept was too cool not to use, with some alterations). They represent general agents that my Inquisitor employs, all of the army is represented like that. interrogator with chain sword and bolt pistol - A fairly simple combination of inquisition and kasrkin bits interrogator with power sword and pistol (can stand in for the interrogator in the inquisition kill team) - most of this one is inquisition bits but the addition of the arbites handcuffs really makes it stand out interrogator with rifle (just a cool concept I wanted to make) - the body of this one is from the Hexbane's Hunters kit which i've given a skitarii rifle and general converted to 40k rejuvenant adept (in my lore a chirurgeon) - a simple headswap and filing off the more ostentations details death cult assassin (in my lore just a general assassin in the Inquisitor's employ) - This is from the saviours of cinderfall kit which i've given the blades, mask and a few other 40 details rogue trader (in lore thecaptain of Trinity's vessel) - also from the hexbane kit this utilises navy breacher bits, a hat and other parts for a nautical feel lectro-maester (in lore a mechanic/engineer in Trinity's employ) - for this one I got as many wrenches and mechanic themed items as I could. Hopefully they look like they're wearing a jumpsuit Ulfast and deathspectersgt7 2 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6109111 Share on other sites More sharing options...
Inquisitor Trinity Posted June 8, 2025 Author Share Posted June 8, 2025 Just finished my interrogators and rogue trader entourage! The interrogators are up on the top row and will likely be used in game to represent commissars (or a vindicare for the sniper). Bottom row is the rogue traders, it should be fairly obvious which is which. In my lore they are all agents in service to my Inquisitor Trinity. You've got an engineer, ship captain, assassin and chirurgeon. If I had to pick a favourite I might say the sniper interrogator. But he'll, they're all good! This interrogator is giving big splinter cell vibes! I'm very happy with this use of the skitarii rifle, it's so steampunk. This interrogator is ready to collar some heretics! This interrogator is more combat ready and likely to jump in with the stormtroopers You can't be a ship captain without a big hat! I figured they'd also have rather fancy weapons. For such a little conversion I think it gives this one a whole new look! A simple headswap and filing off the more fancy details on the tunic. The red mask on this assassin is probably the last thing a lot of heretics see. Gives the model a real focal point Every operation needs a good engineer and mechanic. I went for a sleeves rolled up vibe and as many tools as I could find. Lord_Ikka, Teetengee, brother_b and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6114848 Share on other sites More sharing options...
Inquisitor Trinity Posted June 26, 2025 Author Share Posted June 26, 2025 My newest batch of minis. Some sternguard including a guest custodes! As I expect at some point we'll get some primaris deathwatch I wanted them to be roughly able to pass as deathwatch veterans. I think they would unless power weapons are part of the default loadout. Two of these are also my version of a primaris captain Artemis and Donatus from kill team Cassius! I think I've captured them quite well don't you? The custodes is one of the ones that helps the primaris integrate and is overseeing that process at furor shield. Some of the green stuffing has gone better than others aha. either way though I'm VERY pleased how the custodes turned out. Any guesses which chapter each are from? I'm not a custodes player but I thought building one of those Emissaries Imperatus that turn up to help primaris marines integrate would be fun for my deathwatch/inquisition. The main body is a stormcast with a bunch of custodes parts, marine parts and green stuff. I went with a melts spear as A) cooler, B) probably more effective. Got a little scroll for his orders as well. What do you think? This here is my primaris version of Donatus from Kill Team Cassius. They are not donatus themselves but an homage so they're from a different chapter. Any guesses which? Using parts from the original model worked really well and I think it's a very good recreation! This next one my overwhelming vibes were BONESSSS. I've also used s slightly different bolter magazine and i've used one of the centurion heads. I can't decide if the head works or looks goofy. Next up is my homage to a primaris Artemis (again not the man himself). I did what I could with various aspects but some were just too much of a pain to recreate. All the same he's got the important bits, head, backpack icon, bionic arm, combi flamer, cape, sword. The green stuff is definitely very rough, if I had to do it again i'd have used a model that wasn't missing most of it's central area aha This one is a much simpler conversion but i'm loving the two handed sword slung over their back. Any guesses on which chapter they are? Again nothing too special here. Various bits and pieces make a cool model. Any guesses on chapter? If you want to see more check out my instagram! librisrouge, W.A.Rorie and deathspectersgt7 3 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6118592 Share on other sites More sharing options...
Inquisitor Trinity Posted December 18, 2025 Author Share Posted December 18, 2025 I have returned! Once again I just keep forgetting to update these threads, i'm much more active on reddit and to an extent instagram. I'd like to say i've done a lot but not as much as i'd hoped. I finished the above sternguard and custodes, still very happy with those conversions. and how gold the custodes is. The photos are kinda blurry as I had to compress them to get them on here. A bigger batch was next as I put together all the drones and pets for my inquisition. We have: - 4 servitors - 5 dogs - 3 spiders - 4 servo skulls - 2 Cyclops tiny tanks - 1 C.A.T - 1 nuncio Aquila - 1 cyber eagle - 2 teleport homers - 1 servo sentry (completely kitbashed!) For the most part it was more a batch that needed to be done than a batch I was excited about so I just needed to get it out of the way. And then finally finally i've gotten around to building some of these new deathwatch! Despite my reservations about the lack of options in the box it's still really great that we have some new models. I've given them all some different options and made sure none of the arms are on the body they're 'assigned' to. Take that gw, arms can go on any body and look great! Almost like there wasn't any need to lock down the options like you did.... Anyway, I'll be combining these 5 with 5 of my existing marines to form a 10 man team that complies with the excessively rigid loadout rules. Oh and there's also a terminator chaplain I've converted out of the leviathan captain. Hope you like them all! I've been meaning to change some intercessors to infernus marines anyway as I've got enough intercessors and I want to represent infernus marines in my watch fortress. Problem with that was, I'm really up against the limit of dudes I can have in the fortress going off the lore (I've got a spreadsheet, it's a whole thing). For the same reason I'm making some of my assault intercessors into jump intercessors. I may further change those into primaris vanguard veterans when they inevitably turn up. Lord_Ikka 1 Back to top Link to comment https://bolterandchainsword.com/topic/382266-inquisitor-trinitys-retinue-new-deathwatch-181225/#findComment-6147534 Share on other sites More sharing options...
