Kloros Endall Posted March 1, 2024 Share Posted March 1, 2024 As stated in the title, do grenade harness rules confer to an attached squad? Specifically I want to run Abaddon with a squad of Lightning Claw Justaerin. Do I need to purchase a 2nd grenade harness for the squad to get the initiative mitigation charging into cover? Link to comment https://bolterandchainsword.com/topic/382437-do-the-grenade-harness-rules-confer-to-a-squad/ Share on other sites More sharing options...
Solution Agramar_The_Luna_Wolf Posted March 1, 2024 Solution Share Posted March 1, 2024 (edited) No. Look: "A unir that at least include one model..." With one is more than enough. Edited March 2, 2024 by Agramar_The_Luna_Wolf Better pic Bear 1 Back to top Link to comment https://bolterandchainsword.com/topic/382437-do-the-grenade-harness-rules-confer-to-a-squad/#findComment-6025678 Share on other sites More sharing options...
Kloros Endall Posted March 2, 2024 Author Share Posted March 2, 2024 Happy days, thanks mate. That 10 points is going into another fist on one of the other squads :) Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/382437-do-the-grenade-harness-rules-confer-to-a-squad/#findComment-6025681 Share on other sites More sharing options...
Bear Posted March 22, 2024 Share Posted March 22, 2024 The above is spot on :-) However, it should be said that if you loose / detach the model with the grenade harness, the squad would loose the ability. I.e. if Abaddon somehow managed to die first / decides to leave the squad for whatever reason, the Justaerins would loose the rule in that situation. I only bring it up as have had my Praetor sniped before and then had to remember that his rules that affected the whole squad were now gone even though I had built him and his squad as “1 unit” in my mind :-P Link to comment https://bolterandchainsword.com/topic/382437-do-the-grenade-harness-rules-confer-to-a-squad/#findComment-6029831 Share on other sites More sharing options...
