tagsta Posted April 1 Share Posted April 1 (edited) the List is themed around delivering an ALPHA STRIKE & wreak Havoc. The ROW, combined with Dynat & MoS allow a lot of flexibility for different scenarios. I designed the list to face competitive players & attend competitive events.STRATEGY: Dynat Gives Infiltrate, Scout or Outflank to: - Himself, Retinue & LR - Dark Furies - A Tactical Squad 1) Fire Support Elements (Scorpius, Sicaran, Conversion Beam Contemptor) deploy in the back. 2) Proteus Speeders will hunt Armour and can be held in Reserve & Deep Strike or Outflank if needed. 3) Melta Contemptors Push Forward alongside one non-infiltrating Tac Squad 4) Recon & Tacticals Infiltrate 5) Recon Company ROW will enable High Chances to Get First Turn (Alpha Strike) 6) Nemesis Bolter Recon Squads Pin Squads or Snipe out Characters & the large number of Nuncio Voxes help with Scatter Dice for all Template Weapons. 7) After First Turn, Dynat & the Dark Furies will aim for Close Combat, supported by Shotgun Recons. Both Command Squad & Furies should be able to deal with most Elite Units. 8) Master of Signal either helps my Reserve Rolls or turns on Disruptor if Opponent heavily relies on Reserves.Feedback welcome Legiones Astartes 3.242 Armillus Dynat 185 Rite of War (Legion Recon Company) Retinue Command Squad (5 Man, Infiltrates Alongside Dynat in Transport) • Tartaros Terminator Command Squad 245 Standard Bearer (thunder hammer), 4 Chosen, 4× thunder hammer • Land Raider Proteus 235 hull-mounted twin-linked lascannon Master of Signals 95 ------------------- TROOPS Reconnaissance Squad 165 (10 Man) Reconnaissance Sergeant (Astartes shotgun), 9 Reconnaissance Marines, 9× Astartes shotgun, nuncio-vox, augury scanner Reconnaissance Squad 135 (5 Man to be joined by MoS) Reconnaissance Sergeant (Nemesis bolter), 4 Reconnaissance Marines, 4× Nemesis bolter Reconnaissance Squad 177 (6 Man) Reconnaissance Sergeant (Nemesis bolter), 5 Reconnaissance Marines, 5× Nemesis bolter, nuncio-vox, augury scanner Tactical Squad 110 (Will receive Infiltrate) Tactical Sergeant (artificer armour), 9 Tactical Space Marines • Rhino 65 pintle-mounted multi-melta Tactical Squad 110 (Deploys normally) Tactical Sergeant (artificer armour), 9 Tactical Space Marines • Rhino 65 pintle-mounted multi-melta ------------------- ELITES Contemptor Dreadnought Talon • Contemptor Dreadnought 195 Gravis melta cannon, Gravis power fist (graviton gun) • Contemptor Dreadnought 195 Gravis melta cannon, Gravis power fist (graviton gun) Contemptor Dreadnought Talon (Deploys in Back Field) • Contemptor Dreadnought 225 2× conversion beam cannon, helical targeting array ------------------- FAST ATTACK Proteus Land Speeder Squadron • Land Speeder 85 pintle-mounted graviton gun, hull-mounted graviton gun • Land Speeder 85 pintle-mounted graviton gun, hull-mounted graviton gun • Land Speeder 85 pintle-mounted graviton gun, hull-mounted graviton gun Dark Fury Assault Squad 335 (10 Man, will receive Infiltrate) 3x Chooser of the Slain (melta bombs), 7x Dark Furies ------------------- HEAVY SUPPORT Scorpius Squadron 15 • Scorpius Tank 105 • Scorpius Tank 105 Sicaran Arcus Squadron 15 • Sicaran Arcus Strike Tank 210 two sponson-mounted lascannons Edited April 1 by tagsta Link to comment Share on other sites More sharing options...
Ripper.McGuirl Posted April 1 Share Posted April 1 Looks like a lot of fun. My only tip would be to think about deepstriking the furies instead of infiltrating them. They can’t charge the turn they infiltrate so they’re just going to be nice fat targets on the board first turn. If you can pin their target with your nemesis rifles, you can deepstrike and charge turn 2. Other than that, it sounds great! I like the tartaros command squad as well, I’m working on one myself and have been liking command squads in general. Link to comment Share on other sites More sharing options...
tagsta Posted April 2 Author Share Posted April 2 15 hours ago, Ripper.McGuirl said: Looks like a lot of fun. My only tip would be to think about deepstriking the furies instead of infiltrating them. They can’t charge the turn they infiltrate so they’re just going to be nice fat targets on the board first turn. If you can pin their target with your nemesis rifles, you can deepstrike and charge turn 2. Other than that, it sounds great! I like the tartaros command squad as well, I’m working on one myself and have been liking command squads in general. good suggestion regarding furies! thank you Ripper.McGuirl 1 Back to top Link to comment Share on other sites More sharing options...
