Usernamesareannoying Posted April 3, 2024 Share Posted April 3, 2024 any input on which to take on the kyn? Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/ Share on other sites More sharing options...
AutumnEffect Posted April 4, 2024 Share Posted April 4, 2024 Some quick maths for a unit of 10 with no other considerations.10 Bolters vs... T 3 5+ armour: 4.44 wounds T 3 4+ armour: 3.33 wounds T 5 6+ armour: 2.78 wounds T 4 4+ armour: 2.5 wounds T 4 3+ armour: 1.67 wounds T 5 2+ armour 4+ invuln: .56 wounds10 Ion Blasters vs... T 3 5+ armour: 3.33 wounds T 3 4+ armour: 2.78 wounds T 5 6+ armour: 2.5 wounds T 4 4+ armour: 2.78 wounds T 4 3+ armour: 2.22 wounds T 5 2+ armour 4+ invuln: 1.25 wounds This obviously doesn't take into account range, but (unsurprisingly) as armour saves increase, the Ion Blaster becomes the superior option. The biggest outliers were in the 'Guard' profile (T 3 5+) where the Bolters had a significant edge and the Custodes (T5 2+ 4+ invuln) where it was the Ions that had the bigger edge. My takeaway is that it's pretty much a wash with the Bolters having an edge with an extra 6" of range but the Ions being broadly more useful against more threatening units and especially vehicles. Dr. Clock, Dr_Ruminahui and Zoatibix 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6031909 Share on other sites More sharing options...
Montoya Posted April 16, 2024 Share Posted April 16, 2024 Something wrong in your math there, either that or there is in mine. (didn't check them all) but as an example ion blasters on T5 6+ armour: 10 shots hit 6.7 times (assuming you're hitting on 3's Wound T5 on 4's so 3.35 wounds. No save for 6+ armour due to the Ap-2 bolters on T5 6+ armour 20 shots hit 13.4 times Wound on 5's so 4.422 times. Save on 6's so say 3.69 wounds What am I missing? did you assume they don't all have bolters/ion blasters? Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6034906 Share on other sites More sharing options...
Guest Triszin Posted April 19, 2024 Share Posted April 19, 2024 I like ion over bolters, cause rule of cool Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6035509 Share on other sites More sharing options...
AutumnEffect Posted April 24, 2024 Share Posted April 24, 2024 On 4/16/2024 at 6:00 PM, Montoya said: Something wrong in your math there, either that or there is in mine. (didn't check them all) but as an example ion blasters on T5 6+ armour: 10 shots hit 6.7 times (assuming you're hitting on 3's Wound T5 on 4's so 3.35 wounds. No save for 6+ armour due to the Ap-2 bolters on T5 6+ armour 20 shots hit 13.4 times Wound on 5's so 4.422 times. Save on 6's so say 3.69 wounds What am I missing? did you assume they don't all have bolters/ion blasters? I didn't assume they were hitting on 3's. In my example I said "Some quick maths for a unit of 10 with no other considerations." The math is correct with them hitting on 4+. Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6036456 Share on other sites More sharing options...
Dr. Clock Posted April 24, 2024 Share Posted April 24, 2024 On one unit? Doesn't matter. 2 units? 1 of each. 3 units? Doesn't matter - for me it's 2 bolters because two of them are backfield/ far flank campers and the range matters. 4? Back to 2 of each... but nobody is realistically taking 4. Probably. Most comp lists seem to take 1, maybe two if going full Sagitaur spam. I take 3 ; ) Cheers, The Good Doctor. Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6036534 Share on other sites More sharing options...
Montoya Posted May 3, 2024 Share Posted May 3, 2024 On 4/24/2024 at 1:22 AM, AutumnEffect said: I didn't assume they were hitting on 3's. In my example I said "Some quick maths for a unit of 10 with no other considerations." The math is correct with them hitting on 4+. Got it. That makes sense then. Link to comment https://bolterandchainsword.com/topic/382639-leagues-of-votann-blasters-vs-bolters/#findComment-6038192 Share on other sites More sharing options...
