Phantomworks Posted April 7, 2024 Share Posted April 7, 2024 (edited) Killteam Nightmare sold out already and I missed it as usual. Will the Nightlords be available separately at some stage? Edited April 7, 2024 by Phantomworks Link to comment https://bolterandchainsword.com/topic/382663-will-kt-nightlords-be-released-separately/ Share on other sites More sharing options...
spiros14 Posted April 7, 2024 Share Posted April 7, 2024 It should do. Even the generic legionnaires upgrade from last season is still on the GW website. I suspect that you have missed out on the special Night Lords tokens, but the minis themselves are bound to be in their own box a month or two from now, perhaps even alongside the CSM codex set to release for 40k. Link to comment https://bolterandchainsword.com/topic/382663-will-kt-nightlords-be-released-separately/#findComment-6032504 Share on other sites More sharing options...
Phantomworks Posted April 7, 2024 Author Share Posted April 7, 2024 Tjx, but the tokens are not required to play, correct? Link to comment https://bolterandchainsword.com/topic/382663-will-kt-nightlords-be-released-separately/#findComment-6032544 Share on other sites More sharing options...
Solution spiros14 Posted April 7, 2024 Solution Share Posted April 7, 2024 I've only played a few games myself, but you do need at least conceal and engaged tokens to play - these are markers you can get pretty much anywhere or make yourself. At the start of each round, you declare which model will be "concealed", meaning they're ducking behind cover and otherwise keeping out of sight to the enemy, or "engaged" meaning they're intent on shooting or attacking the enemy in close quarters. If you're concealed you cannot attack but you cannot be attacked except in certain circumstances, and if you're engaged you can attack but you're fair game to everyone else. Because of that dynamic it's important to mark it out clearly so you and your opponent know who is doing what. The tokens are also double sided, allowing you to mark who has activated and who still has to go during the battle round. Again, you don't need the special tokens found in the Nightmare box for this, the tokens are pretty generic and there are plenty of third party manufacturers who can print these tokens out for you if you want them. Dr_Ruminahui and Phantomworks 2 Back to top Link to comment https://bolterandchainsword.com/topic/382663-will-kt-nightlords-be-released-separately/#findComment-6032634 Share on other sites More sharing options...
Phantomworks Posted April 10, 2024 Author Share Posted April 10, 2024 Thank you for the helpful reply. Appreciated. Link to comment https://bolterandchainsword.com/topic/382663-will-kt-nightlords-be-released-separately/#findComment-6033335 Share on other sites More sharing options...
