NiceGuyAdi Posted April 16, 2024 Share Posted April 16, 2024 (edited) I've started running Vallejo primer through my airbrush. I've read a few comments around that it's no good, and that it scratches off very easily. Sure enough, with only a little pressure from a fingernail, I've found this on the latest batch I've primed, which I'd left for several days to cure. What I wonder is: is this a problem? Is the primer just a "tooth" layer, for the acrylic paint to bond to, or should it be tough enough to take some abuse? Edited April 16, 2024 by NiceGuyAdi additional info Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/ Share on other sites More sharing options...
Firedrake Cordova Posted April 16, 2024 Share Posted April 16, 2024 (edited) I suppose the obvious questions are: is it likely the model had any surface contaminants on it which may have prevented bonding, was it fully mixed, and how thick was the primer layer? I use Vallejo's surface primer through an airbrush, and can't say I've not had a problem with it. I know that at least some historical modellers use the Vallejo primer and sand it without issues. I don't know if Miniac and MiniJunkie's videos are helpful or not? Edited April 16, 2024 by Firedrake Cordova NiceGuyAdi 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034615 Share on other sites More sharing options...
NiceGuyAdi Posted April 16, 2024 Author Share Posted April 16, 2024 Those videos are helpful. It's likely because I'm thinning the primer. MiniJunkie was saying he sprays at ~40psi, but my cheapo brush only goes to ~20psi (and that's what the manufacturer says). I'll give another go of priming undiluted, but if that fails because it's clogging, then it looks like I'm back to car primer in rattle cans. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034644 Share on other sites More sharing options...
Firedrake Cordova Posted April 16, 2024 Share Posted April 16, 2024 If it's any help, I add some flow improver to prevent clogging and spray it at ~1.8bar with a 0.4mm (H&S) needle. I try to get a reasonably thin coat on, and then go over it again. NiceGuyAdi 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034664 Share on other sites More sharing options...
andes Posted April 16, 2024 Share Posted April 16, 2024 I stopped using Vallejo primer for this reason... I just found it too unreliable. I know many people swear by it but I've been let down too many times. I'm using Stynylrez now, but recently picked up a bottle of Monument to experiment with. Magos Takatus, Firedrake Cordova and NiceGuyAdi 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034670 Share on other sites More sharing options...
Bryan Blaire Posted April 16, 2024 Share Posted April 16, 2024 I’ve had similar results with Vallejo primer as well. I would wash the plastic with soap and water, dry it thoroughly, and then assemble. No matter what, the Vallejo would peel off with just a bit of rubbing from a finger or nick with a nail, usually on prominent parts of the model. Like andes, I also made a switch to Stynylrez and Monument Hobbies. I found the Stynylrez was also rubbing off by itself, so I’ve found the best results for me have been a thin primer coat, then a thin matte varnish coat, then another thin primer coat - this seems to either become tough enough or just has enough layers that rubbing/nicks don’t seem to appear. I can’t say if the Monument primer is any better for single coat applications because I’ve taken to applying all my airbrushed primer coats in the above fashion, but no matter what, it works for me and I’m not seeing what I would consider loss of detail, so I am likely to keep doing it. andes 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034726 Share on other sites More sharing options...
andes Posted April 16, 2024 Share Posted April 16, 2024 (edited) I think airbrush primers are more delicate by nature. My models don't see a huge amount of table time so I'm fine with it, but if I'm painting terrain I always use rattlecan primer. One of my favorite things about Stynylrez is the dry time. It's ready to take paint after ~20 mins. Edited April 16, 2024 by andes Department of Redundancy Department LameBeard, tinpact and NiceGuyAdi 3 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034749 Share on other sites More sharing options...
Ayatollah_of_Rock_n_Rolla Posted April 16, 2024 Share Posted April 16, 2024 Yes, acrylic primers are more delicate by nature. The main reason people use them is the same reason, why people use acrylic paints for airbrush - less irritating in not so well ventilated spaces. Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6034765 Share on other sites More sharing options...
NiceGuyAdi Posted April 21, 2024 Author Share Posted April 21, 2024 So much useful info comes out of this place. Thanks all. On 4/16/2024 at 3:01 PM, Firedrake Cordova said: If it's any help, I add some flow improver to prevent clogging and spray it at ~1.8bar with a 0.4mm (H&S) needle. I try to get a reasonably thin coat on, and then go over it again. Just by way of update: Switching from using airbrush thinner, to airbrush flow improver, with the primer has made a massive difference both in coverage and usability without it clogging. W.A.Rorie, Bryan Blaire, Urauloth and 2 others 2 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6035954 Share on other sites More sharing options...
Firedrake Cordova Posted April 22, 2024 Share Posted April 22, 2024 Good to hear Link to comment https://bolterandchainsword.com/topic/382719-vallejo-surface-primer-problem/#findComment-6036119 Share on other sites More sharing options...
