Sir Clausel Posted May 15, 2024 Share Posted May 15, 2024 (edited) I have seen some comparisons. But im more interested to know if the height difference is mostly in the legs or torso area(or anywhere else for that matter) Can someone who has both say anything regarding this? Edited May 15, 2024 by Sir Clausel crimsondave 1 Back to top Link to comment https://bolterandchainsword.com/topic/382927-height-difference-between-new-mk-3-and-primaris/ Share on other sites More sharing options...
Terminatorinhell Posted May 15, 2024 Share Posted May 15, 2024 This was something I found. Hopefully it helps out. When I get home I can take some pics of my primaris and MKIII if you need Firedrake Cordova and Sir Clausel 2 Back to top Link to comment https://bolterandchainsword.com/topic/382927-height-difference-between-new-mk-3-and-primaris/#findComment-6040762 Share on other sites More sharing options...
Solution crimsondave Posted May 15, 2024 Solution Share Posted May 15, 2024 (edited) That’s the new Mk 3 with the old head on it. It’s closer than you’d think. The height difference is the legs. The power pack sits higher up so that doesn’t really count. Edited May 15, 2024 by crimsondave phandaal, Firedrake Cordova, Sir Clausel and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/382927-height-difference-between-new-mk-3-and-primaris/#findComment-6040804 Share on other sites More sharing options...
Sir Clausel Posted May 16, 2024 Author Share Posted May 16, 2024 (edited) 13 hours ago, Terminatorinhell said: This was something I found. Hopefully it helps out. When I get home I can take some pics of my primaris and MKIII if you need Yeah this was the one i have also seen. Its just a bit difficult to see where exactly the difference is. But thank you! 9 hours ago, crimsondave said: That’s the new Mk 3 with the old head on it. It’s closer than you’d think. The height difference is the legs. The power pack sits higher up so that doesn’t really count. Yeah this one helps alot. I can clearly see the legs are shorter. But then again it aint a big difference overall. Edited May 16, 2024 by Sir Clausel Firedrake Cordova and crimsondave 2 Back to top Link to comment https://bolterandchainsword.com/topic/382927-height-difference-between-new-mk-3-and-primaris/#findComment-6040848 Share on other sites More sharing options...
