crimsondave Posted May 15, 2024 Share Posted May 15, 2024 Like for these….. When I try to freehand that small it just looks terrible, and I’m sick of avoiding using them. Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/ Share on other sites More sharing options...
Grotsmasha Posted May 15, 2024 Share Posted May 15, 2024 A super-fine tip marker and just write it on, all fancy like. crimsondave, Khulu, Firedrake Cordova and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6040821 Share on other sites More sharing options...
crimsondave Posted May 16, 2024 Author Share Posted May 16, 2024 1 hour ago, Grotsmasha said: A super-fine tip marker and just write it on, all fancy like. I guess I should try that. My hand writing is trash but if I take my time maybe I can pull it off. Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6040825 Share on other sites More sharing options...
Solution Cleon Posted May 16, 2024 Solution Share Posted May 16, 2024 I got a sheet from a kickstarter a while back - I don't use it very often as de-glossing the transfer was more work than I felt it merited, but I can't knock the quality. https://www.etsy.com/uk/listing/1228268308/premium-ultra-detailed-a5-waterslide?click_key=b738c3395fd4b8ce88e579133c5b394b6737a033%3A1228268308&click_sum=1144d18c&ref=shop_home_active_2&crt=1 crimsondave 1 Back to top Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6040857 Share on other sites More sharing options...
beefeb Posted June 17, 2024 Share Posted June 17, 2024 try forgottenchapters.eu or themightybrush.com or go onto facebook and look for skumb4g kustoms one of these guys will have whatever you could ask for in lettering Luthor on the mighty brush does a decal sheet with gothic lettering which is the exact size of the space and its an alphabet sheet so you can make up whatever words/names you require Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6045863 Share on other sites More sharing options...
sbarnby71 Posted June 18, 2024 Share Posted June 18, 2024 One word of caution, I use the Might Brush decals a LOT... there are very thin, so you need to be super careful applying them otherwise I find they can fold too easily and you can struggle to unfold them without tearing or just mushing them up completely. I'm not knocking the quality or anything, they are super detailed, just a bit fiddly to apply. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6046010 Share on other sites More sharing options...
Xenith Posted June 18, 2024 Share Posted June 18, 2024 On 5/16/2024 at 12:19 AM, Grotsmasha said: A super-fine tip marker and just write it on, all fancy like. Second this, I use a sakura micron pen, and just write in all caps. Powderfinger, Firedrake Cordova and Khulu 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6046013 Share on other sites More sharing options...
Jukkiz Posted June 19, 2024 Share Posted June 19, 2024 you always try first with water paints, the ones that kids use. Easy to wipe away if you make mistakes and you can use it as line when using acrylics later Link to comment https://bolterandchainsword.com/topic/382931-does-anyone-make-small-text-transfers-for-shoulder-pads/#findComment-6046296 Share on other sites More sharing options...
