Anon Posted May 19, 2024 Share Posted May 19, 2024 (edited) Hi, I am painting some scouts and want to paint the cloaks in the citadel color "death world forest". I want to try/learn wetblending and I think those cloaks are great for that. Now I am trying to find a good color to shade "death world forest". I tried several gw greens like caliban green but the color transition is too hard. It doesn't look very good. Does anyone knows a color that is similar to "death world forest" just a bit darker? It doesn't have to be a citadel color. And I don't want to use shades/washes. Edited May 19, 2024 by Anon Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/ Share on other sites More sharing options...
Grotsmasha Posted May 19, 2024 Share Posted May 19, 2024 If you already have those two greens, I'd recommend mixing Deathworld Forest into Caliban Green, maybe start at 50:50, then adjust lighter/darker depending on your preference. jaxom 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6041720 Share on other sites More sharing options...
Urauloth Posted May 20, 2024 Share Posted May 20, 2024 I'd look at castellan green. Like deathworld forest, it's an earthtone green (Caliban is a much more verdant green) and it should work well. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6041760 Share on other sites More sharing options...
Firedrake Cordova Posted May 20, 2024 Share Posted May 20, 2024 Formula P3 Thornwood Green might be worth a look, although it might be "too dark" and require mixing in with the Deathworld Forest. Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6041774 Share on other sites More sharing options...
Anon Posted May 20, 2024 Author Share Posted May 20, 2024 Thanks, I will try it out. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6041798 Share on other sites More sharing options...
Cleon Posted May 20, 2024 Share Posted May 20, 2024 Vallejo have a selection of really nice realistic/historical camo greens, so if you have a store that stocks them I'd suggest going in and having a browse - be aware they do refract slightly different from GW paints though so might look a bit odd as a shade if you don't put a varnish over to unify that. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6041910 Share on other sites More sharing options...
Mithrilforge Posted May 21, 2024 Share Posted May 21, 2024 I painted my Orks skin in death world forest, and I painted my T”AU pathfinder’s fatigues in it as well… I used castellan green as the base, Athonian camo wash, then layered on - Death world forest, highlights were - Elysian green then ogryn camo . M Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6042007 Share on other sites More sharing options...
Wolf Lord Duregar Posted May 22, 2024 Share Posted May 22, 2024 Seen that, right? Mithrilforge and Bouargh 2 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6042254 Share on other sites More sharing options...
jaxom Posted May 22, 2024 Share Posted May 22, 2024 (edited) I agree with @Grotsmasha. Wetblending often requires intermediate mixes of the colors you're working with in addition to feathering out (aka blending) the initial colors into each other. @Wolf Lord Duregar's chart shows the three layer-style painting colors required, but you'd end up with five in a wetblend: Deathworld Forest, feathered into a ... ... 50/50 mix of Deathworld Forest and Elysian Green, feathered into... ... Elysian Green, feathered into... ... 50/50 mix of Elysian Green and Ogryn Camo, feathered into... ... Ogryn Camo Such a process gives greater control over the color gradation. EDIT: Forgot to mention, Deathworld Forest is a base color for Elysian Green, so the overall look will read as Elysian Green. If you want Deathworld Forest as the read, then your base color should be darker. @Urauloth and @MithrilForge both recommended Castallen Green and I agree with them. Edited May 22, 2024 by jaxom Wolf Lord Duregar and Mithrilforge 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6042272 Share on other sites More sharing options...
Anon Posted May 23, 2024 Author Share Posted May 23, 2024 19 hours ago, jaxom said: I agree with @Grotsmasha. Wetblending often requires intermediate mixes of the colors you're working with in addition to feathering out (aka blending) the initial colors into each other. @Wolf Lord Duregar's chart shows the three layer-style painting colors required, but you'd end up with five in a wetblend: Deathworld Forest, feathered into a ... ... 50/50 mix of Deathworld Forest and Elysian Green, feathered into... ... Elysian Green, feathered into... ... 50/50 mix of Elysian Green and Ogryn Camo, feathered into... ... Ogryn Camo Such a process gives greater control over the color gradation. EDIT: Forgot to mention, Deathworld Forest is a base color for Elysian Green, so the overall look will read as Elysian Green. If you want Deathworld Forest as the read, then your base color should be darker. @Urauloth and @MithrilForge both recommended Castallen Green and I agree with them. Thank you all for responding. I see that I have a lot to learn and I found a lot of your post very helpful. With intermediate mixes the results are very good. I did Castellan Green into Deathworld forest into Elysian Green. Mithrilforge, jaxom, Grotsmasha and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6042380 Share on other sites More sharing options...
Firedrake Cordova Posted May 23, 2024 Share Posted May 23, 2024 Good to hear Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/382964-what-color-to-use-to-shade-death-world-forest/#findComment-6042384 Share on other sites More sharing options...
