ThePenitentOne Posted May 20 Share Posted May 20 (edited) There are two large continents on Orison's Wake, in addition to a handful of islands that are too small to support agriculture. The larger continent, Farrow, supports the planet's capital city as well as four smaller STC settlements. The smaller continent, Lodi, supports four STC settlements, but lacks a larger city. Each settlement consists of 25 territories arranged in a 5 x 5 array. The center row and column are reserved for territories under Imperial control. each settlement has an Imperial Guard Garrison at the center of it's territory, and the settlement's reservoir and power facility will also always be located in Imperial Territory. Remain territories in the Imperial Zone are generated randomly from the Imperial Territory Table. This arrangement leaves four corner areas consisting of four territories each. These are each controlled by a random Thresher House; the outside corner of the map will contain the corresponding Thresher House territory. This is a special Hab Block where every resident is a member of one of the noble Thresher Houses. The remaining three territories in each corner area of the map are randomly generated from the territory table of their controlling house. The Settlements of Lodi: The Settlements of Farrow Edited May 20 by ThePenitentOne Link to comment Share on other sites More sharing options...
