oldhat Posted May 28 Share Posted May 28 Acastus Knight Porphyrion w/ Lascannons, Hyperios, Implacable Crusader w/ Meltagun, Stormspear, Preceptor Atrapos Seneshal 3x Helvering 2x Warglaive w/ Meltagun 1x Warglaive w/ Stubber Still trying to find a way to make it work, despite knowing the big boys are pretty terrible. Thoughts? Link to comment Share on other sites More sharing options...
Razorblade Posted May 31 Share Posted May 31 (edited) The Porphyrion is the only good unit in this faction and I think implacable is the correct rank for him. Keep him close to the seneschall and he'll be a nightmare to deal with. I think the Atropos is terribly overcosted and also lacks a Melee weapon to make use of the seneschalls WS5. I'd take an errant or Magaera instead. I like the addition of a thermal cannon knight but I think the avenger is not good enough to give up Melee for it. I think the third guy should be dolorous errant/castigator. Lastly you'll only ever need a single helverine, all your other armigers should be warglaives EDIT: A Mageara-seneschall, Errant-Dolorous and the Atrapos add up so that you can perfectly fit 7 armigers at 3000 points Edited May 31 by Razorblade Link to comment Share on other sites More sharing options...
oldhat Posted May 31 Author Share Posted May 31 7 hours ago, Razorblade said: The Porphyrion is the only good unit in this faction and I think implacable is the correct rank for him. Keep him close to the seneschall and he'll be a nightmare to deal with. I think the Atropos is terribly overcosted and also lacks a Melee weapon to make use of the seneschalls WS5. I'd take an errant or Magaera instead. I like the addition of a thermal cannon knight but I think the avenger is not good enough to give up Melee for it. I think the third guy should be dolorous errant/castigator. Lastly you'll only ever need a single helverine, all your other armigers should be warglaives EDIT: A Mageara-seneschall, Errant-Dolorous and the Atrapos add up so that you can perfectly fit 7 armigers at 3000 points How about this: Errant Seneschal Preceptor Atrapos Porphyrion Implacable Add Meltagun to third Warglaive 3/3 split 3k on the nose I still want to run Helverins. I've seen them do well in batreps and they look good on paper. 3/3 seems like a decent split - I can always tinker from there. Link to comment Share on other sites More sharing options...
Razorblade Posted June 1 Share Posted June 1 7 hours ago, oldhat said: How about this: Errant Seneschal Preceptor Atrapos Porphyrion Implacable Add Meltagun to third Warglaive 3/3 split 3k on the nose I still want to run Helverins. I've seen them do well in batreps and they look good on paper. 3/3 seems like a decent split - I can always tinker from there. The Atropos just isn't worth the cost and neither is the preceptor upgrade. I mean by all means try your lack but I can only vehemently advice against helverins. The only meaningful targets against which they reliably outperform the thermal spear are Recons and HSSs and that does not offset having no Melee and being unable to engage 2+ Saves and Land Raiders Link to comment Share on other sites More sharing options...
