Grotsmasha Posted June 2, 2024 Share Posted June 2, 2024 (edited) The B&C Presents: The Call to Arms 2024 HERESY STRONGHOLD What better way to celebrate a new edition of our favourite table-top wargame than to have a big Inter-Forum Painting Event, amiright? Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!! What is The Call to Arms, I hear you ask? The Call to Arms is a multi-forum event designed to encourage us all to start a new army, or bolster our current forces. The Forums of the B&C are divided up into four Strongholds; The Imperium Stronghold Adepta Sororitas Adeptus Astartes Adeptus Mechanicus Astra Militarum Imperial Knights Talons of the Emperor The Imperium of Mankind The Chaos Stronghold Chaos Daemons Chaos Knights Heretic Astartes The Realms of Chaos The Xenos Stronghold Aeldari Drukhari Genestealer Cults Leagues of Votann Necrons Orks T'au Empire Tyranids The Heresy Stronghold Loyalists OR Traitors Legions Imperialis Adeptus Titanicus The Horus Heresy These four Strongholds will act as the hub for each of the four main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the three other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the four Strongholds will face off, and overall winners will be declared. Start Date: 15th JUNE 2024 End Date: 17th SEPTEMBER 2024 (Timezone will be GMT +10, please make local adjustments for time) So, how is it all going to work? As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all four Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds. Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models from the Other Games Forum (Aeronautica, Kill Team, Necromunda), these models / units may be pledged to any Stronghold. You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow. In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed. Once recorded, Vows may not be altered, however special considerations may be made upon request. There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted. How do I join in? Each model has a point value based upon it's size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below, 1pt Infantry 2pts Cavalry/Bikers/Heavy Weapons Teams 3pts Walkers (Dreadnaughts, Sentinals) 4pts Skimmers / Light Vehicles (Landspeeders, ATV, Armigers) 5pts Small Tanks (Leman Russ, Rhino Variants) 6pts Large Tanks (Rogal Dorn, Sicaran, Land Raider) 8pts Superheavies (Baneblades etc) 10pts Imperial Knight etc 5pts Leader and Unit Composition: 1 OR Epic Hero 10pts Primarchs NOTE: Characters with Retinue, I.E. Saint Celestine. Celestine is the EPIC HERO, and is worth 5pts, her two Sister Superiors are Seraphim, which are worth 1pt each. 20pts Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Legions Imperialis / Adeptus Titanicus Scale 1pt Infantry Base, Dreadnaught Base, Rapier Base, Jetbike/Speeder Base, Sentinal Base, Rhino, Predator, Medusa, Leman Russ, Drop Pod 2pts Sicaran, Land Raider, Spartan, Malcador, Armiger Knights, Questoris Knights, Ceratus KInights 3pts Fellblade Chassis tanks, Kratos Battletank, Baneblade Chassis tanks, Arcastus Knights, LI/AI Aircraft* 4pts Thunderhawk Gunship 5pts Warhound Titan 6pts Reaver Titan 7pts Warbringer Titan 8pts Warlord Titan 10pts Warmaster Titan 5pts Leader and Unit Composition: Command Base *I am super unfamiliar with the Aeronautica Craft, so please let me know if there need to be more points gradings for the different Aircraft* Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to either The Emperor OR The Warmaster. Please make your vows in this thread in the following format; "I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of {insert Emperor/Warmaster} and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end." example; I, Grotsmasha, heed the Call to Arms and pledge to paint 20 Legionaires, 3 Outriders, 1 Consul, and 1 Contemptor Dreadnought for 34pts for the Glory of the Emperor and the Heresy Stronghold on or before September 17th, or bear the badge of failure until year's end." The post that contains your Vow must include starting pictures that contain all the models from the Vow. Starting models may be in any of the following conditions; In the box On the Sprue Assembled Single Colour Primed For Tanks / Titans, Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour. Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so. Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation. Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow, please post these within Spoiler / Hidden tags. Once you have made your vow, pop this badge of Participation into your Signature, Will there be any awards? Yes!! There will be similar Badges and Achievements available from all 4 Strongholds, Event Failed: Servitor 10 points: Legionaire25 points Sergeant 45 points: Consul75 points: Praetor100+ points: Master of the Legion Artificer - Top 1, 2, and 3 best painted models from each Forum, chosen by the Moderators. Princeps - Awarded to all completed Titans Heresy Champion - Awarded to the Frater who individually paints the most points worth of models in the Heresy Stronghold Champions of the Horde - The Faction with the highest overall points worth of models Champion of the Call - The Faction that has the Highest Participation vs. Completion Percentage. As to the overall competition between the Strongholds, there will also be Badges awarded for the following; Masters of the Horde - The Stronghold that completes the highest overall points worth of models. Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage. Master Artificer - Voted best painted Model, chosen from the 4 Stronghold Artificers. In addition to the Badges and Achievements above, there will be additional Awards for the following 4 categories. At this stage there are no physical prizes like last year, but that *MAY* change by the end of the Event. Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so within their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool.. Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so within their Vows. Stronghold Artificer - Awarded to four Participants, one from each Stronghold for the Best Painted Model in from the Stronghold, chosen by the Frater via Poll. Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds That's it, you've done it, you've made it to the end!!! If you have any questions or queries, just @Grotsmasha and I'll be more than happy to help you out, now, go on, get, don't you have models to be painting? F.A.Q.s Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians? A- Yes, this is acceptable. Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos? A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum. Q- Are 3D prints allowed? A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent. Edited June 2, 2024 by Grotsmasha Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/ Share on other sites More sharing options...
Grotsmasha Posted June 2, 2024 Author Share Posted June 2, 2024 (edited) PARTICIPANTS The Emperor - Pledged: 886pts / Complete: 764pts / Secured: 764pts / 86.3% Completion Participants: 8 firestorm40k - Vow 1: 18pts - Completed | Spoiler Castellan (5) 10 Cataphractii (10) Contemptor Dreadnought (3) GodEmperorOfMankind - Vow 1: 121pts - Completed | Spoiler 10 Tactical Legionnaires (10) 10 Tactical Support Legionnaires (10) 10 Breachers (10) 10 Siege Tyrants (10) 10 Heavy Support Legionnaires (10) 10 Iron Havocs (10) 5 Recon Legionnaires (5) 5 Apothecaries (25) 2 Master of Signals (10) 1 Landraider Proteus (6) 1 Landraider Spartan (6) 1 Kharibdys Assault Claw (6) 1 Iron Circle Automata (3) LokkoRex - Vow 1: 54pts - Completed | Spoiler 30 Imperialis Militia Grenadiers (30) 6 Imperialis Militia Field Ordnance Guns (24) Mandragola - Vow 1: 12pts - Completed | Vow 2: 71pts - Completed | Vow 3: 24pts - Completed | Spoiler 2 Veletarii (2) 5 Hermes Veletarii (10) Spoiler 10 Raven Guard Assault Legionaires (10) 8 [REDACTED] (8) 8 [REDACTED] (8) Imperial Fist tanks for LI: 7 Kratos (21) 6 Land Raiders (12) 6 assorted Sicarans (12) 10 Imperial Fist Contemptors (10) 6 White Scar Scimitar Jetbike bases (6) 4 Javelins (4) 4 Landspeeders (4) TheArtilleryman - Vow 1: 19pts - Completed | Vow 2: 36pts - Completed | 9 Tactical Legionaires, (9) 5 Veteran Legionaires, (5) 5 Heavy Bolter Legionaires (Out of Competition) (5)Master of the Forge - Company Champion (5) 1 Cataphractii Praetor (5) 10 tactical marines, (10) 10 Support Legionaires w/Volkite Calivers, (10) 5 Heavy Legionaires w/Lascannons, (5) 1 Landraider Proteus (6) time_of_flight - Vow 1: 12pts - Completed | Vow 2: 11pts - Completed | Spoiler 3 Jetbikes (6) 1 Land raider (6) Spoiler 5 Crimson Paladins (5) 1 Sicaran Battle (6) Sgt.Sharp - Vow 1: 214pts - Completed | Vow 2: 2pts - Completed | Vow 3: 170pts - Completed | Spoiler AoD: 148pts 1 Legate marshal (5 pts) Tactical Command section (5 pts) 60 Lasrifles (60 pts) 30 Veletari (30 Pts) 3 Aetheon Heavy sentinels (9 pts) 3 Leman Russ Strike tanks (15 pts) 3 Dracosans (18 pts) 1 Malcador (6 Pts) Legions Imperialis: 66pts 12 Russes (12 pts) 6 Malcadors (12 Pts) 2 Malcador Infurni (4 pts) 2 Valdors (4pts) 12 Basalisks (12 Pts) 4 Madusae (4 pts) 2 Hellhammers (6 Pts) 2 Reavers (12 pts) 1Cyclops Support Tank (2) 2 Solar Auxilia legate Marshals (10 pts) 1 twisted flesh militia force comander (5) 1 twisted flesh militia mounted force commander (5) 1 twisted flesh militia rogue psycher (5) 1 dominion zephon (jump pack preator) (5) 1 survivors of the dark age militia force commander (the inquisitor) 5pts 1 militia force commander (ripper jackson) (65) 1 white scars preator (5) 1 nightlords preator (5) 1 custodian shield captain (5) 1 vindicare assassin (5) 4 craters (12) 1 large sector imperialis building (8) 1 medium sector imperialis building, (4) 1 imperial bunker , (6) 10 white scars tactical marines (10) 10 white scars cataphractii terminators (10) WAR - Vow 1: 122pts - Not Completed | Spoiler 1 Cataphractii Praetor (5) 10 Deliverers (15) 10 Cataphractii Terminators (10) 1 Contemptor Dreadnought (3) 2 Sabres (10) 2 Vindicators (10) 1 Cerebus (6) 5 Predators (25) 3 Sicaran (18) 1 Spartan (6) 1 Kratos (6) 1 Storm Eagle (8) The Warmaster - Pledged: 487pts / Complete: 435pts / Secured: 308pts / 89.3% Completion Participants: 6 Dwango - Vow 1: 79pts - Completed | Vow 2: 208pts - Completed | Vow 3: 21pts - Completed | Spoiler Counts-as Khârn (5) 1 Centurion (5) 20 Despoilers (20) 5 Red Butchers (5) 5 Terminators (5) 5 Plasma Support Squad (5) 3 Rapier Batteries (9) 2 Contemptors (6) 1 Dreadnought (3) 2 Rhinos (10) 1 Spartan (6) Spoiler 1 Landraider (6pts) 3 Thallax (3pts) 10 Rampagers (10pts) 10 Tacticals (10pts) 1 Apothecary (1pts) 2 Servo Cranes (8pts) 4 Servo Haulers (8pts) 20 Pipe sections (40pts) 29 Columns (29pts) 16 Walls (32pts) 75 Railings (25pts) Ladders and Handrails (4pts) 8 Escape Drop pods (8pts) 2 Drop pod Banks (4pts) 2 Medicae Equipment (2pts) 6 Mini Generators (8pts) 5 Bins (5pts) 1 Generatorium Hub (5pts) 1 Praevian Consul (5) 2 Apothecaries (10) 6 thallax (6) LameBeard - Vow 1: 10pts - Completed | Spoiler 3 LI Land Raiders (6) 4 LI Rhinos (4) Lautrec - Vow 1: 46pts - Completed | Spoiler - 1 Champion Consul (5) - 10 MkVI Seekers (10) - 10 MkVI Terror Marines (10) - 3 Jetbikes (6) - 3 Predator Tanks (15) Lord Marshal - Vow 1: 52pts - Not Completed | Spoiler 10 Tactical Legionaries (28mm) (10) 16 Astartes Infantry Bases (Legions Imperialis) (16) 2 Astartes Command Bases (Legions Imperialis) (10) 4 Dreadnought Bases (Legions Imperialis) (4) 4 Kratos Heavy Tanks (Legions Imperialis) (12) Malice Jr. - Vow 1: 45pts - Completed | Spoiler 1 Warbringer Titan, (7) 1 Reaver Titan, (6) 3 Armiger Moirax Knights, (6) 18 Astartes Infantry bases, (18) 4 Contemptor Dreadnoughts, (4) 2 Sicaran Battle Tanks (4) Richmarine - Vow 1: 26pts - Completed | Spoiler 10 Sons of Horus Veterans (10) 5 Sons of Horus Recon Marines (5) 1 Sons of Horus Legion Deredeo Dreadnought (3) 1 Custom Isstvan III scenery (4x Aegis Defence Sections) (8) Edited December 1, 2024 by Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6043698 Share on other sites More sharing options...
Grotsmasha Posted June 2, 2024 Author Share Posted June 2, 2024 * NOTE: THIS THREAD WILL BE UNLOCKED AND OPEN FOR VOWS JUNE 15TH * Please take this time to check out your chosen Rally Point, look at the points values and plan your vows 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6043699 Share on other sites More sharing options...
W.A.Rorie Posted June 14, 2024 Share Posted June 14, 2024 (edited) I, WAR, heed the Call to Arms and pledge to paint: Contemptor Dreadnought Sabres x2 Predators x5 (3 need to be purchased) Vindicators x2 Sicaran x3 Spartan Kratos Cerebus Storm Eagle Cataphract Praetor Deliverers x15 Cataphractii Term x10 for 118pts for the Glory of Emperor and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. Edited June 15, 2024 by WAR Updated photos 7 3 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045469 Share on other sites More sharing options...
Dwango Posted June 14, 2024 Share Posted June 14, 2024 (edited) I, Dwango, heed the Call to Arms and pledge to paint 20 despoilers, 5 red butchers, 5 terminators, 5 plasma support squad, 3 rapier batteries, 2 contemptors, 1 boxnought, 2 rhinos, 1 Spartan, 1 centurion & a Khan proxy for 79pts for the Glory of the Warmaster and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. I'll post pics tomorrow at some point. Edited June 16, 2024 by Dwango Pic added 5 3 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045555 Share on other sites More sharing options...
Grotsmasha Posted June 15, 2024 Author Share Posted June 15, 2024 * UPDATED TO THIS POINT * 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045652 Share on other sites More sharing options...
firestorm40k Posted June 15, 2024 Share Posted June 15, 2024 I, firestorm40k, heed the Call to Arms and pledge to paint the following for 14 points, for the Glory of Lord Dorn and The Emperor, and the Heresy Stronghold, on or before 17th September 2024, or bear the badge of failure until years end. 2 x 5 Cataphractii Contemptor Dreadnought Castellan (Imperial Fists Centurion) (I think I've got the points right - the character doesn't have a retinue, so is only worth 1 point? ) I'm taking part in a Heresy event on 15th September, so the timing of this will certainly motivate me to be ready for it 2 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045661 Share on other sites More sharing options...
lokkorex Posted June 15, 2024 Share Posted June 15, 2024 I, LokkoRex, heed the Call to Arms and pledge to paint 30 Imperialis Militia Grenadiers and 6 Imperialis Militia Field Ordnance Guns for 30x1+6x3=48 points for the Glory of The Emperor and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045688 Share on other sites More sharing options...
Dwango Posted June 16, 2024 Share Posted June 16, 2024 @Grotsmasha just to clarify, it's khan the bloody not a primarch. Looking at the spelling it should read Khârn. Sorry. Should take me back down to 79pts. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6045713 Share on other sites More sharing options...
Lautrec the Embraced Posted June 18, 2024 Share Posted June 18, 2024 I, Lautrec the Embraced, heed the Call to Arms and pledge to paint: - 10 MkVI Seekers - 10 MkVI Terror Marines - 3 Jetbikes - 3 Predator Tanks, Nostramo Pattern (read - old recycled Baals with whatever weapons I managed to find) - 1 Champion Consul (he'll get some nicer base too) for 46 pts for the Glory of Night Haunter uhm, I mean our beloved Warmaster of course and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. 4 3 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046155 Share on other sites More sharing options...
time_of_flight Posted June 19, 2024 Share Posted June 19, 2024 (edited) I, time_of_flight, heed the Call to Arms and pledge to paint 3 Jetbikes and 1 Land raider for 18 pts for the Glory of the Emperor and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. Edited June 19, 2024 by time_of_flight 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046235 Share on other sites More sharing options...
Mandragola Posted June 19, 2024 Share Posted June 19, 2024 I, Mandragola, heed the Call to Arms and pledge to paint 5 Hermes Veletarii and two converted Veletarii (a command box and vexilla) for 12pts for the Glory of the Emperor and the Heresy Stronghold on or before September 17th, or bear the badge of failure until year's end. Here they are, along with one Hermes that I’ve done already for the goonhammer review. I’m counting the Hermes as 2 point cavalry because they’re quite little and that’s their unit type. I actually need to get this stuff ready for the coming weekend for the goonhammer open, so hopefully I’ll manage it! And after that maybe I’ll do some other stuff. 6 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046237 Share on other sites More sharing options...
SgtSharp Posted June 19, 2024 Share Posted June 19, 2024 (edited) (pictures will be added this evening) I Sgt.Sharp heed the call to arms and pledge to paint the following for the glory of The Emperor and the memory of burnt Prospero on or before September 17th, or bear the badge of failure until year's end. The List: 28mm: 60 Lasrifles (60 pts) 30 veletari (30 Pts) 5 man Tactical Command section ( 5 pts) 1 Legate marshal (5 pts, or 1, not sure how we are counting independant characters) 3 Aetheon Heavy sentinels (9 pts) 3 Leman Russ Strike tanks (5 each for 15 pts) 3 Dracosans (6 each for 18 pts) 1 Malcador (6 Pts) for 144 ot 148 pts, depending on the worth of the Legate Marshal. If I can add real quick, because I forgot to add: LI: 12 Russes (12 pts) 6 Malcadors: (12 Pts) 2 malcador infurni (4 pts) 2 Valdors (4) 12 Basalisks (12 Pts) 4 Madusae ( 4 pts) 2 Hellhammers ( 6 Pts) 2 Reavers (12 pts) for 66 points for a total if allowed of either 210 or 214 points, depending on a ruling on the legate marshal Edited June 19, 2024 by SgtSharp Its a good job my job doesn't require basic maths... oh wait 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046325 Share on other sites More sharing options...
GodEmperorOfMankind Posted June 19, 2024 Share Posted June 19, 2024 (edited) I, GodEmperorOfMankind, heed the Call to Arms and pledge to paint all of the below for 93 pts for the Glory of, umm, myself, and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. X10 tactical legionnaires X10 tactical support legionnaires X10 breachers X10 siege tyrants X10 heavy support legionnaires X10 iron havoc X5 recon legionnaires X5 apothecaries X2 master of signals X1 land raider proteus X1 land raider spartan X1 kharibdys assault claw X1 iron circle automata Obviously the kharibdys on the left, and I'll tell you know, it's gonna be a World eaters claw Edited June 19, 2024 by GodEmperorOfMankind Hadn't finished 6 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046356 Share on other sites More sharing options...
Grotsmasha Posted June 22, 2024 Author Share Posted June 22, 2024 * UPDATED TO THIS POINT * Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6046925 Share on other sites More sharing options...
Lautrec the Embraced Posted June 23, 2024 Share Posted June 23, 2024 @Grotsmasha, I believe there is a slight discrepancy regarding Jetbikes. I thought they are in 2 pts cavalry/bike category but in my pledge they are treated as 4 pts skimmer instead: On 6/2/2024 at 3:32 PM, Grotsmasha said: 3 Jetbikes (12) Meanwhile, for @time_of_flight they are indeed counted as 2 pts cavalry: On 6/2/2024 at 3:32 PM, Grotsmasha said: 3 Jetbikes (6) Could they be actually worth "d3+1" points? 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047078 Share on other sites More sharing options...
Grotsmasha Posted June 23, 2024 Author Share Posted June 23, 2024 52 minutes ago, Lautrec the Embraced said: @Grotsmasha, I believe there is a slight discrepancy regarding Jetbikes. I thought they are in 2 pts cavalry/bike category but in my pledge they are treated as 4 pts skimmer instead: Meanwhile, for @time_of_flight they are indeed counted as 2 pts cavalry: Could they be actually worth "d3+1" points? Not sure where the 12 even came from.... But you are correct they are 2pts each 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047085 Share on other sites More sharing options...
SgtSharp Posted June 23, 2024 Share Posted June 23, 2024 (edited) On 6/19/2024 at 7:54 PM, SgtSharp said: +snip= as promised, the picture proof of my stuffs, ready for me to start painting tomorrow, all out on parade, plus the malcador on my desk, because I forgot to take it downstairs for the picture sterling camera work on the infantry pictures as alway...., I do apologies, I'll make sure all my WIP abd the project finished pics are slightly less potato cam. Edited June 23, 2024 by SgtSharp self depreciation 5 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047119 Share on other sites More sharing options...
richmarine Posted June 23, 2024 Share Posted June 23, 2024 (edited) "I, Richmarine, heed the Call to Arms and pledge to paint the below models for {20pts} for the Glory of Warmaster and the Heresy Strongholdon or before 17th September 2024, or bear the badge of failure until years end." 10 Veteran marines of the sons of Horus legion 5 recon marines of the sons of Horus Legion 1 Deredeo Dreadnought of the sons of Horus Legion. 1 lot of custom isstvan III scenery. (Aegis defence line size) Edited June 23, 2024 by richmarine Pic of my corpse pile. 7 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047124 Share on other sites More sharing options...
LameBeard Posted June 23, 2024 Share Posted June 23, 2024 (edited) I, LameBeard, answer the Call to Arms and pledge 3 Land Raiders and 4 Rhinos for the glory of the Warmaster and the Heresy Stronghold, to be completed by 17 September or bear the badge of failure until year’s end. They are Epic Scale, so that’s 10 points. Yes I know the photo shows 5 rhinos, but I’m only pledging 4 of them. Edited June 25, 2024 by LameBeard Typo 5 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047129 Share on other sites More sharing options...
Malice Jr. Posted June 29, 2024 Share Posted June 29, 2024 I, Malice Jr., heed the Call to Arms and pledge to paint 1 Reaver Titan, 1 Warbringer Titan, 2 Sicarans, 3 Armiger Moirax Knights, 4 Contemptor Dreadnoughts, and 18 bases of Astartes infantry for 45pts for the Glory of the Warmaster and the Heresy Stronghold on or before September 17th, or bear the badge of failure until year's end. 8 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047949 Share on other sites More sharing options...
LameBeard Posted June 29, 2024 Share Posted June 29, 2024 2 hours ago, Malice Jr. said: I, Malice Jr., heed the Call to Arms and pledge to paint 1 Reaver Titan, 1 Warbringer Titan, 2 Sicarans, 3 Armiger Moirax Knights, 4 Contemptor Dreadnoughts, and 18 bases of Astartes infantry for 45pts for the Glory of the Warmaster and the Heresy Stronghold on or before September 17th, or bear the badge of failure until year's end. There was me looking at this picture thinking “but where’s the Warbringer?” 1 6 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6047955 Share on other sites More sharing options...
Grotsmasha Posted June 30, 2024 Author Share Posted June 30, 2024 * UPDATED TO THIS POINT * 1 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6048024 Share on other sites More sharing options...
W.A.Rorie Posted July 1, 2024 Share Posted July 1, 2024 hit another snag this weekend but tanks are all washed ready for primer 5 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6048163 Share on other sites More sharing options...
Mandragola Posted July 2, 2024 Share Posted July 2, 2024 (edited) On 6/19/2024 at 12:40 PM, Mandragola said: I, Mandragola, heed the Call to Arms and pledge to paint 5 Hermes Veletarii and two converted Veletarii (a command box and vexilla) for 12pts for the Glory of the Emperor and the Heresy Stronghold on or before September 17th, or bear the badge of failure until year's end. Here they are, along with one Hermes that I’ve done already for the goonhammer review. I’m counting the Hermes as 2 point cavalry because they’re quite little and that’s their unit type. I actually need to get this stuff ready for the coming weekend for the goonhammer open, so hopefully I’ll manage it! And after that maybe I’ll do some other stuff. Vow complete, check it out! I managed to get all these ready for the GHO last weekend. They performed pretty well, providing a Line unit that had reasonable firepower and durability for their cost. The radio guy and vexilla kind of existed too. My Raven Guard and Auxilia combo worked well and I won all four games. It was a really fun weekend and I got to play against a ruinstorm list and ZM for the first time too. Not sure if I’ll do another vow. I’m about to paint a kill team or four. Might do some sort of vows around those I suppose. Edit: all six of the aerials broke off the damn things over the course of the weekend. I’ll have to replace them with bristles or something. They’re cast too thin and snap all the time. Edited July 2, 2024 by Mandragola 7 2 Back to top Link to comment https://bolterandchainsword.com/topic/383034-the-call-to-arms-heresy-stronghold/#findComment-6048287 Share on other sites More sharing options...
