Grotsmasha Posted June 2, 2024 Share Posted June 2, 2024 (edited) What is The Call to Arms, I hear you ask? The Call to Arms is a new multi-forum event designed to encourage us all to start a new army, or bolster our current armies. The Forums of the B&C are divided up into four Strongholds; Imperium, Chaos, Xenos, and Heresy. For the next three months the Loyalists and Traitors of the Heresy Stronghold will be competing to claim Victory over the other Heresy Faction, with all four Strongholds being compared at the conclusion of the Event. There are two categories for Victory in both the Forums and Strongholds, the Forum/Stronghold who has painted the most points worth of models, and the Forum/Stronghold with the highest % of completion (Participants vs Completions). Full Rules and Place your Vow => The Heresy Stronghold Start Date: 15th June End Date: 17th September How do I join in? Models for The Call to Arms have been allocated a point value based around their size, the time they take to paint, and the amount of effort generally taken to paint them, this is why some models of different sizes appear in the same categories, and why Characters are worth more. The below list should cover every model for the Traitors; 1pt Scouts, PA mkII through mkVII, Terminators 2pts Bikes, Outriders, Jetbikes, Tarantula 3pts Rapier Teams, Land Speeders, Dreadnoughts 4pts Armiger Knights 5pts Nemesis Dreadknight, Rhino Chassis Tanks, Impulsor, Gladiators, Drop Pod, Anvillus Dreadclaw 6pts Xiphon, Sicaran Chassis Tanks, Landraiders, Spartans, Terrax Drill, Kharybdis Assault Claw 8pts Glaive, Fellblade, Falchion, Fire Raptor, Storm Eagle 10pts Mastadon, Questoris, Valliant, Castellan, and Cerastus Knights 5pts Leader and Unit Composition: 1 OR Epic Hero, Vigilator, Moritat, Techmarine, Apothecary, Consul, Centurions, Praetors 10pts All Primarchs 20pts Arcastus Knights, Warhound Titan, Thunderhawk 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan, Stormbird Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Legions Imperialis / Adeptus Titanicus Scale 1pt Infantry Base, Dreadnaught Base, Rapier Base, Jetbike/Speeder Base, Sentinal Base, Rhino, Predator, Medusa, Leman Russ, Drop Pod 2pts Sicaran, Land Raider, Spartan, Malcador, Armiger Knights, Questoris Knights, Ceratus KInights 3pts Fellblade Chassis tanks, Kratos Battletank, Baneblade Chassis tanks, Arcastus Knights, LI/AI Aircraft 4pts Thunderhawk Gunship 5pts Warhound Titan 6pts Reaver Titan 7pts Warbringer Titan 8pts Warlord Titan 10pts Warmaster Titan 5pts Leader and Unit Composition: Command Base *I am super unfamiliar with the Aeronautica Craft, so please let me know if there need to be more points gradings for the different Aircraft* Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Legionaires (1ptx20), 3 Outriders (2ptsx3), a Javelin (3pts), and a Praetor (5pts), your vow would be worth 34pts If you have any questions or queries, or there's a model you want to paint but isn't listed, just @Grotsmasha and I'll be more than happy to help you out. Please feel free use this thread as a place to share your thoughts, ideas, and WIPs throughout the Event to motivate and inspire the Traitors, and the Heresy to Victory!!! Full Rules and Place your Vow => The Heresy Stronghold Edited June 2, 2024 by Grotsmasha N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/ Share on other sites More sharing options...
Dwango Posted June 16, 2024 Share Posted June 16, 2024 So, it may just be me supporting the traitor cause however, here's my CtA vow; 20 despoilers 5 red butchers 5 terminators 5 plasma support squad 2 contemptors 1 boxnought 2 rhinos 1 Spartan 1 centurion Khan proxy I'm joint running a local slow grow event. It started in June. Because I'm being tight, I'm using CSM models that have sat in my pile of shame for ages to represent a weaters force at the siege of terra. This will ultimately ally with my dark mech force I've very nearly completed. I've got more to add to the above but this will see me through for a while. Lord Marshal, W.A.Rorie, Corswain and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6045742 Share on other sites More sharing options...
LameBeard Posted June 24, 2024 Share Posted June 24, 2024 I’ve joined the Warmaster this time. If the tiny purple tanks go well I’ve got some 28mm marines I could add for 2nd and 3rd pledges. Dwango, W.A.Rorie and Grotsmasha 3 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6047178 Share on other sites More sharing options...
richmarine Posted June 27, 2024 Share Posted June 27, 2024 Common. I can do this! LameBeard, Grotsmasha, Corswain and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6047699 Share on other sites More sharing options...
Lautrec the Embraced Posted June 28, 2024 Share Posted June 28, 2024 Progress so far - jetbikes assembled (very barebones, their shape is so weird i didn't know where to place trophies or spikes), everything primed and base coated and currently at various stages of dry brushing: Quite happy with the predators now that I see them in colour. They may not be Heresy predators strictly speaking but the trio of assembled baals was less $ than what a new deimos would cost... Just needed some tinkering, rummaging through old bits and we got a Nostramo pattern Predator - and I think the random assortment of weapons and adorments suits the legion. W.A.Rorie, Dr_Ruminahui, Corswain and 5 others 5 3 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6047937 Share on other sites More sharing options...
Dwango Posted June 30, 2024 Share Posted June 30, 2024 Now I've almost finished painting some ZM terrain I've managed to make some progress on the weaters. Reds and blues blocked in. I've done the trim on some termies too but not pictured. Lautrec the Embraced, LameBeard, W.A.Rorie and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6048097 Share on other sites More sharing options...
richmarine Posted July 5, 2024 Share Posted July 5, 2024 Some progress. Deredeo plasma guns WIP and my isstvan terrain is looking grim. firestorm40k, Dwango, W.A.Rorie and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6048788 Share on other sites More sharing options...
Dwango Posted July 6, 2024 Share Posted July 6, 2024 The trim is now done. Took like 4 days to do. The termies just need skin/faces doing then the white needs shading. All bases and weather/battle damage/blood effects will be fine at the same time. Lord Marshal, LameBeard, Lautrec the Embraced and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6048845 Share on other sites More sharing options...
richmarine Posted July 12, 2024 Share Posted July 12, 2024 some progress. Dwango, LameBeard, Lord Marshal and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6049794 Share on other sites More sharing options...
Dwango Posted July 20, 2024 Share Posted July 20, 2024 My vow is complete. 1 minute ago, Dwango said: Vow complete. I will be doing more, just need to sort size then pics. Reveal hidden contents richmarine, LameBeard and Lautrec the Embraced 3 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6050929 Share on other sites More sharing options...
Dwango Posted July 22, 2024 Share Posted July 22, 2024 (edited) My new vow. At the beginning of the year I vowed to paint all of my terrain. This continues and thought I might as well add it to a CtA vow. I'm making a ZM board for a heresy slow grow event I'm jointly running. All of this will be added to it. 10 hours ago, Dwango said: I, Dwango, heed the Call to Arms and pledge to paint 1 land raider (6pts), 3 thallax (3pts), 10 rampagers (10pts), 10 tacticals (10pts), 1 apothecary (1pts), 2 servo cranes (8pts), 4 servo haulers (8pts), 20 Pipes sections (40pts), 29 columns (29pts), 16 walls (32pts) 75 railings (25pts), Ladders and handrails (4pts), 8 single drop pods (8pts), 2 banks of drop pods (4pts), 2 sets of medicae equipment (2pts), 6 mini generator things (8pts) and 5 bins (not included in the points total, 1 generatorium hub (5pts) for 203pts for the Glory of the Warmaster and the Heresy Stronghold on or before 17th September 2024, or bear the badge of failure until years end. Edited July 22, 2024 by Dwango Spellings LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6051082 Share on other sites More sharing options...
richmarine Posted July 26, 2024 Share Posted July 26, 2024 So much stuff painted. All I’ve managed to do is this; I forgot to add the apothecary to the vow. time_of_flight, firestorm40k, WrathOfTheLion and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6052134 Share on other sites More sharing options...
Dwango Posted August 22, 2024 Share Posted August 22, 2024 Completed vow 2. I've pledged a third, much smaller vow too. Just done thallax, 2 apothecaries and a consul. Vow complete. Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6058982 Share on other sites More sharing options...
richmarine Posted August 30, 2024 Share Posted August 30, 2024 Recon complete. Vets started. Dwango, Lautrec the Embraced and LameBeard 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6061147 Share on other sites More sharing options...
richmarine Posted September 15, 2024 Share Posted September 15, 2024 terrain complete. I forgot to take pictures of them. But I used them in the opening of the isstvan 3 campaign. LameBeard and Dwango 2 Back to top Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6064581 Share on other sites More sharing options...
Rayray Posted December 29, 2024 Share Posted December 29, 2024 (edited) Is this call to arms deal still a thing? Is it like the Lux Semper used to run? Nvm, just saw the rules Edited December 29, 2024 by Rayray Link to comment https://bolterandchainsword.com/topic/383038-call-to-arms-2024-rally-point-traitors/#findComment-6083699 Share on other sites More sharing options...
