Brother Raul Posted June 11, 2024 Share Posted June 11, 2024 Hail Brothers and Sisters! Using bases that don't quite work for the rocks the new JPI are sculpted on. Don't want a them too high, basically want 20mm clear pegs to put under the jumping foot or something similar. Was thinking about cutting a X-Wing peg in half or 2/3rd. Understand Citadel have some but I can't get any pics of them or details. Thank you. Link to comment https://bolterandchainsword.com/topic/383102-citadel-flight-stands-or-other-recommendations/ Share on other sites More sharing options...
Grotsmasha Posted June 11, 2024 Share Posted June 11, 2024 Clear Perspex Round Rods, 2 or 3mm should be plenty sturdy enough, ebay will have you covered in avariety of lengths. If you go thicker, say 4mm you could have the rod attached to the base, and magnetise the marine to the rod. Firedrake Cordova and LameBeard 2 Back to top Link to comment https://bolterandchainsword.com/topic/383102-citadel-flight-stands-or-other-recommendations/#findComment-6044963 Share on other sites More sharing options...
Firedrake Cordova Posted June 16, 2024 Share Posted June 16, 2024 (edited) Some of the GW "flying" bases have clear pegs (the ones used for the Aeronautica Imperialis/Legions Imperialis aircraft spring to mind) - I don't know if any of those are easily available? (each base comes with a long one and a short one, so anyone with them is likely to have a bunch of spares) Edited June 16, 2024 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/383102-citadel-flight-stands-or-other-recommendations/#findComment-6045771 Share on other sites More sharing options...
