DISCIPLINARY ACTION
Remember that posting at the Bolter & Chainsword is a privilege, not a right. Those who abuse the privilege will find that privilege revoked. You aren't required to like the rules, but you are required to follow them.
Corrective action is taken by Moderati, Chief Librarian, and Administrati members (the "staff") when a member has broken the rules of the Bolter & Chainsword.
Wherever possible, the staff enforces board policy through guidance and example. If violations are identified, the staff will take the appropriate action. This action might be a warning in the thread, editing content in order to remove the violation, or sending a private message (PM) or e-mail. Deletion/hiding of content will be taken only when necessary to keep discussions civil and contructive.
Content may also be locked or hidden for a time to allow the staff to discuss whether an issue requires a warning or simple redirection.
Getting a PM from a staff member doesn't necessarily equate to a warning. Often, a staff member will contact a member to identify problematic behavior and to provide guidance for avoiding that behavior in the future. Official warnings will ALWAYS be accompanied by a message stating which rule(s) has been broken and the fact that an official warning is being issued for the violation(s). These messages will detail the infraction and the consequences of the disciplinary action. There are five types of rules violations:
  • Abusive behavior - mistreatment of other members, including doxxing
  • Off-topic - discussion outside the scope of the site, deliberate derailment of a discussion
  • Profanity - any content that includes either explicit profanity or attempts to bypass the swear filter
  • Spamming - repeatedly posting content across site in a disruptive manner, unsolicited messages to members, etc.
  • Other - catch-all for infractions not included in the above
If a behavior includes multiple types of violations, all types will be described. Only 1 warning point will be issued unless the severity of the infraction is deemed sufficient to warrant more warning points.
Active warning points generally expire after 180 days. However, all warnings are logged and will be taken into account when subsequent infractions occur.
WARNING CONSEQUENCES
Any official warning will incur consequences in three separate areas based on the criteria below.
  • Ban consequences are based on a member's total active warnings.
  • Reputation Level consequences are based on a member's total warnings, both active and expired, for all types of infractions.
  • Rank consequences are based on a member's total warnings, both active and expired, for the type of infraction for which the member is currently being warned.
Note that the system only imposes the Ban consequences as an automatic result of a warning being issued. The Reputation Level and Rank consequences will be included in the explanation that the member receives from the staff member, but require Administrator approval and action; so these consequences will be imposed subsequent to the warning being issued and explanation being sent.
BAN
A member will be banned from participating in the site based on the number of active warning points, including those received as a result of the current warning:
1) no ban (We consider this just a 'nudge.' You've broken a rule. Don't do it again or more severe penalties will be applied.)
2) 3-day ban
3) 7-day ban
4) 14-day ban
5) Permanent ban (movement to the + EXCOMMUNICATUS + group)
Members who threaten violence against other members may be subject to immediate permanent banning from the community.
While banned, the member will not be able to log in or participate in the site in any way. They can still view site content as a Guest.
REPUTATION LEVEL
A member will lose reputation points and/or level based on the number of active warning points plus the number of expired warnings for all types of infractions.
1) No effect on reputation
2) -1 level or down to Outstanding (675), whichever is lower
3) -1 level or down to Excellent (225), whichever is lower
4) -1 level or down to Very Good (75), whichever is lower
5) -1 level or down to Good (20), whichever is lower
6) -1 level or down to Neutral (0), whichever is lower
7) -1 level or down to Poor (-10), whichever is lower
8) -1 level or down to Bad (-20), whichever is lower
9+) Down to Bad (-20) automatically
Note 1: If the warning is for abusive behavior and the member has previously received one or more warnings for abusive behavior, increase all of the above by one level of severity (e.g., 4th overall warning: -2 levels or down to good (20), whichever is lower).
Note 2: When being reduced in reputation level, the member will lose sufficient reputation points to be at the lowest point value for the new reputation level, which is shown in parenthesis.
RANK
A member will lose achievement points and/or rank based on the number of active warning points plus the number of expired warnings for the same type of infraction. For example, if a member has 1 active warning point plus 2 expired warnings for profanity and they receive a new warning for profanity, they will have 4 total warnings (1 active + 2 expired + 1 new warning).
1) no reduction in points/rank
2) removal of 1 achievement point
3) removal of achievement points sufficient to demote member to next lower rank at lowest point value for that rank
4) removal of achievement points sufficient to demote member to next lower rank or Battle-Brother rank, whichever is lower, at lowest point value for that rank
5+) removal of achievement points sufficient to demote member to next lower rank or Novitiate rank, whichever is lower, at lowest point value for that rank
Note 3: Any warning issued for the abusive behavior type will additionally incur the loss of 1 achievement point. This may result in a reduction in rank (e.g., from Veteran to Battle-Brother).
Note 4: If a member suffers a rank reduction as a result of the automatic 1-point reduction for abusive behavior, there won't be another rank reduction except at 4 or 5 above, or if the offense was considered severe enough to warrant further reduction in rank.
MODERATOR PREVIEW
An optional consequence for an infraction is being placed on moderator preview. While a member is on moderator preview all content they submit will have to be reviewed and approved by the staff before it will be published to the community. The length of time that a member is on moderator preview will be determined by the staff. If the staff are satisfied that the member has reformed their behavior sufficiently, the member will be taken off moderator preview. If a member is placed on moderator preview, the warning comments will include a note to that effect and will indicate the length of time that the moderator preview will last.
When a member is permanently banned as a result of repeated violations of the forum rules, an announcement will be made. This will serve as notification of the ban to head off questions about the whereabouts of a member who has seemingly disappeared, as well as a demonstration that disciplinary action, though normally private between the offending member and the staff, does take place. The strategic goal with this sort of object lesson is to dissuade other members from similarly continuing to violate the forum rules. Such announcements will be pinned in the News, Rumors, and Board Announcements subforum temporarily, but the topics will be locked to prevent any unseemly discussion or responses. If you have any questions about a banning, you may contact the administrators.
Note that our previous disciplinary system simply suspended members instead of banning them, leaving banning as the final measure when a member demonstrated their unwillingness/inability to follow the forum rules. However, we have seen suspended members continue to misbehave during their suspension periods by using reactions in malicious ways. As a result, members will now be temporarily banned instead of being suspended at the lower disciplinary levels.
The Administrators reserve the right to take any disciplinary action they deem necessary, including actions outside those listed above and banning members with fewer than 5 active Warnings as and when they deem necessary.
CONTENT LOCKS
Content may be locked at the discretion of the staff. Reasons for topic locks include, but are not limited to:
  • Topic poses a question that is definitely answered.
  • Topic duplicates an existing topic.
  • Rumor/speculation that is disproven.
  • News/rumor topic once the product is released.
  • Topic has no constructive value.
  • Discussion has shifted off topic.
  • Discussion has become overly contentious.
  • Et cetera
When these situations arise, the staff will lock the topic with an explanation and the following image:
It is possible that the topic may be unlocked later. If necessary, some posts may be edited or hidden by the staff, or the staff may decide that folks have cooled their heels enough to get a topic back on track. You can take it up with your forum moderator if you have issue with a closing. However, please remain civil if you don't agree with what has been done. Flying off the handle will not help bring your point across.
THE REPORT FUNCTION
Inevitably, members aren't going to agree on everything; and, the Internet being what it is, people often act as if it's okay to say whatever they want because there won't be any consequences. Or sometimes someone says something that you find offensive, or that you think is inappropriate in some way.
You'll be tempted to return fire, giving tit for tat or escalating. The community doesn't need that. Remember, the mission of the site is to help each other to enjoy the hobby. It's difficult to do that when we're getting into spats with people we don't know.
Use the REPORT button when you see something that you think needs to be addressed. This will allow you to identify a potential problem to the staff, who will then evaluate the situation, discuss whether or not there is an issue that needs to be resolved, and then take whatever action we deem is appropriate. When you submit a report, be sure to explain the problem that you perceive in a constructive manner, no matter how obvious you think the issue is.
If you submit a report and don't see any action within 3 days, you are welcome to contact the forum moderators for a follow up. Keep in mind that disciplinary action usually takes place behind closed doors and will remain private between the staff and the offending member. While you may see that content is hidden/edited/locked, you will generally not be told the specifics of any punishment meted out to the offending member.
https://bolterandchainsword.com/topic/383222-disciplinary-action/
