Brother Raul Posted July 13, 2024 Share Posted July 13, 2024 Hi All, Both a post for my own learning and a little hack I found. I've found citadel flying bases both cheap and suitable to cut down. Have included a photo of both a glued trimmed stem (hate the casting bubble) and a drilled pegged stem. Little worried about how strong the trimmed and glued base will be as it's got to handle a lot of weight at that point but the drilled and pegged bases are super easy and don't even need glue so won't ruin your paint job. Dr_Ruminahui, Bouargh, Firedrake Cordova and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383270-flying-modelling-for-jump-troops/ Share on other sites More sharing options...
Brother Raul Posted July 13, 2024 Author Share Posted July 13, 2024 Forgot to mention that I also drilled the foot up into the calf for the top peg. Don't even need glue for that but have to file/ shave down the peg a bit to fit the biggest citadel dremel. Any comments or feed back greatly welcome. Link to comment https://bolterandchainsword.com/topic/383270-flying-modelling-for-jump-troops/#findComment-6049900 Share on other sites More sharing options...
Firedrake Cordova Posted July 14, 2024 Share Posted July 14, 2024 Looks like quite a pragmatic solution I'd imagine the strength should be fine - those pegs were used to support the old metal Carrion and BFG battleship models Brother Raul 1 Back to top Link to comment https://bolterandchainsword.com/topic/383270-flying-modelling-for-jump-troops/#findComment-6050022 Share on other sites More sharing options...
Marshal Mittens Posted July 29, 2024 Share Posted July 29, 2024 2mm brass rod painted black works well. Link to comment https://bolterandchainsword.com/topic/383270-flying-modelling-for-jump-troops/#findComment-6052892 Share on other sites More sharing options...
Grotsmasha Posted July 30, 2024 Share Posted July 30, 2024 I wouldn't worry about the peg snapping, Drukhari Raiders are mounted on them and they hold the weight just fine. Link to comment https://bolterandchainsword.com/topic/383270-flying-modelling-for-jump-troops/#findComment-6052902 Share on other sites More sharing options...
