Inquisitor_Lensoven Posted July 14, 2024 Share Posted July 14, 2024 Is there any reason at all to run max sized units? Especially 20+ blobs? the only thing I can think of is if you just want more bodies but you’ve got 3/6 of whatever squad it is. Just seems like with how blast works there isn’t much reason to take full sized units. Are there any strats or unit abilities that you can think of that offsets a minimum of 5 attacks from blast weapons. SvenIronhand 1 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/ Share on other sites More sharing options...
SvenIronhand Posted July 15, 2024 Share Posted July 15, 2024 Character buffs. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050071 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 15, 2024 Author Share Posted July 15, 2024 3 hours ago, SvenIronhand said: Character buffs. Idk, of a buff that offsets how much easier it is to kill a 20 man blob over 2 10 man blobs. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050083 Share on other sites More sharing options...
sairence Posted July 15, 2024 Share Posted July 15, 2024 (edited) I guess you need some buffs that make them annoying to remove without big commmitment. Not every army has them, so for them I don't see much benefit. But like a big Crusader-blob in BT with character support is pretty terrifying, as an example. At the end of the day the difference between 10 and 20 models is two extra shots. It's nice, but not world-ending imo. Edited July 15, 2024 by sairence Karhedron and Interrogator Stobz 2 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050094 Share on other sites More sharing options...
CL_Mission Posted July 15, 2024 Share Posted July 15, 2024 Because it'll look cool. Redcomet and Casual Heresy 2 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050095 Share on other sites More sharing options...
Karhedron Posted July 15, 2024 Share Posted July 15, 2024 11 hours ago, SvenIronhand said: Character buffs. And stratagems. Cenobite Terminator, DemonGSides, Redcomet and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050118 Share on other sites More sharing options...
Rogue Posted July 15, 2024 Share Posted July 15, 2024 If I can drop in a buffed-up unit of twenty that kills your blast unit, then it's problem solved :) I don't think you can just look at resilience. For me, part of the point of large units is that they can be significantly more effective compared to two half-sized units. Using GSC as an example, I could have 20 neophytes with an enhanced Primus and 1CP stratagem, getting sustained and lethal hits on 5+ and full rerolls to hit. Or, I can have that on 10 neophytes, and the other ten can just stand there and watch. Of course, there are times when option one will be overkill, and two lots of ten give me more tactical flexibility. But you asked for reasons to run units of 20+, and from a GSC perspective, souped-up neophytes are a strong choice. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050174 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 15, 2024 Author Share Posted July 15, 2024 11 hours ago, sairence said: I guess you need some buffs that make them annoying to remove without big commmitment. Not every army has them, so for them I don't see much benefit. But like a big Crusader-blob in BT with character support is pretty terrifying, as an example. At the end of the day the difference between 10 and 20 models is two extra shots. It's nice, but not world-ending imo. I guess it depends on how many blast weapons a unit is throwing at it. 3 frag missiles for example is 6 extra shots. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050176 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 15, 2024 Author Share Posted July 15, 2024 15 minutes ago, Rogue said: If I can drop in a buffed-up unit of twenty that kills your blast unit, then it's problem solved :) I don't think you can just look at resilience. For me, part of the point of large units is that they can be significantly more effective compared to two half-sized units. Using GSC as an example, I could have 20 neophytes with an enhanced Primus and 1CP stratagem, getting sustained and lethal hits on 5+ and full rerolls to hit. Or, I can have that on 10 neophytes, and the other ten can just stand there and watch. Of course, there are times when option one will be overkill, and two lots of ten give me more tactical flexibility. But you asked for reasons to run units of 20+, and from a GSC perspective, souped-up neophytes are a strong choice. Sure if I only have one unit with such weapons. unfortunately most armies will have a plethora of units with blast weapons. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050179 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 15, 2024 Author Share Posted July 15, 2024 (edited) Static choices in my guard army lists that never change *with blast HWS x3 mortars infantry squad x2 GL/ML exterminator w/ PCs battle tank demolisher Against an army of 20 man blobs that’s 18 extra attacks thats a pretty big thing. *edit Edited July 15, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050191 Share on other sites More sharing options...
Rogue Posted July 15, 2024 Share Posted July 15, 2024 True, but are there armies consisting entirely (or mostly) of units like that? You take a unit for a specific purpose. In my lists, the 20-neophyte blob is there to drop in, clear something, then hop out and do it again (which is trickier right now, but still). The nature of the unit's purpose limits their spamability, because I really want that specific stratagem to make them as dangerous as possible. Otherwise, as you suggest, I'm just putting down big targets to be shot at. But if I want a unit to sit on my base objective, or to ride around in trucks, then I'm going with 10s every time - I don't need them to do the same things, so I gear them differently. Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050219 Share on other sites More sharing options...
Emperor Ming Posted July 15, 2024 Share Posted July 15, 2024 I've never seen anyone use a missile launcher in A long time Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050220 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 15, 2024 Author Share Posted July 15, 2024 (edited) 1 hour ago, Emperor Ming said: I've never seen anyone use a missile launcher in A long time I’ve had a bunch of MLs laying around for a while. theyve done pretty well for me so far. But even then they’re part of my gun line so I could easily replace them with mortars and still have the same number of blast weapons. 1 hour ago, Rogue said: True, but are there armies consisting entirely (or mostly) of units like that? You take a unit for a specific purpose. In my lists, the 20-neophyte blob is there to drop in, clear something, then hop out and do it again (which is trickier right now, but still). The nature of the unit's purpose limits their spamability, because I really want that specific stratagem to make them as dangerous as possible. Otherwise, as you suggest, I'm just putting down big targets to be shot at. But if I want a unit to sit on my base objective, or to ride around in trucks, then I'm going with 10s every time - I don't need them to do the same things, so I gear them differently. I guess yeah if you’re pulling the unit off the board every turn a 20 blob makes some sense. Edited July 15, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050225 Share on other sites More sharing options...
DemonGSides Posted July 16, 2024 Share Posted July 16, 2024 16 hours ago, Inquisitor_Lensoven said: Static choices in my guard army lists that never change *with blast HWS x3 mortars infantry squad x2 GL/ML exterminator w/ PCs battle tank demolisher Against an army of 20 man blobs that’s 18 extra attacks thats a pretty big thing. *edit Please shoot all of these guns at my infantry blob. PLEASE. My multiple other tanks and stuff will be thrilled. Mission accomplished, squishy human bodies. Let the big boys take care of the problem. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050268 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 16, 2024 Author Share Posted July 16, 2024 4 hours ago, DemonGSides said: Please shoot all of these guns at my infantry blob. PLEASE. My multiple other tanks and stuff will be thrilled. Mission accomplished, squishy human bodies. Let the big boys take care of the problem. Luckily probably only need to shoot one unit at your blob to kill all or most of your infantry blob. sairence and SvenIronhand 2 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050304 Share on other sites More sharing options...
DemonGSides Posted July 16, 2024 Share Posted July 16, 2024 (edited) 3 hours ago, Inquisitor_Lensoven said: Luckily probably only need to shoot one unit at your blob to kill all or most of your infantry blob. Hasn't been my experience with 10th, and I've played quite all few games of it by this point. Edited July 16, 2024 by DemonGSides Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050314 Share on other sites More sharing options...
tychobi Posted July 16, 2024 Share Posted July 16, 2024 Big squads are fun. Guard has enough blast to counter them somewhat. All working as intended. Not sure what the point of the thread is? SvenIronhand 1 Back to top Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050315 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 16, 2024 Author Share Posted July 16, 2024 1 hour ago, DemonGSides said: Hasn't been my experience with 11th, and I've played quite all few games of it by this point. Damn how you been getting games of 11th in? 58 minutes ago, tychobi said: Big squads are fun. Guard has enough blast to counter them somewhat. All working as intended. Not sure what the point of the thread is? I’ve just not seen many if any benefits to out weigh the negatives Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050318 Share on other sites More sharing options...
DemonGSides Posted July 16, 2024 Share Posted July 16, 2024 1 hour ago, Inquisitor_Lensoven said: Damn how you been getting games of 11th in? I come from the future. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050333 Share on other sites More sharing options...
Minsc Posted July 17, 2024 Share Posted July 17, 2024 Pro: Characterbuffs and more mileage from Stratagems and such. Con: More vulnerable to blasts and a bit worse at objective gaming. If its worth it or not depends entitely on yourself and your local meta I'd say. For me I think the pros generally outweigh the cons, but it also depends on the list and if there is an attached character or not. Link to comment https://bolterandchainsword.com/topic/383277-squad-sizes-and-blast/#findComment-6050463 Share on other sites More sharing options...
