Kharn13 Posted July 23, 2024 Share Posted July 23, 2024 Hi folks, Should have done this 6 months ago, but here we are! Like many hobbyists, as a child I only collected random blister packs that I thought looked cool. Since returning to the hobby I’ve been playing CSM and WE. Most recently painting up Skarbrand as a practice run for Angron. Cenobite Terminator, Xin Ceithan, INKS and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/ Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted July 23, 2024 Share Posted July 23, 2024 Hello,hello, hello! Welcome frater! Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051410 Share on other sites More sharing options...
Xin Ceithan Posted July 23, 2024 Share Posted July 23, 2024 Always good to see another follower of the primal Truth here! Welcome to the B&C ! Looking forward to seeing more skulls for the Chaos sub! Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051436 Share on other sites More sharing options...
W.A.Rorie Posted July 23, 2024 Share Posted July 23, 2024 Hello @Kharn13 and Welcome to the B&C! And Nice JOB! Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051514 Share on other sites More sharing options...
INKS Posted July 23, 2024 Share Posted July 23, 2024 Welcome! Skarbrand looks awesome!!!!! Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051569 Share on other sites More sharing options...
Dr_Ruminahui Posted July 23, 2024 Share Posted July 23, 2024 Your Scarbrand is awesome, though I suspect you're not quite finished and will be putting some more work into the axe heads to bring them up to the same level as the rest of the model. Before you start a new chaos model (say, Angron) you should consider dropping by the Chaos Stronghold of the Call to Arms event and consider pledging it. Even if painting events aren't normally your thing, this one might be - I would like to think we've kept it very positive and low pressure. Or, if your next models aren't chaos, consider pledging them in the Imperial, Xenos or 30K strongholds. Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051611 Share on other sites More sharing options...
Kharn13 Posted July 23, 2024 Author Share Posted July 23, 2024 1 hour ago, Dr_Ruminahui said: Your Scarbrand is awesome, though I suspect you're not quite finished and will be putting some more work into the axe heads to bring them up to the same level as the rest of the model. Before you start a new chaos model (say, Angron) you should consider dropping by the Chaos Stronghold of the Call to Arms event and consider pledging it. Even if painting events aren't normally your thing, this one might be - I would like to think we've kept it very positive and low pressure. Or, if your next models aren't chaos, consider pledging them in the Imperial, Xenos or 30K strongholds. Thanks dude, not sure on the axe heads yet. Work to do for sure! Thanks for the suggestion, is this a once a year thing? Sad I missed the start. There is only one stronghold I’m interested in and that is Chaos! 4 hours ago, INKS said: Welcome! Skarbrand looks awesome!!!!! Thanks dude! Dr_Ruminahui and INKS 2 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051636 Share on other sites More sharing options...
Dr_Ruminahui Posted July 23, 2024 Share Posted July 23, 2024 (edited) Yep, Call to Arms is a once of year thing, but folks can jump in at any time - no need to have been here from the start. All it means is you have less painting time, as it ends mid-September. And even if you don't join, drop by and cheer folks on - every bit of support is appreciated. Glad to hear you are all in on Chaos - hopefully we'll see you join, and if not I'll see you around the various Chaos forums. Edited July 23, 2024 by Dr_Ruminahui Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051637 Share on other sites More sharing options...
Kharn13 Posted July 23, 2024 Author Share Posted July 23, 2024 11 minutes ago, Dr_Ruminahui said: Yep, Call to Arms is a once of year thing, but folks can jump in at any time - no need to have been here from the start. All it means is you have less painting time, as it ends mid-September. And even if you don't join, drop by and cheer folks on - every bit of support is appreciated. Glad to hear you are all in on Chaos - hopefully we'll see you join, and if not I'll see you around the various Chaos forums. Thanks for the extra info. I’ve had a kitbashed daemon prince sat on my paint desk unpainted for a while which I might enter into the Master of the Forge category. If not, I’ll be sure to cheer people on. See you in the Chaos forums! LameBeard and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051641 Share on other sites More sharing options...
Celtic_cauldron Posted July 25, 2024 Share Posted July 25, 2024 Welcome Kharn13! Celtic_Cauldron Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6051875 Share on other sites More sharing options...
Cenobite Terminator Posted August 6, 2024 Share Posted August 6, 2024 Welcome to the fold Kharn13. Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383333-a-belated-hello/#findComment-6054427 Share on other sites More sharing options...
