hd3 Posted July 28, 2024 Share Posted July 28, 2024 Per title. I rushed my Havocs to get them ready for a game day and now my squad markings are off on two of them. IS there anyway i can remove them without ruining the paintjob on the shoulder? Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/ Share on other sites More sharing options...
Grotsmasha Posted July 28, 2024 Share Posted July 28, 2024 Have you varnished over the decal? Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6052404 Share on other sites More sharing options...
hd3 Posted July 28, 2024 Author Share Posted July 28, 2024 No, just micro sol/set Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6052405 Share on other sites More sharing options...
Grotsmasha Posted July 28, 2024 Share Posted July 28, 2024 Did you varnish the pad prior to setting the decal? if yes, Microsol softens the decal, perhaps hitting it with more microsol and agitating it with a soft bristle toothbrush could be enough to get them off. WrathOfTheLion, crimsondave, Mithrilforge and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6052452 Share on other sites More sharing options...
crimsondave Posted August 3, 2024 Share Posted August 3, 2024 Agree with Grotsmasha. If you haven't varnished it, you can keep brushing it with Microsol it will eventually rub right off. I've done it several times. WrathOfTheLion and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6053770 Share on other sites More sharing options...
WrathOfTheLion Posted August 3, 2024 Share Posted August 3, 2024 1 hour ago, crimsondave said: Agree with Grotsmasha. If you haven't varnished it, you can keep brushing it with Microsol it will eventually rub right off. I've done it several times. I've done it a few times by accident, so if it works on accident, I think it should work better intentionally :) Firedrake Cordova, Sky Potato and crimsondave 3 Back to top Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6053774 Share on other sites More sharing options...
Mithrilforge Posted August 5, 2024 Share Posted August 5, 2024 This is the Way! As all of the above have already stated, I have removed decals by using MicroSol on the decal to soften it up again and rub with a cotton swab (earbud) till the decal softens and breaks up and comes off Mithril Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6054063 Share on other sites More sharing options...
Xenith Posted August 5, 2024 Share Posted August 5, 2024 On 7/28/2024 at 7:52 AM, hd3 said: No, just micro sol/set One of those says 'decal softner/remover' on them - apply that to the decal until it softens and can be shoved off with a brush. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383372-best-way-to-remove-a-water-slide-decal-that-has-already-dried-without-damaging-the-paint/#findComment-6054086 Share on other sites More sharing options...
