INKS Posted July 28, 2024 Share Posted July 28, 2024 I am trying to find the closest match to 003DA5 - it's a blue or a navy blue color. I have tried to google it but I can't seem to find a close match or even how to know that other than my eyes, which aren't very good. lol I know Citadel doesn't have a direct match, I am not sure about other brands. A search did not turn up anything, but maybe I am just searching wrong. If there isn't a direct match, then I wonder if someone with better eyes or a better understanding of the hex code for colors could help me match that blue. I would really appreciate it. thank you Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/ Share on other sites More sharing options...
Brother Tyler Posted July 28, 2024 Share Posted July 28, 2024 003DA5 The two GW colors that look close (but aren't quite right) appear to be... Altdorf Guard Blue: 1F56A8 Macragge Blue: 0D407F Neither one is close enough for me to suggest using them, though. Each might be made closer to the color you're looking for through a combination of mixing and/or undercoats. There may be more recent GW colors that I haven't converted into hexadecimal, or colors in other ranges. The trick (with the hexadecimal code) is to look at the colors on the same monitor as the one you're looking at 003DA5. Even then, appearance on the computer monitor invariably differs from actual appearance. Firedrake Cordova and INKS 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052430 Share on other sites More sharing options...
Cleon Posted July 28, 2024 Share Posted July 28, 2024 My issue is trying to visualise your blue - is there something 'real' you got the colour from? Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052442 Share on other sites More sharing options...
INKS Posted July 28, 2024 Author Share Posted July 28, 2024 2 hours ago, Brother Tyler said: 003DA5 The two GW colors that look close (but aren't quite right) appear to be... Altdorf Guard Blue: 1F56A8 Macragge Blue: 0D407F Neither one is close enough for me to suggest using them, though. Each might be made closer to the color you're looking for through a combination of mixing and/or undercoats. There may be more recent GW colors that I haven't converted into hexadecimal, or colors in other ranges. The trick (with the hexadecimal code) is to look at the colors on the same monitor as the one you're looking at 003DA5. Even then, appearance on the computer monitor invariably differs from actual appearance. Thanks @Brother Tyler this is really good. Maybe mixing them will get me even close to what I am looking for. 18 minutes ago, Cleon said: My issue is trying to visualise your blue - is there something 'real' you got the colour from? Yes, it is the color used on the quebecois flag. Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052443 Share on other sites More sharing options...
LameBeard Posted July 28, 2024 Share Posted July 28, 2024 It looks not so much Navy Blue as Royal Blue, or even a French Blue. Maybe try Vallejo who do one each of those. INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052446 Share on other sites More sharing options...
Cleon Posted July 28, 2024 Share Posted July 28, 2024 Ah right, never actually seen a real one, but from pictures I think the Vallejos I was looking at are a too deep/strong blue. Possibly Cobolt Blue is closer to what you're looking for, it's 62.009 but I can't see it loaded to encycolorpedia to be sure. INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052456 Share on other sites More sharing options...
INKS Posted July 28, 2024 Author Share Posted July 28, 2024 Yes I guess it's more royal than navy. I said navy blue because when I googled the color that is what it called it. but it's a brighter and not darker blue Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052460 Share on other sites More sharing options...
Bryan Blaire Posted July 28, 2024 Share Posted July 28, 2024 Try Vallejo Game Color Magic Blue (72.021) or Pro Acryl’s Blue (005), or possibly Vallejo Model Color Andrea Blue (70.841). Alternatively, you could also look at Golden Fluid Acrylics Manganese Blue Hue or more likely the Golden Fluid Acrylics Cobalt Blue (#2140-1 Series 8). Hope that can help! Color matching exact can be tough. INKS and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052465 Share on other sites More sharing options...
INKS Posted July 28, 2024 Author Share Posted July 28, 2024 7 minutes ago, Bryan Blaire said: Try Vallejo Game Color Magic Blue (72.021) or Pro Acryl’s Blue (005), or possibly Vallejo Model Color Andrea Blue (70.841). Alternatively, you could also look at Golden Fluid Acrylics Manganese Blue Hue or more likely the Golden Fluid Acrylics Cobalt Blue (#2140-1 Series 8). Hope that can help! Color matching exact can be tough. thank you, I will take a look at all these colors. Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052466 Share on other sites More sharing options...
Brother Tyler Posted July 28, 2024 Share Posted July 28, 2024 Vallejo: Color Charts web page The Army Painter: Vivid Blues | Speedpaint (similar to GW Contrast) | Warpaints Air AK Interactive: (select "Products") Each of the linked pages has color swatches, or links to color swatches. You should be able to find something close to what you're looking for. Desired: 003DA5 The Army Painter Regal Blue (014983) The Army Painter Royal Blue (0057A5) The Army Painter Imperial Navy (00355E) LameBeard, Firedrake Cordova and INKS 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052469 Share on other sites More sharing options...
INKS Posted July 28, 2024 Author Share Posted July 28, 2024 3 minutes ago, Brother Tyler said: Vallejo: Color Charts web page The Army Painter: Vivid Blues | Speedpaint (similar to GW Contrast) | Warpaints Air AK Interactive: (select "Products") Each of the linked pages has color swatches, or links to color swatches. You should be able to find something close to what you're looking for. Desired: 003DA5 The Army Painter Regal Blue (014983) The Army Painter Royal Blue (0057A5) The Army Painter Imperial Navy (00355E) Super helpful thank you. Maybe Imperial Navy with some white or something. I'll keep looking but it seems like I am going to have to mix a little to get what I need. that is ok. just going to take some time and experimentation I guess. Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052470 Share on other sites More sharing options...
Firedrake Cordova Posted July 28, 2024 Share Posted July 28, 2024 Vallejo have a Royal Blue in their Model Colour line. Based on the swatch on their site, it looks a bit darker than your desired colour, though. INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052476 Share on other sites More sharing options...
Grotsmasha Posted July 28, 2024 Share Posted July 28, 2024 That looks like GW's Caledor Sky could be right INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052508 Share on other sites More sharing options...
Bung Posted July 29, 2024 Share Posted July 29, 2024 There are some Hobby Apps that May Help you. Paint Rack and Hobby colour converter have a function where you can take a picture of something and you can get the closest Hobby Paint from the paints in the App. INKS, Firedrake Cordova and Magos Takatus 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052533 Share on other sites More sharing options...
INKS Posted July 29, 2024 Author Share Posted July 29, 2024 14 minutes ago, Bung said: There are some Hobby Apps that May Help you. Paint Rack and Hobby colour converter have a function where you can take a picture of something and you can get the closest Hobby Paint from the paints in the App. will have to look these up to see if it helps some Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052535 Share on other sites More sharing options...
Bryan Blaire Posted July 29, 2024 Share Posted July 29, 2024 (edited) INKS, having the Golden Fluid Acrylics Cobalt Blue (pigment PB28) in hand, it looks, at least to my eyes, against the color band that hex code is making on here, to be almost identical to that color. The color band looks a hair lighter to my eyes, like you might need to add one drop of titanium white paint to like 4 drops of the cobalt blue to get that color or something similar (may need a drop more of T White or a drop or two more of C Blue). The hex code for cobalt blue is supposedly 0047AB - not sure hex-wise how far off that is from the 003da5, but doesn’t seem like it’s that far off to the less educated me. Edited July 29, 2024 by Bryan Blaire Firedrake Cordova, INKS and LameBeard 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052542 Share on other sites More sharing options...
INKS Posted July 29, 2024 Author Share Posted July 29, 2024 12 minutes ago, Bryan Blaire said: INKS, having the Golden Fluid Acrylics Cobalt Blue (pigment PB28) in hand, it looks, at least to my eyes, against the color band that hex code is making on here, to be almost identical to that color. The color band looks a hair lighter to my eyes, like you might need to add one drop of titanium white paint to like 4 drops of the cobalt blue to get that color or something similar (may need a drop more of T White or a drop or two more of C Blue). The hex code for cobalt blue is supposedly 0047AB - not sure hex-wise how far off that is from the 003da5, but doesn’t seem like it’s that far off to the less educated me. This is awesome, thanks so much!!! Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6052544 Share on other sites More sharing options...
NovemberIX Posted July 30, 2024 Share Posted July 30, 2024 There's also this that might help https://redgrimm.github.io/paint-conversion/index.html Colorhexa also does a good break down where they show what the HEX breaks down to in RGB decimal and percentages. On 7/28/2024 at 10:11 PM, Bryan Blaire said: The hex code for cobalt blue is supposedly 0047AB - not sure hex-wise how far off that is from the 003da5, but doesn’t seem like it’s that far off to the less educated me. That's probably pretty close, It's breaks down to a a few percent more green and a tiny bit more blue. I'm gonna try and explain hex as I know it, the problem is hex only half works for model painting, cause it's about intensity of light not amount of pigment. They can kinda cross over if you do a conversion to CMYK (hence the colorhexa link, but that's outside my general experience). HEX is just the base16 description of RGB colors, instead of using decimals between 0-255, you use 00 to FF with the letters A-F standing in for digits after 9. So basically when I look at the hex, I see 00 as no red, 3D as a bit less than a quarter green 47 takes that about a percent more, and A5 as about 70% intensity blue, so AB would maybe be 72-73%. Translated (again from hexa) the original color becomes 0, 61, 165 in decimal terms, cobalt is 0, 71,171, so all in all pretty close. So what does this mean? well not a whole lot, you already got a couple of great suggestions, the Cobalt blue would look good, and I'd second Proacryl Blue, maybe laying that over Vallejo French Blue might get you where you want. INKS, Bryan Blaire, Brother Tyler and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383373-003da5-blue/#findComment-6053062 Share on other sites More sharing options...
